Home Made
Results 1 to 10 of 10
Thread: Home Made
    Jun 2013
    Springs
    Thanked: 11
    Default Home Made
    Made this for a buddie of mine for his birthday. What a mission to cut the corners with a Dremel, but got it done in the end. The Jameson bottle was only used for sizing. Will put Brannas in it. Click image for larger version.
ID:	499534Click image for larger version.
ID:	499535Click image for larger version.
  2. The Following 2 Users Say Thank You to Tazz123 For This Useful Post:
    Dec 2012
    Slaapstad
    Thanked: 51
    Default Re: Home Made
    Nice, next time use a hole saw to cut the corners out and then just connect with a grinder.
    Jun 2013
    Springs
    Thanked: 11
    Quote Originally Posted by Boksie View Post
    This bottle was about 4mm thick, will a holesaw be able to drill that?
    Langs die rivier, op n berg
    Thanked: 2295
    Ja
    Dec 2012
    Slaapstad
    Thanked: 51
    The cheap wood type ones you buy at most hardware stores won't, but you get bi-metal ones at some stores that would and any HSS would also cut the holes.
    If you go to a hardware shop that sells electrical stuff they sometimes also sell a hole saw for making extra holes in DB boxes, these are cheaply available and would also cut that like butter.
    edenvale
    Thanked: 199
    as long as its not a cheapy, drill pilot hole first
    durban
    Thanked: 639
    With the correct speed and feed and pressure and coolant .Yes. It is also quite easy to resharpen a hole saw if you know how.
  9. The Following User Says Thank You to plunger For This Useful Post:
    Thanked: 8110
    The cheap wood type ones you buy at most hardware stores won't.
    too true
    Tried to cut a stainless pot with one once..........let's just say the pot won.
    Ela Diablo: Land Rover S2A 109 PUP: SOLD
    Jun 2013
    Springs
    Thanked: 11
    Thanks guys
    Dec 2014
    Thanked: 1295
    These are excellent cutters. I have a set of small diameter ones and they are top class.
    http://www.rotabroach.co.uk/cutters/
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  13. The Following 2 Users Say Thank You to JohnnoK For This Useful Post:
