Strange and sudden tyre wear
Results 1 to 11 of 11
    Mar 2011
    Boksburg
    Thanked: 51
    Default Strange and sudden tyre wear
    Colleague of mine drives a ford d cab. His front tires look like the attached photos. What would cause this. The left front is worse with large chunks on the tyre surface torn off. Thanks
    2011 Amarok TDI D/Cab 4x2
    2001 Isuzu KB 320 V6 D/Cab 4x2
    DISCLAIMER: I'm not an expert in the subject posted about above, i'm a member of an internet forum only and my comments, advise, suggestions and ideas should be taken from that point of view
    Cape Town or Jansenville or missing...
    Thanked: 3060
    Default Re: Strange and sudden tyre wear
    What tyres are those?
    That looks like rough gravel use wear and tear.
    Wilderness
    Thanked: 912
    The toe, caster or camber is set wrong.
    The cause of this can be many things. Wear on steering components, wear on suspension components, bumping into curb, driving over the sidewalk suspension modsetc. Take it in for a check and alignment.
    2011 Isuzu 300d-teq 4x4 d/c
    Wilderness
    Thanked: 912
    The toe, caster or camber is set wrong.<br>The cause of this can be many things. Wear on steering components, wear on suspension components, bumping into curb, driving over the sidewalk&nbsp; suspension mods etc. Take it in for a check and alignment.
    Malawi
    Thanked: 622
    Quote Originally Posted by Johan Slabbert View Post
    I think they are Bridgestone Dueler...
    Thanked: 3060
    Quote Originally Posted by tashtego9 View Post
    Thought so too. Unless it's an alignment issue, it seems some surfaces chew up the Duellers.
    My 2013 Fortuner came with these OEM, 23000km on bad gravel and they looked like that but far worse. Bridgestone said abuse and pulled up shoulders. I said okay and voted with my wallet, and I still do
    The Hankook replacements lasted 80 000km on the same vehicle.
    Dec 2010
    Thanked: 92
    Pieter is right this is an alignment issue. Most probably a mixture of camber and toe. I have seen similar issue on my lifted GV where camber chows tyres if I don't rotate often enough especially left front
    Itís a general problem on Ford Rangers with the factory Continentals to have this problem with the degradation of the tyres.
    I did wheel alignment, tyre rotation etc and the problem just got worse. Chunks of rubber just break off.
    Ford does nothing about the problem and Continental even less.
    There are many other threads on this exact issue assuming that this is a Ford Ranger with Continentals
    Jun 2017
    Thanked: 54
    Quote Originally Posted by Therackermann View Post
    Thought it was the Goodyears? Is it both?
    Suzuki Jimny 2017
    Radical cups
    Steering damper
    Front Runner roof rack
    Floor board
    Feb 2015
    Thanked: 42
    Looks the almost the same as my continental lx front tyres. And this specific tyres look like continental crosscontact AT.
    I thought mine were due to over inflation and bad gravel roads. Atleast that is what they say is a possible cause in one of the SA4X4s which detailed tyre wear and most common causes.
    2006 Ford Ranger 4000 V6 - Sold
    1990 Honda Ballade 160i - Sold
    2016 Ford Ranger 2.2 XL 4x4 double cab
    Built Ford Tough.
    Jul 2010
    Bellville
    Thanked: 25
    Too low tire pressure?
