Ga-Ma "trail" on Klein Pella, Northern Cape for the adventurous - Page 6
Page 6 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 101 to 120 of 257
  1. #101
    Sep 2018
    Not too far from Pofadder
    Thanked: 328
    Default Re: Ga-Ma "trail" on Klein Pella, Northern Cape for the adventurous
    I couldnt leave it like it was, i had to move that rock and do the leveling.
Name:	Klein Pella Ga-ma 154.jpg
    I definitly need a better panoramic app, any suggestions?
    Current progress is about 5m / hr, I think it will remain that for the next 100m or so.
Name:	Klein Pella Ga-ma 155.jpg
  2. #102
    Sep 2018
    Thanked: 328
    A bit of progress. I removed the bigger rocks so I could plan the line through the gully.
Name:	Klein Pella Ga-ma 158.jpg
    stacked the bigger rocks on the lower side so they can form a barrier and prevent sand from washing away.
Name:	Klein Pella Ga-ma 159.jpg
    Looking back you can see there is still a lot of work to level it.
Name:	Klein Pella Ga-ma 156.jpg
    Before
Name:	Klein Pella Ga-ma 157.jpg
    After
  3. #103
    Sep 2018
    Thanked: 328
    I took the Hardbody up to the gully today for the first time to judge the progress with a vehicle on the track.
Name:	Klein Pella Ga-ma 160.jpg
    The track is ok to where the hardbody is standing.
Name:	Klein Pella Ga-ma 161.jpg
    There is quite a bit of work still to get the turn right, but I wanted to jump ahead first to clear the bigger rocks out and see where the line will be.
Name:	Klein Pella Ga-ma 162.jpg
    Looking back.
Name:	Klein Pella Ga-ma 163.jpg
    some rocks cleared out.
Name:	Klein Pella Ga-ma 164.jpg
    Only the big one remaining. I tried but could not split it so I hav to lift and wedge, lift and wedge and repeat untill i had it rolled away. I need to get the sledge hammer out here again.
Name:	Klein Pella Ga-ma 165.jpg
    All the rocks cleared out and the sharp edges blunted to save the sidewalls.
Name:	InkedKlein Pella Ga-ma 167_LI.jpg
    The path will follow the green line drawn in.
    Next I have to finish the turn and the drop into the gully.
  4. #104
    Sep 2018
    Thanked: 328
Name:	Klein Pella Ga-ma 170.jpg
    I leveled the turn and drop down. It looks a bit out of place, but previous experience showed that it will blend in once it get used.
Name:	Klein Pella Ga-ma 171.jpg
    I took the bike through to where I need to work now.
Name:	Klein Pella Ga-ma 172.jpg
    The line is going up this step, but more to the right.
Name:	Klein Pella Ga-ma 173.jpg
    The line passes between two Myhr trees (Mirre boompies).
    The pass will probably be called Myhr Pass (Mirre pas)
Name:	Klein Pella Ga-ma 174.jpg
    The Myhr tree on the left looks like it recently got some water, I just have no idea where that would be from, we haven't had any rain this year.
    As far as I understand this Myhr tree is not the same as the one in the middle east, but I do not know much about it I would be grateful if someone could I'd it for me and maybe provide a link to more information.
  5. #105
    Feb 2007
    Thanked: 85
    Quote Originally Posted by Bex View Post
    Bex, Ek het 'n vriend gevra..hoop hy kan help. Ek beplan om laat in Des/vroeg Januarie 'n draai in die area te maak, Gaan jy daar wees en weet jy dalk of die winkel oop sal wees om dadels ens te koop? groete Paul
  6. #106
    Sep 2018
    Thanked: 328
    Ek is die hele week voor Kersfees uit vir vergaderings en is die eerste week van Jan uit, ek kom die 6 de terug, die res van die tyd is ek hier.
    Die gastehuis het nog dadels en sal he tot daai tyd.
  7. #107
    Feb 2007
    Thanked: 85
    dankie...voorlopige beplanning is om daar te wees rondom 29 Des.
  8. #108
    Sep 2018
    Thanked: 328
    The best closeup I have of the tree.
  9. #109
    Feb 2007
    Thanked: 85
    Dankie ek stuur vir Deon aan
  10. #110
    Feb 2007
    Thanked: 85
    My vriend Deon is redelik seker dis die dikvoet, Pachypodium succulentum.
  11. #111
    Sep 2018
    Thanked: 328
    It does not look the same to me, i also looked up pachypodium Succulentum for more picture.
    I will make a sepperate thread and post better pictures.
