Looking to buy 2010 Freelander 2 TD4 SE - Have some concerns
Results 1 to 3 of 3
    Aug 2018
    Queenswood
    Default Looking to buy 2010 Freelander 2 TD4 SE - Have some concerns
    G'day All,
    Went to test drive the vehicle today. Great drive. 2 things do bother me:
    1 - It has 215,000 k's on the clock. Is this high or pretty much acceptable?
    2 - Pulling away is my main concern. When I the vehicle pulls away the nose almost rocks a bit from left to right and then steadies its self. Is this something to be concerned over? I did a u-turn at around 50km/hour no problem.
    Thank you.
    Thanked: 193
    Default Re: Looking to buy 2010 Freelander 2 TD4 SE - Have some concerns
    Quote Originally Posted by bazzapr View Post
    G'day All,
    1 - It has 215,000 k's on the clock. Is this high or pretty much acceptable? Cambelt service is due soon. 240000km's or 10 years.
    2 - Pulling away is my main concern. When I the vehicle pulls away the nose almost rocks a bit from left to right and then steadies its self. Is this something to be concerned over? I did a u-turn at around 50km/hour no problem. Worn lower control arm bushings maybe, or bent rims. Could be more serious, or less, have it checked out first.
    Thank you.
    Answers in red. They're awesome cars.
    2005 Land Rover Discovery 3 V8 (Will allways end up with an V8)
    1967 Land Rover Series 2A 3.5 V8 (The Green Machine)
    196? Land Rover Series 2 V8 100" (The Coiler)
    2007 Subaru Forester XT 2.5T (The Daily)
    Ex.
    1996 Land Rover Discovery 1 Tdi
    1997 Land Rover Discovery 1 V8
    2001 Land Rover Discovery 2 V8
    2006 Land Rover Discovery 3 TDV6
    2007 Land Rover Freelander 2 TD4
  3. The Following User Says Thank You to JeandreDiedericks For This Useful Post:
    Feb 2015
    Thanked: 32
    G'day All,
    1 - It has 215,000 k's on the clock. Is this high or pretty much acceptable? My 2010 Model was going great til the Timing Belt snapped on 212000km's, Book says to change on 240 000km's, I would suggest do it now if not already done.
    2 - Pulling away is my main concern. When I the vehicle pulls away the nose almost rocks a bit from left to right and then steadies its self. Is this something to be concerned over? I did a u-turn at around 50km/hour no problem. Could be a number of issues, probably something small like shocks, but as mentioned rather have it checked by TWT or someone similar.
    Thank you.
  5. The Following User Says Thank You to scotty780925 For This Useful Post:
