What globe replacement?
Results 1 to 10 of 10
    Melkbosstrand Cape Town
    Default What globe replacement?
    I had these globes in my SJ which are crap, replaced them with 55w/35w HID after market kit but the oncoming traffic moan like crazy as they are too bright , what can I replace them with ?
    Sep 2016
    Oxford
    Default Re: What globe replacement?
    Have you checked the setting of the lights? Maybe not the bulb, but lights just set too high.
    Quote Originally Posted by Leakydiff View Post
    Thanks ,the SJ is lifted which doesn't help and I have set them as low as possible . They are so bright even the cats eyes on the road shine in the day.
    Garsfontein
    Just normal Osram Nightbreakers? But even those might be too bright in your situation. Are the brights and normal dipped mains one single bulb?
    Jun 2007
    What does the headlight itself look like ? Okd glass fluted lenses or the newer clear polycarbonate lens ?
    Jan 2007
    Grootbrak
    The standard lenses are designed for tungsten and not HID and will blind oncoming traffic.
    Osram Nightbreaker + should make a significant difference.
    I have fitted them to my 2002 Hilux and they make a huge difference.
    BTW have you checked the voltage on the old globe terminals.
    Brian Coleman
    2002 Hilux Raider 2,7i S/C 4x4 + Canopy Caravan
    2014 Suzuki Grand Vitara Dune 2,4 M/T + Challenger Nomad 4x4 Trailer
    I bought new lenses at Midas same as Golf 1 clear lenses and agree they are not designed for HID kits but wow did they work well . Originally I bought a light bar but never fitted it as the HID`s were more than enough. I think these globes are the original ones and probably 10 years old but I will put in a set of Osram night breakers and report back .
    Sep 2015
    Pity you didn't replace with LED rather than a HID as they have a "frame" that allows one to shape the light. You would have to experiment as some reflectors at the bottom through light up while the top reflectors throw it forward. On my driver's side light, I placed a cap on the top and bottom - see the first pic. On the co-pilots side, I just needed one on the bottom. You might need a cap on the end, but I didn't find this necessary. The second pic shows the excess corrugated roofing that I used for the caps. Yeah - I like DIY.
ID:	498083   Click image for larger version.
    Renault Duster 4WD Gen1: No Meow
    I had the same issue with globes for my SJ, I managed to get the following, it's a H4-P45T 60/55w.
    2008 SUZUKI GRAND VITARA 2,4 A/T
    WIZERD LIFT KIT, WIZERD BASH PLATES,
    WIZERD TRANSFER CASE PROTECTOR,
    WIZERD ROCKSLIDERS, 235/65/17 BRIDGESTONE A/T
    1984 SUZUKI SJ 410
    Sep 2015
    I put this HID in my bike awhile back. Note that it has a (dark) shield along the bottom that holds the cap in front. I cut the nearly half round shield to just keep the part that was blocking the glare.
