Ford & Mazda 2. 5 gearbox running very hot.
Results 1 to 20 of 32
    Jun 2013
    Richards bay
    Default 2. 5 gearbox running very hot.
    Good day everyone. I just replaced the gearbox on my 2.5 Mazda Drifter 4x4. The gearbox and transfer case are both full of oil and there are no funny noises or vibrations coming from them. Yet, this gearbox runs extremely hot. So hot that it actually burns my leg next to the tunnel inside. I first had 15w40 (Shell Helix) oil in the gearbox and EP90 (Castroll) in the transfer case. This morning I had the 15w40 replaced with EP90. The gearbox is still running at the same temperature. Anyone had a similar problem that could shed some light?
    2000 Mazda Drifter DC 4x4 2500 TDi
    50mm lift
    BFG All Terrains
    Small package with a big Heart
    Why buy something, when you can experience the frustration of building it yourself.
    Dec 2012
    Slaapstad
    Thanked: 90
    Default Re: 2. 5 gearbox running very hot.
    Try and get your hands on Castrol BOT 402. I put it in my gearbox on my Ranger 2.5TD after having the 5th gear fixed and haven't looked back. Shifts really smooth and not running hot.
    A word of warning, it's not cheap, but it's cheaper than rebuilding the gearbox again by far...
  3. The Following User Says Thank You to Boksie For This Useful Post:
    Thanked: 10250
    EP90 is the wrong oil
    15W40 is the wrong oil
    A good 75W90 or 80W90 would be better for the gearbox. (as per the owners manual)
    https://www.dropbox.com/s/l9amjj4hut...+Transaxle.pdf
    the transfer case seems to need a good ATF like Dexron III
    https://www.dropbox.com/s/l9amjj4hut...e+and+Axle.pdf
  5. The Following User Says Thank You to jelo For This Useful Post:
    Thanked: 185
    You need an oil with a SAE 80W-90 viscosity in the gearbox and transfer-case.
    15-40 is way to thin and EP90 is also wrong.
    http://weatherinfo.co.za/Ford_Manual.zip for the manual
    Touareg V10
    KTM 1290 Super Adventure R
  7. The Following User Says Thank You to SpiderGear For This Useful Post:
  8. #5
    Thanked: 10250
    I seem to be getting an idea why the previous gearbox was replaced............
  9. #6
    Mar 2016
    Thanked: 1914
    15w40 is engine oil
  10. #7
    Jun 2013
    Richards bay
    Quote Originally Posted by Boksie View Post
    Try and get your hands on Castrol BOT 402. I put it in my gearbox on my Ranger 2.5TD after having the 5th gear fixed and haven't looked back. Shifts really smooth and not running hot.A word of warning, it's not cheap, but it's cheaper than rebuilding the gearbox again by far...
    Thank you Boksie. I will have look at it.
    50mm lift
    BFG All Terrains
  11. #8
    Langs die rivier, op n berg
    Thanked: 2464
    Quote Originally Posted by Oppies3800 View Post
    15w40 is engine oil
    Baie gearboxe mag net daarop loop, anders shift hulle nie. Ek dink die vorige shape isuzu moes met 15w40 loop...
  12. The Following User Says Thank You to Reenen For This Useful Post:
  13. #9
    Thanked: 2464
    Op plaas, gebruik ons baie “universal” olie soos supertou of kht, en nog n paar ander name. Werk van engine, ratkas tot hidroliese stelsel.
  14. #10
    Thanked: 2464
  15. #11
    Thanked: 2464
    Klink na n bearing issue
  16. #12
    Thanked: 2464
    Solank dit gl4, en nie gl5 is...
  17. #13
    Jun 2013
    Richards bay
    EP90 is the wrong oil15W40 is the wrong oilA good 75W90 or 80W90 would be better for the gearbox. (as per the owners manual)https://www.dropbox.com/s/l9amjj4hut...+Transaxle.pdfthe transfer case seems to need a good ATF like Dexron IIIhttps://www.dropbox.com/s/l9amjj4hut...e+and+Axle.pdf
    Thanks Jelo. I see the service manual is for the 2006 and later model. I have the 2000 model. Do you think the same oil should be used? I used the 15w40 because the guy who sold me the gearbox as well as a previous technician I spoke to recommended it. I found my slip for the oil I bought this morning and it's Castrol Axle EPX80w90. Which makes it the right oil then. As per the manual. The Dexron III seems to be a General Motors or Ford Trademark. What would a good equivalent be?
    50mm lift
    BFG All Terrains
  18. #14
    Jun 2013
    Richards bay
    Quote Originally Posted by SpiderGear View Post
    You need an oil with a SAE 80W-90 viscosity in the gearbox and transfer-case. 15-40 is way to thin and EP90 is also wrong.http://weatherinfo.co.za/Ford_Manual.zip for the manual
    Thanks SpiderGear.See reply to Jelo.
    50mm lift
    BFG All Terrains
  19. #15
    Thanked: 2464
    Quote Originally Posted by iamartin View Post
    Axle oil is gl5, en is baie baie sleg vir n syncro gearbox. Dit gaan jou synchros opvreet.
    Axle oil is vir hypoid gears wat op n angle loop en masiewe wrywing opbou, dus spesiale “taai” olie om te verseker dat daar n oliefilm tussen geartande bly.
  20. #16
    Jun 2012
    Thanked: 151
    Daai ratkas loop warm, maak nie saak die olie nie. Tussen 96°C en 110°C. Die volgende issue gaan die hydraulic fluid vir die clutch wees wat donker word a.g.v die hitte.
  21. #17
    Jun 2013
    Richards bay
    Exactly. Had 5th gear repaired and used 15w40 in that box. As recommended by repair technician. One week later 3rd and 4th gears seized up. At first thought it to be bad repair job, but now I'm wondering if it was not the oil. Now I bought a second hand box from an engine importer and they also recommended 15w40.
    50mm lift
    BFG All Terrains
  22. #18
    Jun 2013
    Richards bay
    Quote Originally Posted by Jack Russell View Post
    Oorspronklike ratkas het nie naastenby so warm geword nie. Hierdie ratkas brand my been dwars deur n dik Flameproof overall broek.
    50mm lift
    BFG All Terrains
  23. #19
    Jun 2013
    Richards bay
    Axle oil is gl5, en is baie baie sleg vir n syncro gearbox. Dit gaan jou synchros opvreet.Axle oil is vir hypoid gears wat op n angle loop en masiewe wrywing opbou, dus spesiale “taai” olie om te verseker dat daar n oliefilm tussen geartande bly.
    Is daar dan n verskil tussen Axle EPX 80w90 en n ander EPX 80w90?
    50mm lift
    BFG All Terrains
  24. #20
    Jun 2012
    Thanked: 151
    Dis bietjie te warm.
