Electricians Question
Results 1 to 19 of 19
    Centurion + Others
    Thanked: 142
    Default Electricians Question
    Morning EXPERTS.
    We about to wire a new pool pump/filter setup.
    is it legal to run a cable from the pump supply another waterproof plug point about 15m away?
    if so - what is the correct type of cable?
    shielded cable ?? cerfex/serfix
    thanks
    cc
    Merit before Race - anything else IS Racism.
    Stay Calm, engage low-ratio, keep buggering on - a Landy Man
    Longevity isn't worth dying for,
    Aug 2008
    Harties
    Thanked: 326
    Default Re: Electricians Question
    2.5mm2 twin and earth in conduit.
    Or SWA cable.
    Fortuner D4D
    Jurgens XCAPE
  3. The Following 2 Users Say Thank You to PRA For This Useful Post:
    Aug 2008
    Harties
    Thanked: 326
    The socket must be on an earth leakage protected circuit.
    Fortuner D4D
    Jurgens XCAPE
  5. The Following 2 Users Say Thank You to PRA For This Useful Post:
  6. #4
    Oct 2006
    CAPE TOWN ,SOUTH AFRICA
    Thanked: 334
    Well, you can plug anything you like in to a plug, as long as the plug point complies to the regulations, on earth leakage and protected by a 20 amp breaker and the right size cable.
    Normally a pool pump is classed as a fixed appliance, has an isolator on or adjacent to it ,controlled with a time clock, its own circuit breaker and on the earth leakage system.
    I see nothing wrong with fitting a weather proof plug also on own circuit breaker controlled with timer , and you plug the pool pump into that. But must be within arms reach. You wouldn't tap another plug of there as its on a t/c and will be off at times
    So you cant tap a plug of the pool pump as such, but you can fit another breaker in the DB and run a plug point from there.
    ORA
    Ian
    Thanked: 255
    Most pool pump electrical boxes come with an additional plug point. Just extend it with some properly sized surfix.
    2004 Defender 110 Td5
    Thanked: 1365
    Quote Originally Posted by Sawdust View Post
    Cannot just put surfix. Image is from the local standard. It is possible that there has been an amendment. I bought this version about 3 years back. We have a lot of underground cables in our holiday place. Even armored cables get damaged. I would cover with some concrete and when coming up standard conduit tends to be too weak. Any joints underground use only those epoxy filled joiners. Available at builders. They have two types. Cheaper of the two was too flimsy for my liking.
    Jouko
    2003 Grand Cherokee 4.7l
    2012 Smart
    Never drive a normal car
  9. The Following User Says Thank You to Jouko For This Useful Post:
  10. #7
    Jan 2010
    Thanked: 59
    Correct and legal way, circuit breaker/ (double pole circuitbreaker-isolator) on E/L (as a plug is mostly installed in pool db) in main or sub board, marked as pool, with a minimum of 2.5mm cable, depending on additional equipment close to the pool db which might be fed from pool db. Pool db marked as (DB fed from Main/sub db). No outside plugs, as mentioned it is a permanent part of the installation.
    Problem comes when requiring a C of C for sale of house. There is a lot off different opinions with regards to interpreting the SABS book, as even electricians tend to differ at times, some take short cuts etc, as its not always possible to get to a Internal db due to flat roofs, db in passage etc,
    Then there is a part on C of C which says "mixed circuits" which I would have used,( "stopped doing Cof C long time ago, to much trouble) if there was no other option than outside weatherproof plug, but again, same thickness of wires, normally protected by a 20A circuit breaker, and mark the db and outside plug as Mixed(pool-plug) as well as the pool db. (I would have preffered a weather proof double pole isolator, even if fed from plug circuit) outside instead of a plug, still on E/L Again, there will be guys having a different opinion of what I just said, thats why, I am not getting involved in arguments, interpretation etc. Just my opinion of possibilities to evaluate.
  11. The Following 2 Users Say Thank You to Rudy Roodbol For This Useful Post:
  12. #8
    Thanked: 1365
    I agree with post #7. Electricians have different opinions. Difficult to find 2 that agree. I had 2nd DB added to the house. More than one opinion.
    I feel sorry for the electricians. That standard I took one page above has been changed many times. 396 pages and it is only one part of the set. Very few like to read standards and they are never written so that there are no questions.
