Puma 2.4 Volume Control Valve
Results 1 to 15 of 15
    Apr 2012
    Northriding
    Thanked: 16
    Default Puma 2.4 Volume Control Valve
    Does anyone know where I can get one of these valves locally besides the agents? It is the fuel metering valve on the injector pump. The agents want a ridiculous price for it. I have tried all the normal Land Rover parts suppliers (Dover, British, LP4A etc) but they don't stock it.
    1997 Defender Tdi
    2010 Defender Puma
    Thanked: 12965
    Default Re: Puma 2.4 Volume Control Valve
    Try Ford. Ask for the Suction Control Valve. Should be the same.
    Feb 2016
    Thanked: 720
    +1 it's the same part, usually cheaper at Ford
    Aug 2017
    Thanked: 275
    From lots of reading, a lot of guys has swopped their VCV thinking its at fault.
    Also note, that you will need to do pilot learn after replacing.
    Like Jelo say, ask ford, part number 6C1Q-9358-AB.
  5. The Following User Says Thank You to Jakkals. For This Useful Post:
    Apr 2012
    Northriding
    Thanked: 16
    Thanks for the suggestions. I went to Action Ford this afternoon and they do not have that part number in their system. Have a similar one but it is for the 2.2 Ranger engine and the connection does not look the same. I may have to source it from the UK.
    1997 Defender Tdi
    2010 Defender Puma
    Fourways Gardens
    Thanked: 634
    You can get one from the UK from little over half local price if i recall correctly.
    Series III 88"
    Scout Nomad
    Apr 2012
    Northriding
    Thanked: 16
    Some feedback on this issue.I ordered the valve from Diesel Parts Direct in the UK which cost 70 GBP including shipping and took a chance with our postal system. It took 3 months but did finally get here. It is the original Denso valve but comes in a Nissan box with part number A6860-VM09A. It made a big difference to the running of the engine especially at lower throttle settings. The fuel rail pressure is much more stable than before and no hunting when idling. I will have to wait for colder weather to see if it has solved the problem of cutting out on cold start but think it will have. May be interesting to see if it is obtainable from Nissan locally and what it costs.
    1997 Defender Tdi
    2010 Defender Puma
  9. The Following 3 Users Say Thank You to AlanW For This Useful Post:
    Thanked: 218
    Did this Resolve your issue?
    My 130 went into the power loss mode yesterday and this morning (like fuel starvation or no boost)
    Restart engine and issue gone... so thinking the VCV could be the culprit...or fuel pressure sensor..
    Apr 2012
    Northriding
    Thanked: 16
    Yes it definitely solved the problem. Was worse in cold weather and no trouble this winter. No fault codes are registered but if you monitor the fuel rail pressure it is very erratic.
    1997 Defender Tdi
    2010 Defender Puma
    Thanked: 218
    Quote Originally Posted by AlanW View Post
    cool, I setup my Ultra gauge to read the following:
    -fuel rail press
    -coolant temp
    -boost press
    -intake manifold press
    so will monitor the rail when idling etc.. thanks
  13. #11
    Thanked: 218
    so yesterday afternoon, within 100m boost dropped and wont go over 5psi, restart, all good, 3km, same-repeat.
    Drive the clappers out of it, all good.
    The map pressure and rail pressure was pretty stable, only boost dropped.so either actuator or sensors.
    Cleaned the MAF and MAP (they weren't dirty as the truck had a major service in April)
    This morning I drove her little harder than usual, all seems fine and no issues for the 20km..
    Lets see
  14. The Following User Says Thank You to D-tox For This Useful Post:
  15. #12
    Fourways Gardens
    Thanked: 634
    Hi Alan,
    What symptoms did you have exactly? Did this sort it out eventually?
    Claude
    Series III 88"
    Scout Nomad
  16. #13
    Apr 2012
    Northriding
    Thanked: 16
    Claude in colder weather it would run very roughly and often cut out for the first few minutes after starting. At idle I could also hear the revs hunting as the ECU tried to compensate for erratic fuel rail pressure. After installing the new unit there was an immediate improvement in low throttle behavior and no more cold start problems. It definitely was the source of my problems. It not complicated to replace, just very fiddly.
    1997 Defender Tdi
    2010 Defender Puma
  17. The Following User Says Thank You to AlanW For This Useful Post:
  18. #14
    Feb 2016
    Thanked: 720
    Yep, I also had the exact same symptoms which started in winter a couple of years ago.
    Replacing the VCV sorted this out, but remember, you will have to do a pilot correction and a pump re-learn after you change the valve, so you will need a GAP tool or go to a dealer/workshop.
  19. The Following User Says Thank You to Orxy For This Useful Post:
  20. #15
    Jun 2007
    Gillitts Durban
    Thanked: 47
    I can also confirmed the above. Mine also started with erratic idling, sometimes hunting when coasting at a set speed and the few times I went above 3000rpm - a slight starvation. Odo at the time = 160k km. Bought the VCV unit at LP4A Pinetown (LR009837) Denso unit for R2400. After installing it, I took it to Land Rover for a pump re-learn exercise. All issues was immediately solved and the 2.4 as smooth as a Swiss clock.
    1997 Land Rover Defender 90 CSW TDI
    2010 Land Rover Defender 110 CSW Puma
    Echo 4 Off Road Trailer
  21. The Following User Says Thank You to Bernard Burger For This Useful Post:
