Radio Flyer DIY Wagon
Results 1 to 13 of 13
    Mar 2012
    Thanked: 274
    Default Radio Flyer DIY Wagon
    So I thought I'll quickly do a DIY kiddies wagon thread.
    It was my sons 2nd bday this weekend and he had a plastic wagon that was getting a bit small for him. Seeing that I was always amused by these American Radio Flyer wagons that they use to strap to the roof of the Beetle's I thought why not build him a bigger one.
    So here it goes.
    This is what I saw on the Radio Flyer Website
    This is the design that I came up with, using std wood sizes.
    Honda Civic Type R
    - Daily Drive
    IsuzuKB 250 DMAX - Swambo
    Mar 2012
    Thanked: 274
    Default Re: Radio Flyer DIY Wagon
    So I went to the local Builders that I hate, but anyway, I don't have time to go the proper wood merchants.
    Stock
    Started Cutting Pieces
    Made the handle from copper tube. I actually saw somebody on the web that did this and thought that's pretty cool.
    Honda Civic Type R
    - Daily Drive
    Mar 2012
    Thanked: 274
    More pieces cut and mock-up assembly.
    Other side of handle, sealed.
ID:	501522Click image for larger version.
ID:	501523Click image for larger version.
    More pieces cut and mock-up.
    Honda Civic Type R
    - Daily Drive
    Mar 2012
    Thanked: 274
    Sprayed the tube, Sanded, Sealed the wood and dummy assembled the first axle.
    Second axle assembly started.
    Still need to put end stops on both sides of the wheels.
    Honda Civic Type R
    - Daily Drive
    Mar 2012
    Thanked: 274
    Thought I would play a bit and engrave his nickname on the side of the wagon.
    Glued and clamped mock-up
    Some final sanding
    Final color spray, and ready for sealer and rear axle fitment.
    Honda Civic Type R
    - Daily Drive
  6. The Following 3 Users Say Thank You to ViperR For This Useful Post:
    Mar 2012
    Thanked: 274
ID:	501679Click image for larger version.
    First and second coat of sealer done.
    Added a plywood spacer to the rear wheel assembly to make up for the height of the front swivel part.
    Front assembly mock-up, without the steering beam.
    Got this swivel from Gelmar, so I'll see how that holds up.
    Honda Civic Type R
    - Daily Drive
  8. The Following User Says Thank You to ViperR For This Useful Post:
    Dec 2010
    Meyerton
    Thanked: 91
    Viper, what is the dimensions of that swivel?
    I am planning a Murphy bed, and on the websites they show this for the pivot point.
    Ford Ranger 2.2 Supercab
    Suzuki Jimny -SWAMBO
    Merida 29'r for fun and pain.
    Mar 2012
    Thanked: 274
    Quote Originally Posted by leonoost View Post
    It's 76x76, they also have a 150x150
    Honda Civic Type R
    - Daily Drive
  11. The Following User Says Thank You to ViperR For This Useful Post:
  12. #9
    Mar 2012
    Thanked: 274
    Dummy Mock-up again
    Swivel work, getting checked.
ID:	502077Click image for larger version.
    Working on the Handle location.
    Structural Test - passed.
    Honda Civic Type R
    - Daily Drive
  13. #10
    May 2016
    Thanked: 2360
    Well done!
    There is more value in that wagon than anything you can buy!
    (It is measured in love, not rands)
    2006 VW Touareg V10 TDi
  14. The Following User Says Thank You to 4eTouareg For This Useful Post:
  15. #11
    Mar 2012
    Thanked: 274
ID:	502081Click image for larger version.
    Final product
    Next - need to get approval from mini me.
    - Still need to make the cattle rails.
    Honda Civic Type R
    - Daily Drive
  16. The Following User Says Thank You to ViperR For This Useful Post:
  17. #12
    Jhb, Lesotho
    Thanked: 108
    Really really nice. Love the copper pipe idea.
    Jan
    1988 110 CSW V8
    1961 S2 SWB
  18. #13
    Mar 2012
    Thanked: 274
    The Manager did a quality check. He was not happy with this swivel It only lasted about 30min.
    The problem is that he sheet metal is so thin that when he pushes or pulls the wagon the plate starts flexing. Eventually the bearing started to fall out.
    So not being a huge problem, I made a plan now we have this.
    M12 Carriage bolt with two oversized washers and a nyloc nut.
    He'll definitely won't break this swivel. I was initially a bit worried that it will be a bid too hard to turn but actually it work pretty well. I just put a bit of grease between the two washers.
    Honda Civic Type R
    - Daily Drive