    Jouko
    2012 Smart
  13. The Following User Says Thank You to Jouko For This Useful Post:
  14. #9
    Centurion + Others
    Thanked: 142
    Thanks to all the replies and input.
    WHAT, may i ask, is a double pole isolator
    Thanks,
  15. #10
    Oct 2006
    Thanked: 334
    Quote Originally Posted by Capt Chaos View Post
    Thanks,
    It switches off both poles in other words it switches off live and the neutral simultaneously,
    where as a normal switch just turns off the live side .
    ORA
    Ian
  16. The Following User Says Thank You to OFFROAD ADDICT For This Useful Post:
  17. #11
    Hillcrest, Malaysia
    Thanked: 3703
    I think the "meaty" part of the question was - what type of cable ?
    And this doesn't appear to have been answered.
    Also will the cable be buried. ?
    ZS5KAD Yeasu Ft-897D
    3 V8's
  18. #12
    durban
    Thanked: 478
    Good question. And if its exposed does it need to be fitted into trunking or is cerfix/serfix good enough.? Or can you use white surfix in sun or must it be black or white.?
  19. #13
    Jan 2010
    Thanked: 59
    I did answer the question about the meaty part: 2.5mm three core. Ideally in ground/plant sections is to put a armoured cable, but what I used to do, and first discussed this withe client, (surfix can be used, i did not use flat twin and earth, as surfix has a thin additional alluminium cover) when client agrees, 20mm pvc or galvanised conduit, mounted against surface of wall, on normal or hospital saddles, and digg a trench 350-400mm deep and installed this surfix, again, in either pvc or galvanised conduit. For difficult bends, you can use spraque tubing which is flexible and from my experience, can last a while outside before becomming brittle. Again, galvanised spraque could be used.
    PS: Hospital saddle, is slightly different to normal saddle, as it has a 5mm backplate which causes the conduit to stand away from the wall.
    a lot of old school engineers, still prefer surface mount to be galvanised and on hospital saddle. Hopes this clears some questions, and Yes, you can use 2.5mm cable, as it normally is protected by a 20A circuit breaker.
  20. The Following User Says Thank You to Rudy Roodbol For This Useful Post:
  21. #14
    Centurion + Others
    Thanked: 142
    yes thanks
    I was planning to use heavy surfix AND put it in conduit BURIED.
    in which areas do you work Rudy??
    thanks again...
    cc
  22. #15
    Dec 2009
    Thanked: 21
    My sparkie question, if I may. I have an existing plug socket which is now getting a cupboard in front of it. A new 4x4 box with all the goodies is now installed in the cupboard. What is the correct way to wire to this box? Can the existing wires be extended or must new wires be installed to go all the way to the new box?
  23. #16
    Jan 2010
    Thanked: 59
    Unfortunately I stopped working end of Jan this year.
  24. The Following User Says Thank You to Rudy Roodbol For This Useful Post:
  25. #17
    Jan 2010
    Thanked: 59
    Waldo, the way it could be done, put an extention box on the back cover of the cupboard, with a 4x4 coverplate to have accessability later. Join the wires inside the ext box, prefably crimping the joint with ferrulles, and insulate properly. Some use connector blocks, but I prefer ferulles. Gland on side of ext box, use surfix, probably in ega tube, drill through cupboard wall and fit new plug on extension box, surfix in ega tube, where you want the plug. Mark again from where its supplied. Ideally chase in wall extend existing conduits to and back too new plug position, rewire and connect, but this is very seldom possible as only the cupboards are replaced. Strictly speaking, qualified, registered Elect. should do the job and sign off Cof C for his part of the work. Hope it helps, and again, thats the way I would do it, others might differ, Rudy
  26. #18
    Dec 2009
    Thanked: 21
    Thanks Rudy. Got all the bases covered and yes, will have the required signoff, just wanted to confirm that it is ok to extend the existing wires.
  27. #19
    King Williams Town
    Thanked: 615
    Thanks,
    Best is install a double pole and neutral circuit breaker. It breaks both live and neutral circuits as well as tripping on over current. We have thrown out the double pole pole isolators as a main switch on new or rewired houses in our town. Pool pumps boards have gone the same way...reason is that it must trip on the consumers side and not councils side
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  28. The Following 2 Users Say Thank You to hunter26 For This Useful Post:
