Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 65
    Apr 2014
    Richards Bay
    Thanked: 116
    Default Engine conversion: Forward Control
    Calling on forum experience!!!
    My father has bought himself a forward control 2b that he plans on using for over landing.
    The very first thing he did was drop the leyland 2.6... at 25l/100km and only 67kw it was never going to be feasible.
    So what engine and gearbox combo?
    His requirements
    Something simple i.e. no computers, Diesel and reasonable fuel consumption.
    The chassis rails are 630mm apart. Length shouldn't be much of a problem.
    He has access to a small boiler shop, so fabrication shouldn't be an issue.
    1985 Land Rover 110 - 300tdi conversion
    It's always more fun on the road less travelled
  2. The Following User Says Thank You to iLandy For This Useful Post:
    Apr 2014
    Richards Bay
    Thanked: 116
    Default Re: Engine conversion: Forward Control
    The long weekend carnage.
    Engine, gearbox, front diff and firewall removed.
  4. The Following User Says Thank You to iLandy For This Useful Post:
  5. #3
    West Rand
    Investigate a Toyota 2L (2.4 Diesel) fitted with a Garret Turbo. You can get a adaptor plate to fit this engine to the existing Landy Gear box from Gilo engineering in Booysens in the South Of Johannesburg. You can Google them. doing a Turbo conversion on these engines is very easy.....
    Apr 2014
    Richards Bay
    Thanked: 116
    Looking at something like a
    nissan QD32T or TD27Ti
    Isuzu 4JG2
    Merc OM603 - not easy to find one with low mileage.
    GMC 6.2 V8 diesel
    need some other recommendations
    Mar 2015
    New Germany
    Thanked: 912
    Quote Originally Posted by iLandy View Post
    Isuzu 4JG2
    GMC 6.2 V8 diesel
    What about a 300TDi with a VGT Turbo the VGT turbo makes a huge diffrance R380 and then you can use a LT230 so no need for adaptor plates
    The only prob there would be weight of the forward control to much for the 300TDi
    2005 Defender TD5
    Thanked: 17104
    Isuzu 4JG2
    GMC 6.2 V8 diesel
    all good choices except for the GMC which is a huge pig of an engine
    also: Ford WL25, Isuzu 4JB1-T
    STAY AWAY FROM THE TOYOTA 2L (sorry Moeras, but they were garbage engines).
    Jakes Louw
    Thanked: 17104
    The FC2B isn't that heavy. 2050kg.
    Jakes Louw
    May 2016
    Thanked: 3996
    Isuzu 280 DT
    2006 VW Touareg V10 (Sold)
    King Williams Town
    Thanked: 1902
    Isuzu 4JG2
    GMC 6.2 V8 diesel
    Imho and not a mechanic. But if I was to travel Africa,I would look for a simple engine that is common in all of Africa,something that does not need a special octane of fuel to run it.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Thanked: 17104
    none of those do
    most of them will run on Waste Veg Oil or even paraffin
    Jakes Louw
  13. #11
    Robertson/ Larissa, Greece
    Thanked: 4858
    You don't have a clue what you're talking about!
  14. #12
    Thanked: 17104
    OK if you say so.
    Jakes Louw
  15. #13
    PRETORIA
    Thanked: 42
    Quote Originally Posted by Moeras View Post
    What will the outputs be of this turbo 2.4 toyota diesel engine?
    Will it be reliable?
    FOTON TUNLAND 4X4 LUX
  16. #14
    Thanked: 17104
    Quote Originally Posted by UITZICHT View Post
    63 to 68 kW gross at 4,000 rpm with 188 N⋅m gross of torque at 2,200 rpm
    too small for the FC2B
    and no, the Turbo version had a reputation for always overheating
    Jakes Louw
  17. #15
    cape Town - 0624206806
    Thanked: 522
    6,5 GMC on an R380 box....going in my 101Click image for larger version.
ID:	498579Click image for larger version.
    Total length - 1,88 mtrs
    Total weight - +/- 560kg
  18. #16
    Thanked: 522
    I've got a Merc 300d as well
  19. #17
    Thanked: 522
    Strange...I know of 4 landys (3 x88's, 1 x 109) that had them fitted...and then pulled out again.
    Problem is the working rpm ( sweet spot)
  20. #18
    Thanked: 17104
    yep me too, but remember, we know nothing Gary
    Jakes Louw
  21. #19
    Langs die rivier, op n berg
    Thanked: 3869
    Td27ti, of QD32ti, met meganiese pomp, en gilo adaptor na landy gearbox.
    Basies n straight drop in.
    No nomsense engine, geen elektronika, en was nog na 2010 in afrika verkoop in nuwe bakkies wees hul robust design.
    Tussen 90 en 115kw, 300-400nm
  22. #20
    Apr 2014
    Richards Bay
    Thanked: 116
    Leaning towards a Jap import as they are supposedly low mileage (under 100K).With the QD32 what transmission and transfercase combo would work? Something out of a patrol maybe? Transfercase needs to fall to the right.The ENV diffs on the forward control have a ratio of 4.7.
