Results 1 to 4 of 4
    Strand
    Thanked: 37
    Default 2008 Pathfinder 4L V6 Auto.
    Problem fixed.
    Good day, I need some advice and assistance.
    I have the 2008 auto Pathfinder. This morning, as always, started the car, wait a couple of seconds, put on the safety belt, and engaged D. But, strangely enough, the car reversed. Check again, gear lever in D and instruments display R. But, the gear shifter is moving very lightly, as if no restrictions. Will not disengage R or move anywhere.
    Now, I know it could be the selector at the gear shifter. But, how difficult/easy is it to remove the centre console? At the moment I am at work, but will only have time this afternoon to check it out. The car cannot be taken to the dealers, it is parked in the basement and the low bed cannot enter. I will have to fix it myself.
    Any suggestions? I do not have the workshop manual either, therefor my asking here.
    Thanks.
    Ockert
    I might be a FOOL, but I am an OLD fool - from unknown.
    Jul 2013
    Thanked: 420
    Default Re: 2008 Pathfinder 4L V6 Auto.
    Bit early , Jelo is still sleeping.
  3. The Following User Says Thank You to janseekat For This Useful Post:
    May 2012
    Tussen die Bolandse berge
    Thanked: 285
    Did you sort out the problem?
    Nico Thiart
    Thanked: 17934
    Quote Originally Posted by janseekat View Post
    go climb a very tall tree and then do a backflip onto your head
    Jakes Louw
