Maintaining my dual battery
Results 1 to 15 of 15
    Krugersdorp
    Thanked: 24
    Default Maintaining my dual battery
    Hi All,With the current petrol price, I have a little run around for work and back, And now the bakkie is standing at least a week at a time,I saw this Sunday that my second battery is not holding charge, and even main battery goes a bit more flat than usual.So here is the thinking: Get one of these Midas chargers, .8/4 Amp DC Smart Battery ChargerProduct Code: PSA004Category: Battery ChargersBrand: Pro Useradd a brad Harrison plug between main battery and dual battery , and when bakkie is standing, just unplug brad Harrison and plug the charger into the dual battery.Any thoughts on this?
    May 2007
    Thanked: 24
    Default Re: Maintaining my dual battery
    I have a similar problem so interested in any answers.
    My regards
    Mike
    krugersdorp
    Thanked: 231
    adendorf in krugersdorp selling
    https://www.adendorff.co.za/product/...gel-batteries/ R545.00
    mica in rant en dal have one that looks similar to c tech for about same $.
    i have one from adendorff.
  4. The Following User Says Thank You to jadranko For This Useful Post:
    Hillcrest, Malaysia
    Thanked: 4422
    Just connect the PSA to the aux battery. Donít bother disconnection the main battery.
    Depending on your system this may keep both batterie nicely charged.
    ZS5KAD
    3 V8's
  6. The Following User Says Thank You to Fluffy For This Useful Post:
    Sep 2010
    False Bay
    Thanked: 85
    Get Benton BX2 and you will always be smiling with a full battery
    Sam
    ZS1SAM
    V5/ZS1SAM
    HAMNET
    2018 Toyota 2.4 GD6 SRX D/C 4x4 auto
    Land Rover Defender 110 Puma - sold
    Metalian Mini
    May 2017
    Thanked: 269
    I drive around 800km per month unless I have a long trip away - so I connect the charger to my aux battery in the engine bay once a month for 24 hours - would this suffice? The rest of the time it's connected to my battery box and keeps the 3rd battery on charge since it's only used for long trips
    Fiddler
    Hillcrest, Malaysia
    Thanked: 4422
    Quote Originally Posted by EHoffmann View Post
    Let's see if I have this correct.
    Bakkie - main battery
    Bakkie - Aux battery in engine compartment.
    Bakkie/Storage place - 3rd battery in battery box.
    Where does the battery box live, because we now have effectively two aux battery systems.
    ZS5KAD
    3 V8's
    Nov 2006
    Thanked: 344
    "Get Benton BX2..."
    Sorry but my Bentons packed up one after the other (number 5 just the other day) and I wont touch them again.
    Spend your money wisely.
    Sep 2016
    Boksburg
    Thanked: 82
    Just a question. Why connect to the aux battery and not the crank battery? I would have thought connecting the charger to the crank battery will charge it first and then the normal dc/dc system will kick in and charge the aux battery as if the power comes from the alternator.
    Alfa 159 - die dors ene, met 6 silinders
    Fiat 500c - SWAMBO se pink'e met 'n swart pruik, en make-up
    VW T5 4Motion - cause there ain't no Italian 4x4 kombies
    May 2017
    Thanked: 269
    Prado engine bay - Starter battery
    Prado engine bay - 2nd crank battery with NL solonoid
    Battery box with AGM goes behind the front passanger seat, in the foot-hold. (that is removed from the car and only put in the Prado when I do a long trip) with WRND and takes my solar.
    I got the battery box before I got the Prado - and the Prado came with 2 engine bay batteries. Brand new solonoid and battery, so a waste to remove I imagine.
    so the 2nd battery is the one I charge once a month with the charger- and the question is - is once a month sufficient?
    Fiddler
  13. #11
    Sep 2010
    False Bay
    Thanked: 85
    Quote Originally Posted by Damdan View Post
    "Get Benton BX2..."
    I have a BX-1 and BX - 2. Have had them for 7 years and they are both in continuous use. BX- 1 on my workbench and the other in my vehicle. The BX - 2 is essentially on all the time as I only use my vehicle for trips and the occasional local trip. Never had a moments hassle
    Sam
    ZS1SAM
    V5/ZS1SAM
    HAMNET
    Metalian Mini
  14. #12
    Jan 2008
    Bethlehem
    Thanked: 70
    I have a Benton BX2 connected to my cruiser, at times it stands more than a month, I just connect to main battery and it keeps both main and aux batteries full, never had a problem with the BX2 or BX1 for that matter - BX1 now 10 years old and still going strong
    Christo Davids
    Land Cruiser 105 4500 EFI
    Hilux 2.8GD6 Extracab 4x4
  15. #13
    Mossel Bay
    Thanked: 47
    Quote Originally Posted by Christo Davids View Post
    My BX1 also now running for 10 years.
  16. #14
    Nov 2006
    Thanked: 344
    Dont know why I have a problem then with the BX2's then.
    Bought BX1's from a forum member not too long ago so they are newish and working ok.
    But the BX2's have all packed up.
    Am now trying out my new 20amp Victron blue smart and all is good so far.
  17. #15
    Krugersdorp
    Thanked: 24
    Quote Originally Posted by jadranko View Post
    adendorf in krugersdorp selling https://www.adendorff.co.za/product/...gel-batteries/ R545.00mica in rant en dal have one that looks similar to c tech for about same $.i have one from adendorff.
    I went and bought one of these at Adendorfs on Saturday, read the spec's and manual thats available online and it seemed to fit my requirement perfectly. only managed to connect it onmmm Monday evening, and it working like a charm.BUT, when I checked on Tuesday morning no lights where showing in the unit and it had teh distinct smell of blown electronic component, So will have to take it back.
