DC-DC Charger Comparison - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 56 of 56
  1. #41
    Feb 2016
    Thanked: 606
    Default DC-DC Charger Comparison
    OK, but:
    At least 25 of the 40odd posts in this thread mentions (or the comments are linked to) DC-DC that has solar input
    Ok, but:
    On the list there is a Solar MPPT option. In other words the list caters for chargers with AND without MPPT.
    Not everyone wants to lug around the extra solar panels, some people just want something that can replace their ancient solenoid system
  2. #42
    Thanked: 605
    Default Re: DC-DC Charger Comparison
    If buying one now, I think it would be worth to get one that is LifePO4 capable. Very soon that will be the battery standard.
    I've got a HCDP 12V 12A Dual Purpose DC to DC Charger DCDC12A tha tI'm looking to replace now for this reason.
  3. #43
    Ellisras
    Thanked: 441
    Yep.
    Which MPPT would you recommend to add to the Orion Tr Smart if one needs Pv input
    2000 Patrol GU 4.2D(onkey) old and wise at 844 000 km
    2014 Patrol GU 3.0CRD reaching puberty at 103 000 km
  4. #44
    Feb 2016
    Thanked: 606
    Yep.
    Victron SmartSolar 100/20. Thatís actually all I currently have (yes only charging from solar, not alternator) still considering if I really need to add the orion.
    (Yes I threw out my Projecta 25 since my first post on this thread, it fried my primary battery)
  5. #45
    Ellisras
    Thanked: 441
    Careful
    The HcdP 12V 12A is actually a constant voltage charger,
    Meaning it delivers a max of 12A until the battery takes virtually no more current at 14.2V
    NOW - That is exactly what you want to feed the BMS of a LifePO4 - you do not need to change.
    But - LifePO4 batteries can accept a lot of current, so remaining with the 12A unit only limits your rate of charge vs what the battery can take.
    A trick solution is to add another HcdP 12A unit in parallel to your existing one. Bingo : you then have 24A LifePO4 ready DC-DC charger for R2000 + you can add some more solar panels.
  6. #46
    Mossel Bay
    Thanked: 67
    Don't you think lead-carbon batteries pricewise @ R3000 /100A/h is a better cheaper option and you can charge it with a normal DC-DC
    2017 Hilux 2.4 SRX D/C 4x4 2012 Cross Polo [mamma s'n]
    http://travel.webshots.com/album/558867451ncpSPZ
  7. #47
    Thanked: 605
    Careful
    Wow, that is excellent info. No-one tells you that. Thank you. Are LifePO4's happy with 14.2 v max charge, I believe they need a bit more than that?
  8. #48
    Thanked: 605
    Quote Originally Posted by Lofty View Post
    Well yes, because the price of LifePo4 has come down and you can use nearly all of the battery at near constant voltage without damaging it.
    A 100AH lead whatever, you should only deplete 30% to preserve the battery, so effectively you only have a 30AH battery, perhaps 40AH if you push it.
    An equivalent LifePo4 gives you say 90AH of usable capacity. Triple that of the lead unit.
    A 120AH Lifepo4 can be had for around R 6000.00 these days, that's 4 times the capacity for double the price and a much longer theoretical life (which remains to be seen). hence if you buy a DC DC charger now, make sure it will work with LifePo4, even if you don't have such a battery yet. Your next one after this one will almost certianly be a LifePo4.
    Good news, as per the previous post, is that the basic HCDP unit I have seems to be LifePo4 suitable.
  9. #49
    Feb 2017
    Santa Cruz, CA
    Thanked: 184
    I noticed that National Luna now offers a 40 Amp DC-DC charger. Is this for the same application with just more amps, or is this intended for some specific application that isn't obvious to me? It would be great to get feedback from someone that has one.
  10. #50
    Ellisras
    Thanked: 441
    14.2V is just enough. More is better but not critical as the LiFePO4 BMS will deal with the cell balancing
  11. #51
    Oct 2007
    Quote Originally Posted by CalDriver View Post
    The 40 amp National Luna is more or less the same. It has one additional DC input (over and above the solar and alternator inputs of the 25 amp model ). The remote monitor also now ships with slightly improved firmware.
    1997 Suzuki Samurai (Coily)
    1.5 inch spring lift
    30x9.5 BFG KM2 muds
    4.16 RockLobster
    2017 Ford Ranger Wildtrak 4x4
  12. #52
    Thanked: 605
    Thnx. So perhaps will not quite get to 100% charge. 90 or 95% will do for me, just hope it does not damage the battery.
  13. #53
    Ellisras
    Thanked: 441
    Will get to 100% - just takes longer
    Any decent LiFePO4 12V system ready battery will have a proper BMS to manage and protect the battery...
    FongYongKoo and home built Litium packs with elcheapo BMS might pose a problem.....
  14. #54
    Thanked: 605
    Thank you for the info Dungbeetle!
  15. #55
    Lonehill (JHB)
    Thanked: 19
    Where did you see this?
    2014 Ford Ranger 3.2 XLT 4x4 D/C Auto
    2018 Ford Everest 2.2 XLS 2x4 auto (SWAMBO)
  16. #56
    Thanked: 605
    Here:
    https://lithiumbatteriessa.co.za
    Out of stock currently though.