  12. The Following User Says Thank You to Bex For This Useful Post:
  13. #112
    Sep 2018
    Thanked: 328
    I cleared the passage between the trees.
    Before
Name:	Klein Pella Ga-ma 180.jpg
    After. the step up was not high, about 300m , but the rock kept breaking into an overhang so I had to break it far back and then fill it in with gravel, so it ended up looking flat.
Name:	Klein Pella Ga-ma 181.jpg
    Looking back.
Name:	Klein Pella Ga-ma 182.jpg
    So tomorrow morning early I want to clear a path through this, then a step up and another one like this.
    It should go quick, I would like to break through to the top by tomorrow evening.
  14. The Following User Says Thank You to Bex For This Useful Post:
  15. #113
    Sep 2018
    Thanked: 328
    I wanted to get a lot done today so I was out there at 6 this morning.
    This would be the first time through the gully with the 4x4.
    Gaps that looked unnecessarily wide while making them suddenly did not look wide enough any more.
    I did manage to get through, but I decided to spend some time making the gaps more GD6 friendly.
    This took a bit of time, but I don't want to see any more men cower while angry wifes go on about scratches and dents.
    It fit through the gap between the trees without problem.
    Then I could start on the gap I wanted to clear.
    Before.
    The sun was just reaching the work site and the light was not great for pictures so I didn't take many. It took about 2 hrs to clear it out.
    The gap was too narrow and I did not want to break away everything so I left the ledge on the left intact. You have to get both left wheels up onto it.
    At the top there as an axle twister and I had a bit of trouble getting through.
    The limited slip differential could not quite get me through so I backed off a bit and filled the hole on the right with a flat rock and some gravel.
    I got it Through. I had run out of time as I had to go do some work, but the hardest part in this pass is over, I will see if I can get to the top this afternoon when go make up for the time I lost widening it for some bigger vehicles.
  16. The Following 2 Users Say Thank You to Bex For This Useful Post:
  17. #114
    Oct 2012
    Thanked: 219
    Bex, this country needs more people like you! Keep up the good work.....would love to come visit you some time.
    That Mighty Amarok
    Swart Tires wat ek self gekoop het
    Pull over wat my ouma gebrei het
    Vensters waar deur ek kan sien
    Engine voor
    Exhaust agter
  18. The Following 2 Users Say Thank You to Snyks For This Useful Post:
  19. #115
    Sep 2018
    Thanked: 328
    Thanks Snyks. I look forward to more 4x4 enthusiasts driving the trail.
    Another pair worn through.
    Pedro joined me this evening, so we made short work of the last bit of the pass.
    A last climb to the top.
    On top of the plataeu there is a lot less work to do, so I did another 500m before turning back.
    I do have to plan the trail and mark it out. I have however now reached the point where traveling to where I am working takes too much time to do it in short bursts. I will have to do most of the trail on the plataeu in one or 2 trips over weekends, and then start to work on the descent from the other side.
    The next 3 week will be hectic so I don't think I will add much to the trail till around Christmas. I will drive on it a bit though.
  20. The Following 2 Users Say Thank You to Bex For This Useful Post:
  21. #116
    Sep 2018
    Thanked: 328
    I have some visitors.
    They really enjoyed testing the first part of trail C.
  22. The Following User Says Thank You to Bex For This Useful Post:
  23. #117
    Sep 2018
    Thanked: 328
    Just some random pictures of recent activity on the Trail A. I think a more detailed report will be forthcoming at some stage.
ID:	513075   Click image for larger version.
ID:	513076   Click image for larger version.
ID:	513078   Click image for larger version.
  24. #118
    Sep 2018
    Thanked: 328
    Route B
    The FJ did a climb up a rock that have not been attempted before. I did talk about maybe adding it in a previous post. We had to clear away a few rocks at the top for it to get over it as i didnt finish it before.
    The aproach to the rock is on the rear side, and the steep part of the climb has a 90 degree sharp left turn before it gets to where it is parked in the picture. Mark rose to the challenge an the rock is therefore named "Mark's challenge"
    The cross over on the edge of a big drop.
    Dropping into the river bed.
    I will probably resume normal trail building posts in 2 weeks time, for now I have too many irons in the fire.
  25. The Following User Says Thank You to Bex For This Useful Post:
  26. #119
    Jul 2018
    Kathu
    Thanked: 71
    this looks awesome. A good excuse to take the family to Klein Pella. What do you think of the route on big litre class bikes? That's also tempting for me as a quick weekend getaway....
  27. #120
    Dec 2013
    Paarl
    Thanked: 506
    This place has been written onto the to do list
