Results 1 to 19 of 19
    Jul 2018
    Thanked: 28
    Default Freelander 2 Cracked hose
    So I think that I've been experiencing intermittent turbo boost loss when my freelander 2 (2007 hse 2.2 td4) reaches normal operating temperature. After a bit of internet searching I ended up cleaning the maf and map sensors (both dirty, esp the map) and then proceeded to check all the hoses I could find (I don't even know where to locate the turbo). I ended up finding a huge crack in the hose in the picture. I'm not sure if it goes all the way through but I would think it needs to be replaced.
    Anyone know what hose this is and can I manage to replace it on my own (I can follow a youtube video, that's about the extent of my expertise) or would I need to take it to a mechanic?
    Thanks in advance.
ID:	501019   Click image for larger version.
ID:	501020   Click image for larger version.
    Jul 2016
    cape town
    Thanked: 123
    Default Re: Freelander 2 Cracked hose
    Quote Originally Posted by RJay View Post
    Thanks in advance.
    Hi,i think it should be D.I.Y,that split is causing the boost leak.the peeps should be coming around soon to add/give their advice.
    Regards.
    Currently(Katryn) 2011 FL2 SD4 stock
    K6 GSXR750 (With all the BAZZAZ goodies)
    EX: 2012 Mazda CX7 Individual 2.3disi (sold)
    2010 Mazda 3 Sport Dynamic (sold)
    2004 VW 1.9Tdi (sold)
    2007 Fiat Strada (sold)
    (Thandi) K7 gsxr600 (wrecked)
  3. The Following User Says Thank You to dieselwa For This Useful Post:
    Jul 2018
    Thanked: 28
    I love Google and YouTube. Anyone else wondering what that hose is, it's the intercooler hose and supposedly easy to replace. We will see about that!
    https://youtu.be/8m812JMMQbU
    Now to source the hose....
  5. The Following User Says Thank You to RJay For This Useful Post:
    Jul 2016
    cape town
    Thanked: 123
    Google and youtubeshowed me how to change timingbelt,waterpump and tensioner
    Jul 2016
    cape town
    Thanked: 123
    I think flat four racing will have silicone boost pipes
    Jul 2018
    Thanked: 28
    Thanks. I'll give them a call tomorrow.
    Boksburg
    Thanked: 18
    I replaced the same hose yesterday, bought it at Volkspares in Boksburg for R300.
    Just had to cut it to size.
    It's 57mm diameter and 11.5cm long.
    Took me about 30mins because the clamp screws are in a bad place to reach.
  10. The Following 2 Users Say Thank You to cobusf For This Useful Post:
  11. #8
    Jul 2018
    Thanked: 28
    Thats amazing!!! I just got quoted R1452,66 excl VAT from LR.
    Ill ty some generic spare shops around Cape Town for the silicone hose.
  12. #9
    Boksburg
    Thanked: 18
    If you were not that far away you could have the spare piece I have.
    They only had a larger one that I modified...
  13. #10
    Boksburg
    Thanked: 18
    Maybe try Flat Four Racing in Cape town, they are part of the Volkspares parts group
    Sorry I see someone posted them already...
    Last edited by cobusf; 2018/09/05 at 10:42 AM. Reason: Sorry it was already posted
  14. The Following User Says Thank You to cobusf For This Useful Post:
  15. #11
    Jul 2018
    Thanked: 28
    Gave them a call but didnt know the size. I do now. Thanks guys. Ill try and find someplace a little closer to work (newlands), but if not ill have to drive out to them.
  16. The Following User Says Thank You to RJay For This Useful Post:
  17. #12
    Pretoria North, Patryshoek
    Thanked: 3272
    The 100vx also has a boost pipe with a latent defect. It cracks on a seam and looses boost.
    I have a polyurithane mix that cures to the shore hardness of an engine mounting. We use it for suspention bushes.
    Then I take bandage, drench it in this and wrap that pipe. No problem, ever again.
    +27 zero eight 2 four 95 9252
  18. The Following User Says Thank You to Henris For This Useful Post:
  19. #13
    Jul 2018
    Thanked: 28
    Had it sorted this morning. Supply and fit for R350-00.
  20. The Following 2 Users Say Thank You to RJay For This Useful Post:
  21. #14
    MTUNZINI
    Thanked: 1369
    Quote Originally Posted by cobusf View Post
    That 57 mm is it OD or ID
    Koos Best
    Land Rover Discovery3 TDV6 S.
    VW T6 D/cab 4 Motion with slide on camper
  22. #15
    Boksburg
    Thanked: 18
    Quote Originally Posted by Koos Best View Post
    Let me check tomorrow morning, still have a piece left. Then I'll let you know.
  23. The Following User Says Thank You to cobusf For This Useful Post:
  24. #16
    MTUNZINI
    Thanked: 1369
    Hi , will be much appreciated
    Koos Best
  25. #17
    Boksburg
    Thanked: 18
    Hi Koos, the ID is 57mm
  26. The Following User Says Thank You to cobusf For This Useful Post:
  27. #18
    Oct 2019
    Would you mind telling me where the MAP sensor is located, im having the same issues with my FL2
  28. #19
    Goodwood
    Hi there RJay - i know you had this done last year - but where did you take it?
    Quinton
    1995 Discovery I V8 (sold)
    1998 Discovery I Tdi (sold)
    2001 Discovery II Td5 "Helga"(sold )
    Discovery 3/4 Tdv6 HSE (wish list)
    Current - 2007 Freelander 2 Td4 HSE
