Jimny tyres 215/75/15 vs std tyres and 40mm lift
Results 1 to 20 of 33
    Nov 2017
    Gauteng
    Thanked: 21
    Default Jimny tyres 215/75/15 vs std tyres and 40mm lift
    Hi guys ,
    Plenty Jimny questions from me this side, my apologies in advance .
    What are your guys experiences with stock tyres and a 40mm coil spacer lift , vs 215/75/15 tyres on stock suspension?
    I have heard the tyres throw the gearing and consumption for a ball of poo ?
    We will be using the car mainly for Moz and Botswana trips through beach sand and dunes .
    What are your thoughts ?
    2011 Suzuki Jimny . 40mm zombie offroad lift , 215/75/15 tyres, 50mm powerflow .
    Disco 2 Td5, 3 inch lift, straight pipe, remap, egr delete, cdl mod, 32/11.5/15 all terrains. ( Sold )
    1985 Suzuki Sj410 , 970cc of stock Japanese power , 245/75/15 muddies , 2 inch lift . ( Sold )
    2016 Harley iron 883 , lowered , tank lift , wire tuck , fender delete, flipped mirrors , straight pipes . ( Sold )
    Various Volvo company cars over the last 6 years .
    2001 Polo Playa Millenium , stock besides 75hp nitrous shot. ( Sold )
    1987 Caddy , 2.1 16v Abf , 44mm throttles , 288 billet cams , 11.5 :1 compression. ( Sold )
    1981 Mk1 Golf , 1900cc , weber 38 dgas , 298 cam , tnt branch , 11.5 : 1 compression . ( Sold )
    Thanked: 1415
    Default Re: Jimny tyres 215/75/15 vs std tyres and 40mm lift
    My consumption is for a ball of poo - But offroad I smile a lot
    Sent from my iPhone
  3. The Following User Says Thank You to Rebel 4x4 For This Useful Post:
    FWM
    Nov 2017
    Gauteng
    Thanked: 21
    HAHA ! Are you on 215s with a lift or stock suspension ?
    Thanked: 1415
    Quote Originally Posted by ZUK410 View Post
    With a lift and heavy BF’s.
    But I don’t think the lift will make a major impact
    Sent from my iPhone
    Jun 2016
    Randfontein
    Thanked: 2081
    I'm on 215/75R15 Genreal Grabbers with 40mm spacer lift. I measured with the GPS and got 11.2km/l. The lift does not do much to fuel consumption its mainly the tyres. The bigger tyres does look a lot better than stock and has advantages offroad but lets be honest who buys a Jimny kits it out and worry about consumption. Its all about the offroad fun.
    Willie
    2020 Nissan NP300 2.5TDi S/C
    Nov 2017
    Gauteng
    Thanked: 21
    I'm on 215/75R15 Genreal Grabbers with 40mm spacer lift. I measured with the GPS and got 11.2km/l. The lift does not do anything to fuel consumption its mainly the tyres. The bigger tyres does look a lot better than stock and has advantages offroad but lets be honest who buys a Jimny kits it out and worry about consumption. Its all about the offroad fun.
    Not terribly concerned about the consumption , just wanted to know if its worth it for mostly soft sand driving , or if the 215s have a big impact on the low range gearing . I have heard a couple guys say it does . I dont want to put them on and then battle to get up dunes!
    I had an SJ410 with 245/15 Bulldogs and it seemed perfect to me in low range , although the final drive is lower on the SJ.
    Jun 2016
    Randfontein
    Thanked: 2081
    215/75R15 will be perfect for sand driving because you dont need to crawl in sand.
    We were in Namibia 2 months ago and found that 2nd and 3rd gear low range and tyres deflated as low as 0.6 bar worked very well
    Oh and don't be shy with the loud pedal the Jimny's got VVT for a reason
    Willie
    Nov 2017
    Gauteng
    Thanked: 21
    I like the sound of that !!
    215/75 /15s it is !
    Jun 2016
    Randfontein
    Thanked: 2081
    Which tyres will you be going for?
    Willie
    Nov 2011
    Hartenbos
    Thanked: 375
    It actually do. You increase your frontal area by lifting the vehicle.
    Cobus
    2010 Jimny
    Jun 2016
    Randfontein
    Thanked: 2081
    Quote Originally Posted by jab2 View Post
    So how much effect will a 40mm lift have in fuel consumption?
    Willie
    Mar 2011
    Walker Bay
    Thanked: 1068
    What brand of tyres were you using?
    QUOTE=FWM;3948060]215/75R15 will be perfect for sand driving because you dont need to crawl in sand.
    Oh and don't be shy with the loud pedal the Jimny's got VVT for a reason[/QUOTE]
    Jun 2016
    Randfontein
    Thanked: 2081
    We were a group of 5 Jimnys and 5 Gypsys
    The Jimnys had standard tyres on and the Gypsys had 215/75R15 General grabbers on.
    Even though the Gypsy has less power than the Jimny they still did everything the Jimnys did having bigger tyres than the Jimny.
    Willie
  15. #14
    Mar 2011
    Walker Bay
    Thanked: 1068
    Thanks - I always thought 0.8 bar was low!
    Even though the Gypsy has less power than the Jimny they still did everything the Jimnys did having bigger tyres than the Jimny.[/QUOTE]
  16. #15
    Jun 2016
    Randfontein
    Thanked: 2081
    0.8 bar will be low for a heavy vehicle but because the Jimny is so light you can go lower and as the sand heats up your tyre pressure goes up with it again.
    Willie
  17. The Following User Says Thank You to FWM For This Useful Post:
  18. #16
    Nov 2011
    Hartenbos
    Thanked: 375
    More than zero. Your frontal area increase with 2.4% and you create a larger channel of dirty air under the car.
    Cobus
    2010 Jimny
  19. #17
    Mar 2011
    Walker Bay
    Thanked: 1068
    In terms of litres/100km I did not find much impact with the lift - maybe due to my heavy foot!
    But as Jab2 said it must increase consumption and yes I did use more fuel but that included a roof rack which was fitted at the same time.
    While bigger tyres off road are excellent I found that tar travelling on hills was a real pain with gear changing and yes I do push the engine rev wise. I have since gone back to standard size. What a difference!
    But I do miss the great look of the big tyres on Jimny.
  20. The Following User Says Thank You to Paul Dold For This Useful Post:
    FWM
  21. #18
    Mar 2016
    cape town
    Thanked: 39
    We run 215/75/15 on steel rims and have 40mm lift, air helpers plus all the extra protection on the Jimny plus a roof rack and Thule, extra 40 litres of fuel on the towbar, fridge etc and record a fairly constant 8.5 to 9.5 km/l.
    Who cares my landcruiser ran at 3 to 4 km/l.
    Rather spend money on fuel than a heavy HP to some bank
  22. The Following User Says Thank You to Dirtrob1 For This Useful Post:
  23. #19
    Aug 2016
    Nigel
    Thanked: 22
    This might be a stupid question but is it the 215 of the tire or the hight 75 making the difference on the fuel and the power?
  24. #20
    Jun 2016
    Randfontein
    Thanked: 2081
    Quote Originally Posted by Edw1n View Post
    Both but the bigger profile has more effect than the wider tyre.
    Willie
