Home UPS using camping gadgets
Results 1 to 5 of 5
    Sep 2015
    Thanked: 10
    Default Home UPS using camping gadgets
    Hi All. I have a CTEK MXS10, and two 100 Ah AGM deep cycle batteries. It occurs to me that to keep the Playstation, SmartTV, and DSTV Explora running without damaging hard drives, etc., during our frequent power outages, I could plug these two into an inverter, and run continuously that way as a home-made UPS solution. Off-the-shelf UPSes only last minutes, so donít help the outages during the night. Your thoughts, please?
    Also, must I have a pure sine wave inverter, or will a modified work in this scenario? Many thanks
    Russ
    2012 Land Rover Freelander 2 SD4 SE
    She's not as soft as you'd think!
    Jhb, Lesotho
    Thanked: 100
    Default Re: Home UPS using camping gadgets
    I have this setup running expensive security cameras and wifi equipment, so sure it should work for your application
    Jan
    1988 110 CSW V8
    1961 S2 SWB
    Nov 2008
    Ellisras
    Thanked: 311
    2000 Patrol GU 4.2D(onkey) beyond 825 000 km
    George
    Thanked: 765
    I'd go with a high quality pure sine wave inverter.
    Roodekrans
    Thanked: 127
    @ SerenitySeeker I run my LCD, playstation, DSTV from my modified sine wave inverter during power outages no problem, for years now.
