Trailer jack
Results 1 to 8 of 8
Thread: Trailer jack
    Feb 2008
    Thanked: 26
    Default Trailer jack
    What is the best way to jack up a trailer when you have a puncture or a flat tyre?
    2012 Freelander 2 SD4 SE
    Offtrax Outplay
    May 2016
    Thanked: 2300
    Default Re: Trailer jack
    Put the inflated spare in front of the flat wheel.
    Pull the trailer (with your car) forward so that the flat wheel sits on top of the spare.
    Your vehicle jack will now fit under the trailer's axle.
    2006 VW Touareg V10 TDi
  3. The Following User Says Thank You to 4eTouareg For This Useful Post:
    Aug 2007
    Stellenryk, Bellville
    Thanked: 289
    Invest in a 2-ton hydraulic bottle jack - they fit underneath the axle of your offroad trailer, but will probably not fit underneath a small luggage trailer. I have one in my offroad trailer, used it many times to jack it up to level it.
    2007 Colt Rodeo 3000I V6 D/C 4x4
    Dual battery system
    57 mm freeflow system
    General Grabber AT3's
    Challenger Bundu Basher Off-road trailer aka Bos Parra
    Thanked: 235
    Never unhitch the trailer or caravan when changing a flat .
    A 3 ton hydraulic jack works best.
  6. The Following 2 Users Say Thank You to janseekat For This Useful Post:
    Nigel
    Thanked: 1597
    I huat use the hi-lift jack
    LC 78 Troopie 1HD-FTE
    +27 zero eight 2 four 95 9252
    Thanked: 60
    Most of my trailers have those levelling jacks fitted, so they have their own built in jack. Used a few times to change wheels. Very convenient.
    Apr 2017
    Thanked: 50
    Quote Originally Posted by Gert View Post
    Hi Gert, I have used a product from Roadque called an EASY WHEEZY ALUMINIUM JACK, very safe and simple to use, can be used on round shaft or square shaft axle. I had to change two trailer tyres due to blowouts , a normal bottle jack or car jack is too high to fit beneath the axle when the rim is on the ground,see their website, www.roadque.co.zaregards
    Jun 2007
    EDENVALE
    Thanked: 12
