Where can I get these castor wheels?
Results 1 to 4 of 4
    Thanked: 306
    Default Where can I get these castor wheels?
    Im looking for the caster wheels that fit into the bottom of a 1/2 inch square tube. Its the legs for a parrots cage but the wheels keep falling off.
    The issue is the fittings that go into the square tubing and the wheels then attach to those fittings.
ID:	498264   Click image for larger version.
    Thanked: 1700
    Default Re: Where can I get these castor wheels?
    If the parts falling off are not broke just drill a hole into the tube and put a screw in. Alternatively pin or wire depending on how the parts look like.
    Gelmar has something similar.
    Jouko
    2003 Grand Cherokee 4.7l
    2012 Smart
    Never drive a normal car
  3. The Following User Says Thank You to Jouko For This Useful Post:
    George
    Thanked: 537
    Also vote for Gelmar, they have a castor that fit into those rolling wire veg rack things with square profile leg sections.
    Aug 2011
    Thanked: 27
    Take some isolation tape and tape it 1 or 2 times around and press it back in.
  6. The Following User Says Thank You to PlaasBakkie For This Useful Post:
