Jimny tyres 215/75/15 vs std tyres and 40mm lift - Page 2
Results 21 to 33 of 33
    Mar 2016
    cape town
    Thanked: 39
    Default Re: Jimny tyres 215/75/15 vs std tyres and 40mm lift
    215/75/15 on steel 7 inch rims
    Mar 2016
    cape town
    Thanked: 39
    Now should be right way up
    Jan 2007
    Thanked: 326
    Quote Originally Posted by Dirtrob1 View Post
    Still looks like an Aus Jimny
    Vic
    Mar 2016
    Thanked: 2067
    This Fortuner has a very odd shape...
  5. #25
    Thanked: 43
    Hi,
    I need to put new tyres on my gen3 Jimny, and I want to go slightly bigger. The options are very limited though:
    205/75/15 Goodyear Wrangler - My first choice, but they out of stock
    195/80/15 Hankook Dyna Pro Atm RFM - Looks good, but concerned about sidewall strength
    215/75/15 General Grabber - SO tempted, but really concerned about fuel consumption and power loss
    so, with the 215's does the power loss effect offroad driving, especially steep climbs and sand dunes?
    Any comments or suggestions on my choices?
  6. #26
    Jan 2007
    Thanked: 326
    Quote Originally Posted by BDalldorf View Post
    Hi,
    I had 215/80R15's on my Gen 3, which are bigger than all of the sizes you have listed. I never had any issues off-road, no matter how steep. I never did any dune driving, but the bigger the tyre the better the floatation, so I can't see you having an issue.
    Vic
  7. The Following User Says Thank You to saxj For This Useful Post:
  8. #27
    Jun 2016
    Randfontein
    Thanked: 2004
    Hi,
    I had 215/75R15 General Grabbers on my gen3 Jimny. Really good value for money and you can still do 120km/h on the open road. Offroad the traction is excellent and you can still do dunes because of better flotation as Vic mentioned.
    The reason I say so is because I have done dunes with a Gypsy (with less power than a Jimny) with 215/75R15
    Willie
    2020 Nissan NP300 2.5TDi S/C
  9. The Following User Says Thank You to FWM For This Useful Post:
  10. #28
    CPT
    Thanked: 24
    I have 40mm spacers on coils, safari HDP's and 215's. No real difference. You'd be hard pressed to spot the difference. Consumption went from 12-13km/L (I do 99% highway driving) to 10-11km/L.
    I have a K&N filter, sliiiight difference with this fitted, but still would be hard pressed to spot the difference. Improved consumption from 9-10km/L to 10-11km/L, so nothing to write home about.
    Things to add that make all the difference:
    Stiffer shocks (Safari HDP's are cheap and durable enough for what most people do, they're hard as nails.)
    Steering damper
    All of these can be found in one place: Zombie Offroad.
    2014 Jimny
    40mm spacer lift
    Gabriel Safari HDP's
    215/75/R15
    30mm Wheel Spacers
    Steering Damper
    K&N Filter
    TC bash plate
    Burnco Bumper
  11. The Following User Says Thank You to Professional_Weekender For This Useful Post:
  12. #29
    Thanked: 43
    Thanks all, much appreciated!
  13. #30
    Thanked: 6
    Hi, on the new Jimmyís 2020 models, whatís the biggest size tyre you can add without any issues of rubbing etc
    And what is the best size to install?
    Land Cruiser 79 V8 2015
    Land Cruiser 76 V8 2014
  14. #31
    Jan 2007
    Thanked: 326
    Quote Originally Posted by HorseBeast View Post
    215/80R15 is the biggest you can fit without a lift (4.6% bigger than stock). 215/75R15 is the best if you want to maintain your fuel consumption (1.5% bigger than stock). There are also a lot more options available in 215/75R15.
    Vic
  15. The Following User Says Thank You to saxj For This Useful Post:
  16. #32
    Thanked: 6
    Quote Originally Posted by saxj View Post
    Thanks so much... so with the 215/75ís there is absolutely no rub, even on full articulation?
  17. #33
    Jan 2007
    Thanked: 326
    None whatsoever
    Vic
