Results 1 to 3 of 3
    Thanked: 16
    Default Shredded water pump
    Hi All
    It's been a while since I posted but I have run into a problem.
    My Defender 300TDI water pump bearing collapsed and I spent the weekend stripping the front and replaced the timing belt while everything was off. (A lot simpler than I thought!)
    Anyway, when I removed the water pump, low and behold, it had no blades on it.
    Luckily I was able to fish them out of the passage behind the water pump largely intact. Unfortunately, the remaining hub on the pump is a bit buggered and I am unable to match up the broken blades with the hub.
    I suspect there are some small bits that managed to escape and are now sitting somewhere in the block. I don't imagine they could have gotten far as the pump ceased being a pump when the blades broke off.
    I know there is a drain plug below the turbo somewhere, would it be possible the bits could be flushed out via this drain?
    Charles
    Defender TDI 110 CSW
    Lift, Long Range Tanks, Dual Battery's, A few Dents and loads of FUN!
    Don't Regret Enjoying Life!!
    Thanked: 17104
    Default Re: Shredded water pump
    I'd try the drain plug, but also remove both radiator hoses and use a high pressure water source to try and dislodge the little pieces.
    Jakes Louw
    Thanked: 16
    Thumbs up Re: Shredded water pump
    Thanks Jelo
    I'll give that a go
    Charles
