Discovery 4 Long Range Tank
Results 1 to 20 of 33
Hybrid View
    Hoedspruit
    Thanked: 89
    Default Discovery 4 Long Range Tank
    Good day everyone.
    Just a quick question. I have a Frontrunner Long Range Tank fitted to my D4 V8. The Frontrunner website said that there is no way of telling how much fuel is in the tank. This past weekend we drove to Pta and filled the car with a 103 liters. I did ask the person filling the tank to give it a minute or two as the filler pipe feeds both tanks. After he said nothing more wants to go in I assumed both tanks were full. We drove until the main tank was just under three quarters and I started pumping from the auxiliary tank and it filled the main tank. After a couple of days in Pta we hit the road again and wanted to pump more petrol from the auxiliary tank as we only pumped about a quarter tank from the 2nd tank, thus there still should be plenty left. I could hear the pump coming on, but after a couple of minutes I noticed that the fuel in the main tank is not increasing. I stopped the pump as I don't want it to get burnet out. Went to the filling station and only managed to fill 93 liters before it could not take anymore.
    Any suggestions? I can't hear a difference in the pump in terms of noise. So now I'm not sure if the pump is faulty or the tank is empty.
    Also, how long does it take to fill the 2nd tank? Maybe it wasn't filled up properly.
    Any help would be appreciated.
    Andre
    2011 Discovery 4 V8 HSE
    May 2012
    Thanked: 124
    Default Re: Discovery 4 Long Range Tank
    Takes about 30 minutes
  3. The Following User Says Thank You to Onematch For This Useful Post:
    Hoedspruit
    Thanked: 89
    Thank you Onematch
    That will make sense then. Perhaps the 2nd tank did not fill, as didn't spend more that 10min at the pump.
    Feb 2012
    Chintsa East
    Thanked: 466
    You have a huge airlock. I had the same with mu 90 till I fitted a second breather from the 2nd tank that vented into the filler pipe. T-d it into the main breather pipe.
    2013 Disco 4 XS Lifted
    Toyota Yaris, Swambo's shopping basket
    Jeep Wrangler Sahara 2006 the worsies car for the beach(what a car!! )
  6. The Following 3 Users Say Thank You to pwgg For This Useful Post:
    May 2012
    Thanked: 124
    Quote Originally Posted by pwgg View Post
    That news makes me a happy man, will speak to my Indy - the only problem left is the cash payment at the end of the refuel!!!
    Sinoville Pretoria
    Thanked: 570
    So you have to spend 30 minutes at filling station??
    Surely design or installation of the long range tank must be defective?
    Air lock or breather problem?
    Henk Pretorius D4 3,0 SDV6 HSE
    EX AFRICII SEMPER NOVUS
  9. The Following 2 Users Say Thank You to julius caesar For This Useful Post:
  10. #7
    Sinoville Pretoria
    Thanked: 570
    Pwgg great minds think alike😎
  11. #8
    Forest Hills, KZN
    Thanked: 782
    30min at the pump?? Is that how long it really takes?
    2004 LR Discovery 2 Td5 GS - Hybrid Turbo, Intercooler, 33's, 2" Lift, V8 TC, Ashcroft CW&P 3.75 + ATB lockers. (Ingwe)
  12. The Following User Says Thank You to douglash For This Useful Post:
  13. #9
    Thanked: 109
    Fitting a LR tank to a V8 has some unique challenges due to the fact that it actually breathes through the carbon canister once the filler cap is closed. There is a lot more plumbing below the V8 compared to the Diesels. IIRC even the Kameel developed in conjunction with Landyworx had some issues on the V8, last I recall, I might have heard incorrectly, they don't fit them to V8s anymore.
    Mine is a copy of the original FR tanks that had a raised bit where the breather connects. I got it from Bob in Alberton as he had it made years ago according to the original FR drawings (I did not ask how he got hold of them), later on FR went for a design that's simpler to manufacture.
    It took me a few weeks to sort out all the niggles. It is very easy to get a breather just wrong enough to create airlock, especially as all the other plumbing limits space for routing. Initially I struggled to fill the tanks. Keeping in mind that no matter what I did through the years, filling the V8 takes a bit of time and I hated stopping to fill up.
    I ended up creating a dual filler point, to have peace of mind on exactly how much goes into which tank, increasing breather diameter and added a fuel gauge, although this is not really accurate. This then created the situation where the larger tank would pressurise when full, the filler caps have a one-way valve to let air in, not out. In my case these two factor combined and started siphoning fuel out of the 2nd tank, right up to the top of the main filler cap, once there it either went into the Carbon Canister as liquid not vapour, then out the Canisters's breather, leaking fuel under the vehicle or out when I opened the main cap to check. Meantime the car would splutter as it now dumped raw fuel via the Canister recirculation line to the inlet manifold.
    Needless to say, it scared the crap out of me the first time this happened. Turns out after reading US forums its a fairly common issue there.
    This got solved by plumbing into the carbon filter line as the US guys do, or they add a separate breather outlet for the 2nd tank, I could not find one locally and was in a bit of a hurry.
    The FR copy actually takes 102 L to the neck but on hot days it generates enough vapour to overwhelm the Carbon Canister if you fill it and park. Fine when travelling, otherwise I add about 90L. The main tank still takes about 10 minutes to fill from empty, the 2nd about 5 mins.
    I transfer for about 15 mins when the light goes on and then I have about another 15 mins left for later. You can hear the pump running dry if you pay attention.
    Wynand
    2005 Discovery 3 HSE v8
    2002 Discovery II XS v8 (sold)
    1974 Chev K 25 (julle dink 'n v8 is dors)
    Land Rover - making mechanics from motorists since 1947 and electronic engineers since 1989!
  14. The Following 2 Users Say Thank You to Dr Jones For This Useful Post:
  15. #10
    Brentwood Park
    Thanked: 419
    I had an issue with my Disco when I got it. The aux tank never took more than 40 liters. I just assumed it was small. Tgwinduna had a look and said there was no problem, he checked fuel lines and all that and sent me on my merry way. Whatever he did gave me a heart attack the next time I filled up though because the Landy took 172 liters on board. Not sure who was sweating more, the attendant or myself. Haha. So yes, I would check for airlocks and all that.
  16. The Following User Says Thank You to Chopped For This Useful Post:
  17. #11
    Apr 2019
    Thanked: 444
    Just wanted to make a plug for Overlandworx - just picked up my 2012 D4 with their long range tank. 120 extra liters. Very well done including a wheel carrier.
  18. #12
    Hoedspruit
    Thanked: 89
    Quote Originally Posted by heyyahhey View Post
    Wow that sounds very good. Any pictures of the tank and the wheel carrier?
    Andre
  19. #13
    Apr 2019
    Thanked: 444
    Quote Originally Posted by Fourie110 View Post
    Andre
  20. The Following 2 Users Say Thank You to heyyahhey For This Useful Post:
  21. #14
    Hoedspruit
    Thanked: 89
    That looks really good. Thank you for posting pictures.
  22. #15
    Mar 2012
    Fourways
    Thanked: 434
    Mine is booked for this same Long Range tank in 2 weeks!!! Cant wait to get this baby fitted although I think it will be eye watering to fill it up being and extra 120L
    Rob,
    D4 SDV6 HSE ARB Bullbar, Compos, BFG 265/65R18s, Big Country drawers, National Luna 52L, Dometic 50L, Spare Wheel Carrier, Roof Rack, Hardshell RTT, FR 50" LED Bar, Lift Rods, Mantec Snorkel, C-TEK Dual batt system, 270 Ostrichwing, Maxtrax, TXG Rock Sliders, IIDtool, shelf
