Results 1 to 18 of 18
    Bellville
    Thanked: 241
    Default Pajero Gen 4 spotlights without bull-bar
    Hi
    I am looking to install spots on my 2011 Pajero, but does not want to install a bull-bar. Anyone here installed a set of decent (LED) spotlights on the Gen 4 using a custom bracket? As one would need lightweight but robust items, which lights did you choose and why? Where did you buy the bracket or who made it for you?
    Are number plate style brackets sufficient for such light items?
    If in Cape Town, who did the installation and wiring for you?
    Cost?
    2011 Pajero 3.8 GLS LWB
    Thanked: 464
    Default Re: Pajero Gen 4 spotlights without bull-bar
    I can't recall ever seeing spots on a Pajero's stock bumper, but I have seen a lightbar installed behind the bumper, below the number plate. That might be worth looking into?
    Iwan
    2007 Mitsubishi Pajero 3.2DiD SWB (Gen4)
    2001 Mitsubishi Colt Rodeo 2.8TD D/C 4x4 (sold)
    Bellville
    Thanked: 241
    Guys are doing it often in Aussie land, e.g. using number plate bars. But OK, then I am on pioneering stuff here. Will let you guys know!
    Light bar not my favourite, so will keep on looking for lightweight spots.
    Magaliesburg
    Thanked: 16
    Quote Originally Posted by Ouarzazate View Post
    I’ve also had preference to the idea of not having a nudge bar with the lights mounted on it. I’ll be interested in how you eventually do it.
    2018 Mitsubishi Triton Extreme Auto
    Barberton
    Thanked: 3674
    Hi
    Cost?
    I have only ever mounted spots on a car on two occasions, in 1983 on a VW Passat and in 1991 on a Nissan Sani. Both installations I selected a strong "body beam" behind the grill and mounted flatbar brackets onto it. The brackets would then push through the grill and the spots can be mounted on them.
    I don't have a Pajero anymore to check, but I'm pretty sure there are a few such beams to choose from.
    Southampton
    Thanked: 276
    What about one of these?
    2015 Pajero Sport 4x4
    1996 3.5v6 Pajero (For Sale)
    Carpe Diem Scrotum
    Bellville
    Thanked: 241
    Exactly what I was talking about, but I am not convinced that it will not vibrate. Also don't like the space between the mounting plate and the new position of the number plate. Also, the little tube thingy not needed if the spots are thin enough. Will probably have something fabricated that connects onto the number plate mountings but then goes backwards to actually rest on the bumper, with some rubber in between, and maybe some flat metal strips into the grill to connect onto some rigid supports in there.
    Thanked: 2825
    Have the same issue with my Triton, still waiting to see if someone comes up with a solution or if I see a vehicle with non-nudgebar mounted spots
    Aug 2018
    Durban North
    Thanked: 60
    Reviving an old thread
    Has anyone successfully put spotlights on there Gen 4 without a bull bar or nudge bar? If so please show me.
  10. The Following User Says Thank You to SimonV For This Useful Post:
    Mar 2021
    Hartebeespoort Dam
    Thanked: 74
    Quote Originally Posted by SimonV View Post
    Howsit Simon
    Have you checked for any mounting spots to make your own brackets ? We have a 2017 Gen 4 SWB pajero with a nudge bar and the led bar is on there, i can have a look for you to see if there are any possible spots for said brackets
  12. The Following User Says Thank You to Thomas Corben For This Useful Post:
  13. #11
    Mar 2013
    Thanked: 514
ID:	632032 Click image for larger version.
    Also contemplated spots but the Pajeros lights are actually really good. I would just have a look behind the grill and bend some flat bar to the desired position where there are existing holes.
    Pieter Greyling
    Of all the paths you take in life make sure a few of them are dirt-John Muir
    ORRA: Z85
    -Pajero SWB 3.8 V6
    -BMW F800GS
  14. The Following User Says Thank You to pjf110 For This Useful Post:
  15. #12
    Aug 2018
    Durban North
    Thanked: 60
    Quote Originally Posted by pjf110 View Post
    Thanks. I have been contemplating putting them on like in the first pic you attached, just worried about damage to the bumper and vibration.
  16. #13
    Johannesburg/Prague
    Thanked: 169
    Thats fixing them to the plastic 'bumper' will work and should not vibrate as the fog lights are also attached to this plastic 'bumper' perhaps put a steel plate to reinforce , but you will have to drill into this lovely plastic
    Pajero 3.2 DID Gen 4 Standard for now
    Platcar Alfa Giulietta 1.4 MA
    Swambo Volvo S40 T5
  17. The Following User Says Thank You to 12richardk For This Useful Post:
  18. #14
    Aug 2018
    Durban North
    Thanked: 60
    Quote Originally Posted by 12richardk View Post
    I have thought about this, and have some metal plates i can use to reinforce it, but the thought of drilling holes into the bumper gives me hives
  19. #15
    Johannesburg/Prague
    Thanked: 169
    There are lots of plugs available to cover the holes if you ever remove them and look ok , I would use thin double sided tape to prevent the bracket scratching the paint and a long plate between the the 2 spots from under , when you drill the holes in the plastic place some tape over the surface for a clean hole . If you need the extra lights then it should be all good ,I thing the lights for normal use are pretty good
    Swambo Volvo S40 T5
  20. The Following User Says Thank You to 12richardk For This Useful Post:
  21. #16
    Aug 2018
    Durban North
    Thanked: 60
    Can all you clever pajero owners tell me if this is a connector I can use to connect Spot lights up to?
    This is behind the front grill that I have removed.
    Thanks.
ID:	633146   Click image for larger version.
  22. #17
    Johannesburg/Prague
    Thanked: 169
    Put Your bright lights on and see if there is power on high beam , or low beam , if high then its for spots , if low does have no power then great its for spots , but if power all the time then for something else and you will have to change a few things , worth a try , I have never seen this plug but then I did not look!
    Swambo Volvo S40 T5
  23. #18
    Nelspruit, Mpumalanga, South Africa
    Thanked: 45
    <sub>
