Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 65
    Jan 2011
    Thanked: 51
    Default Fortuner 2.8 GD6 OBD Tire Pressure Monitoring System
    Hi,
    Recently bought a OBD TPMS from Alibaba for $30 Shipping was $25 but only because it was 5 day delivery so can probably get away much cheaper if you do not mind waiting a couple of weeks via normal post and/or ordering more than one unit.
    https://www.alibaba.com/product-deta...10853e5fpWsvzF
    Pretty sure it will work on the 2.8 GD6 Hilux as well...
    I was very sceptical that it would actually work but decided to try in anyway as I did not like the normal TPMS systems available. Having to reprogram or swop sensors when you swop tyres, flat sensor batteries x 4, theft of external sensors, bulky display for tyre pressures that need a power source etc so gave this unit a go etc etc.
    Surprisingly it actually looks very decent and works as promised. Quality is also fine. Drove around for a couple of km after setting it without any false alarms etc. I then deflated one tyre from 2.1 to 1.5 and it picked it up in +- 1.3km.
    Fitment is a 2min job: https://www.youtube.com/watch?v=ALqxjgawF7E
    No cutting of wires etc, just plug and play.
    Changed the green tyre indicators to blue and it matches the blue lights of the Fortuner while still turning red when a flat is detected.
    Next test will be on a gravel road, 2WD and 4WD, to see what it does as there will most likely be some slippage on the tyres that could affect the accuracy of the unit as it uses ABS/tyre rotation data from the ECU. Who knows, maybe the algorithm/data used as well as the distance used to detect a flat will prevent false alarms. I drive on tar 95% of the time so not really a deal breaker to me but might be for some more regular gravel road travellers that are looking for a TPMS system
    Not sure when I will be able to do some gravel roads but will report back when I have.
    I suspect the biggest question is if this unit will work on the older 3.0 D4D Fortuner/Hilux
    2017 Toyota Fortuner 2.8 GD6 4x4 iMT
    2016 Hyundai Tucson 1.6 T-GDi
    2019 Bush Lapa Miskruier BL1861
  2. The Following User Says Thank You to observer For This Useful Post:
    Melkbosstrand
    Thanked: 638
    Default Re: Fortuner 2.8 GD6 OBD Tire Pressure Monitoring System
    Interesting...
    Everybody needs to believe in something.... I believe I will have another Beer!
    Travel Blog: https://since1652.wordpress.com/
    https://www.instagram.com/since1652travel/
    May 2007
    Durbanville Cape Town
    Thanked: 218
    Very nice. In for a group buy if more people are interested.
    Thanked: 108
    It looks very interesting. Did you get the one without the speedlock? I wouldnt like the thing to go off every two hours of driving. I also don't want it to start messing around with locking the doors etc. when the car already does that.
    Jan 2011
    Thanked: 51
    No just ordered the standard one. Still need to do a 2hr+ trip but I assume it will just be one beep so nothing serious.Doing some gravel roads today so will see how it reacts to wheel slip /4wd etc.
  7. The Following User Says Thank You to observer For This Useful Post:
    Jan 2011
    Thanked: 51
    Happy to report that the TPMS unit did not show false flat tyres on gravel roads
    Oct 2012
    Thanked: 21
    Thanks for the info.
    What is connected to the valves?
    Hilux 2.8 GD6 4x4 DC
    Jurgens Explorer
    Cobus
    Jan 2011
    Thanked: 51
    Drove up to Paarlberg Mountain Reserve where there are lots sharp turns, bad ruts etc. Did +- 30km where I used 2WD to go up around steep inclines/turns etc. Invoked the traction control a few times and also tried 4WD without issue.Will most likely do some longer distance gravel roads beginning of October when we go to the Orange River so will provide more feedback then.
  11. The Following User Says Thank You to observer For This Useful Post:
  12. #9
    Jan 2011
    Thanked: 51
    Quote Originally Posted by Cobus. Pelser View Post
    Thanks for the info.What is connected to the valves?
    Nothing, it uses the wheel sensor/ABS data from the ODB port
  13. #10
    Melkbosstrand
    Thanked: 638
    Can you set the alarm level? i.e lower than 1.5 bar
  14. The Following User Says Thank You to Papsak For This Useful Post:
  15. #11
    Oct 2012
    Thanked: 21
    Quote Originally Posted by observer View Post
    Thank you
    Jurgens Explorer
    Cobus
  16. #12
    Jan 2011
    Thanked: 51
    Quote Originally Posted by Papsak View Post
    No, check the first link I posted under details. You can set the % deviation from the "learning phase" tire pressures. In my case I left it at 25% default so it will alert at 2.1 bar minus 25%.
  17. #13
    Feb 2017
    Thanked: 30
    Quote Originally Posted by bees View Post
    Thanks a lot Observer. Was looking at all sorts of TPMS systems for my Fortuner GD-6 and most of them have a display unit you must put somwhere on your dashboard - not for me. But the one as per this topic is 100%.
  18. #14
    Jan 2011
    Thanked: 51
    Quote Originally Posted by SUVMan77 View Post
    Bees - I will definitely be interested in getting one. Based in Pretoria. Count me in please.
    Pleasure....just a pity about the Rand:USD exchange rate at the moment
  19. #15
    Jan 2011
    Thanked: 51
    Thought I would give an update on this unit Done +- 1000km now and no issues so far.
  20. #16
    Dec 2006
    Thanked: 33
    Thanks so much for sharing.
    Brilliant solution!!
    I want one!
    Who's in for a group buy?
    2012 Jeep Wrangler 3.6 Unlimited Sahara
    2018 VW Amatrok 3.0 V6 4motion
    2021 Sprite Splash/Tourer SX
  21. #17
    Jan 2011
    Thanked: 51
    This unit saved my tyre in Cederberg this weekend TPMS alarm went off and correctly identified a puncture left rear tyre! Really chuffed with this purchase We did a lot of gravel road travelling and I first thought that maybe this was the first false alarm...
  22. The Following 2 Users Say Thank You to observer For This Useful Post:
  23. #18
    Citrusdal
    Thanked: 345
    Only problem I see is when sand driving and you want to deflate to 1bar or less. It will start beeping unless you reset your starting point to 1 I suppose.
    2011 FJ Cruiser
    Afrispoor Serval
  24. #19
    Jan 2011
    Thanked: 51
    Still need to go to Atlantis to test that but as you mentioned you just can just reset it or maybe if all 4 tyres are the same pressure the wheel rotation speeds will be +- the same so no alarm
  25. #20
    Thanked: 108
    Quote Originally Posted by Jacques_R View Post
    I want one!
    I would also be interested in a group buy
