Having Trouble with 1950 Vauxhall
Results 1 to 20 of 20
    Jul 2018
    Durban Hillcrest
    Thanked: 6
    Default Having Trouble with 1950 Vauxhall
    I have a 1950 Vauxhall Velox 2.25L straight 6 that performs better with the Choke half out. I have tried everything to get this sorted out. Bought a refurbished Carb from UK. new points, plugs, leads coil, set the timing and still the same problem,
    I must mention here that the spark plugs also carbon up very quickly, I was advised to have the head overhauled which I have now done but still having the same problems, in another discussion someone mentioned if the car runs better with the choke half out this will tell you if its Carb Related.
    What would be the fix if it is carb related, Jetting??
    appreciate any suggestions
    Nigel
    Aug 2008
    Thanked: 16
    Default Re: Having Trouble with 1950 Vauxhall
    Beautiful machine! I don't know if your can still get LRP fuel in KZN but if you're using ULP, it's advisable to throw a little bottle of 'Valve Guard' by Wynns to every 60 litres fuel.
    Although this won't fix the carb thing, I thought I'd mention it in case you didn't know.
    I reckon your's is a jetting problem. Underfuelling = jets too small.
    Your mind is your strongest weapon.
    Then there's.....POWER TOOLS!
    '94 LC 80 GX
    '00 Frontier 280DT 4X2
    2002 Sprite Surfer Nomad
    Nigel
    Thanked: 1131
    Couple of questions.
    What is the air to fuel mix? Have you had it on a gas analyser?
    What plugs are in the car? Could be they are to cold.
    Are you sure the dwell angle is sufficient/right?
    Have you checked the power on the coil? Is it putting out enough voltage?
    LC 78 Troopie 1HD-FTE
    +27 zero eight 2 four 95 9252
    cape town
    Thanked: 103
    my guess is vacuum leak somewhere ... in the distributor vacuum advance or brake booster ?
    suppose the "choke half out" means the choke is actually engaged and not just incorrect setting of the choke cable.
    kathu
    Thanked: 1177
    What carb ? Solex? These old engines are not rocket science. As said in this thread make sure timing is 100% spot on.
    Please post a pic of a carboned spark plug.
    Once had a similar problem on an old 3.8 Chevy engine. Later found out it had a carb from a 3.2 engine. Identical looking carbs but different bore and jets. The owners still had the original carb. Sorted out the original one and it was purring like a kitten.
    Thanked: 5482
    Worn spindle shafts on the carb butterflies, causes a lean condition. needs a carb rebuild or a new carb.
    Jul 2016
    Pringle Bay
    Thanked: 489
    When you say it runs right with the ckoke out. ! How does it idle without the choke ? If it idles ok with no choke if you try and rev does it struggle ?
    Jelo he said he had a refurbed carb from the UK.
    Audi A6 Avant Quattro V6 tdi
    VW Touareg V6 tdi ( sadly written off )
    2 x Toyota Celica GT4 Gen 6 (Sold) sadly missed
    2 x Toyota Celica Gen. 5 ( Sold ) not missed as much as the above.
    Thanked: 5482
    Quote Originally Posted by meh View Post
    then I'd say if it did the same with both carbs, he has an inlet manifold leak
    Jul 2018
    Durban Hillcrest
    Thanked: 6
    The idle is great with the choke right in. She revs great until it gets a load then starts backfiring through the carb and looses power, when this happens i pull the choke half out and the motor pulls well
    Jul 2018
    Durban Hillcrest
    Thanked: 6
    The carb is a ZENITH 30 VIG-5 , that is the carb that came with the car. and the same refurbished one I got from UK, the jetting is correct as per the workshop manual.
    Jul 2018
    Durban Hillcrest
    Thanked: 6
    When we had the Head redone we checked the manifold for cracks, I even sprayed it all over with the pink spray they use when checking for new pipe welding cracks,
    Nothing came up. the auto advance and retard works well and the carb pumps a burst when you accelerate, it dies not have a brake booster so no leaks there.
    Jul 2018
    Durban Hillcrest
    Thanked: 6
    Quote Originally Posted by nigelgeast View Post
    I don't have an actual pic of the Spark Plug but this is what they look like after about 40 KM, If I go anywhere I take a cleaned set or new or both with me because after wa while the car starts missing due to the plugs being carboned up.
    Jul 2010
    Pinetown
    Thanked: 630
    I WISH I had an old car like this.
    Cried like a baby when I had to sell my 32 year old BMW 5 Series and again when I had to sell my Ford Ranchero. Both in excellent condition.
    But economics and retirement years combining ...
    I LOVE old cars!
    And that's not only my "OLD" Suuz!!! Still a youngster at 20 years now.
    Platkar = Chevy Spark 1.2
    Nigel
    Thanked: 1131
    Not sure if you answered all my questions.
    What plugs are those? Run a hotter plug.
    That is way to rich. That plug should be clean
    What is the air to fuel ratuo. My guess would be about 13:1 is what it should be.
    Thanked: 5482
    Yep the jetting is way out if the plugs look like that, and that destroys my running lean theory.
    cape town
    Thanked: 103
    Have you confirmed valve timing is good. Check the distributor for worn bushings and pins, distributor cap for arcing and the firing sequence is correct. If still points and condenser confirm the distributor lobes are not worn.
    he needs to make it rich by pulling the choke to run correctly, points to a timing issue imo. spitting thru the carb is the key
  17. The Following 2 Users Say Thank You to RussellF For This Useful Post:
  18. #17
    kathu
    Thanked: 1177
    Back firing through card usually points to ignition timing. I would recheck all timing marks. Make sure that when on TDC the timing marks does correspond.
    Make 100% sure you use thecorrect spark plugs. Friend of mine was battling to get a 351C running smooth a few weeks ago. Also backfiring through the carb. We solved the problem by fitting a set of old spark plugs from one of my v8`s.
    I only use AC Delco spark plugs on my v8 engines. The equivalent in NGK and Champion foul very easily for unknown reasons.
  19. The Following User Says Thank You to grips For This Useful Post:
  20. #18
    Nov 2017
    Thanked: 80
    In addition to the above, I would just replace the condenser with a new one - it is possible that the new one is faulty. If not faulty you will have a spare for the future.
    Check the plastic insulator where it mounts on the distributor as it could be squashed or hard and brittle etc, check the wire from the insulator inside going to the points. Could be that the lug and/or wire going to the points is worn - the wire could be frayed or the lug will be splayed out, possibly not making proper contact. Check that when you tighten the nut on the outside of the distributor, the bolt pulls tight on the inside. Make sure there is no corrosion on or around that bolt. Remove the rotor arm and add oil or grease inside the top of the distributor shaft - whatever the specs say.
  21. #19
    Jul 2018
    Durban Hillcrest
    Thanked: 6
    Guys
    Thanks for all the advice, I am away from home at present but will certainly try all the suggestions, I will provide feedback once I have resolved or require additional tips
  22. #20
    Al Ain
    Thanked: 17
    When buying a new condenser (capacitor), take a test meter with which can measure capacitance. Make sure the new part measures 0.22 uF. due to mass production, they tend to measure around 0.19 uF, or less. And even this could also contribute to your problems.
    I might be a FOOL, but I am an OLD fool - from unknown.
