How do I use tyre pressure to get better handling on different surfaces?
Results 1 to 20 of 27
    Cape Town Southern Suburbs
    Thanked: 1098
    Default How do I use tyre pressure to get better handling on different surfaces?
    I have a Honda CRV, softroader with basic AWD, I'm using the stock 15" rims and stock tyres are 205/70/15, on tar I ran 2.5bar.
    What kind of pressure ranges could be useful on surfaces like poor gravel roads with heavy corrugations, beach sand, mud and other surfaces I may encounter?
    How should I adjust my driving when dropping the pressure really low, I have seen people mention pulling tyres off the bead can happen if you aren't careful?
    Any other general advice in this regard is welcome.
    Edited it to be less specific.
    Cape Town or Jansenville or missing...
    Thanked: 3060
    Default Re: How do I use tyre pressure to get better handling on different surfaces?
    First tell us how long is a piece of string
    Thanked: 1098
    Quote Originally Posted by JohanSlabbert View Post
    I'm not expecting to get specific tyre pressures, just a general idea on what kind of pressure ranges to use on different surfaces, some tips from those that have experienced these conditions and which I can test when the scenarios arises.
    For instance driving on soft beach sand from what I have read 0.8 - 1.2bar could suffice?
    Thanked: 202
    Isuzu bakkie - 255/60 R18
    Tar towing : back 2.8 front 2.2
    Tar solo - not loaded : 2.0 front and back
    Gravel : 1.2 to 1.5 all round - lower if the roads are rough - possibility of side wall damage
    Sand : 1.0 to 1.2 all round
    Thanked: 3060
    I'm not expecting to get specific tyre pressures, just a general idea on what kind of pressure ranges to use on different surfaces, some tips from those that have experienced these conditions and that I can test when the scenario arises.
    Trial and error is your best teacher here, there are just so many variables that it's hard to give solid advice.
    What would be suitable pressures for decent gravel roads, poor gravel roads with heavy corrugations, beach sand, mud and other surfaces I may encounter?
    But I'll give it my best shot anyway.
    Assuming a light load and sticking to under 100km/h:
    Decent gravel: 1.8 bar
    Poor gravel: 1.5 but don't go above 80 for too long.
    Then:
    Sand: start 1 bar but you could drop to as low as 0.6.
    Mud: Some will say a hard tyre cuts through the mud better to the firm stuff underneath. I tend to drop the pressures in mud to around 0.8 bar. You'll have to see what works best for you and the vehicle.
    As for a tyre coming off the rim, unless you drive like a hooligan, above 0.8 bar there's not much chance of it happening. But good advice is to avoid sharp turns at any speed over walking pace. Better advice is learn how to put a tyre back on the bead with a good (fast) compressor.
    Like I said, many variables, for instance, an empty vehicle on a cold day could cruise for hours at 100 with the tyres at only 1.5 bar, but the same vehicle on the same road, same speed, same 1.5 bar, but fully loaded on a 45 degree summers day, is a recipe for tyre failure.
    Go play and learn, is the best way.
    Helderkruin
    Thanked: 399
    Slegte grondpad 1.5 bar
    Sand so 1 bar
    Modder bly my bande hard.
    Beste is maar om jou voertuig te gaan toets en kyk op watse banddruk doen hy die beste en as jy bietjie gelaai is ook.
  7. The Following User Says Thank You to Leon Venter For This Useful Post:
    Thanked: 185
    Really good advise from Johan.
    Beware mud. It turns any HT or AT tyre into racing slicks and than you are stuck. I found out that the in the Riversdal mountains when I started off-roading. Mud just clogged up a brand new set of BFG ATs and I were left with no traction/grip. I upgraded to mud tyres as soon as I could afford them.
    Blowing down is not only about floatation and a bigger footprint. It is also about comfort.
    Last time I did Gamkaberg, the campers next to me watched me blown down my tyres to 1.5bar. Their comment was that they do not need to blow down the tyres on their new Hilux DC, because it is a rocky trail.
    They left 30 mins before me and halfway up the mountain, I caught up with them. The 5 passengers looked like skittles inside the toyota bouncing of each other and the cab. We had a smoother ride (and faster (in 2nd gear low range)), but swambo was still complaining about the jarring. At the top campite, I blew down to 1 bar. Happy, smooth sailing from then on.
    We spent about 45mins at the top campsite before continuing on the trial. The hilux never got there... (And not because the toyota couldnt do a fairly easy trail, but I'm sure his bruised wife said to turn around)
    PS I never go over 80kph when my tyres are at 1.5bar or lower. Even on a national road after coming of a trail. Yes, I'm lazy and would rather pump at the next town.
    PSS Get yourself a little digital tyre pressure gauge. It is scary how inaccurate petrol station gauges can be.
    Isuzu Frontier 280LX 4x4 2001
  9. The Following 3 Users Say Thank You to RogueFrontier For This Useful Post:
    Thanked: 3060
    Quote Originally Posted by RogueFrontier View Post
    . The 5 passengers looked like skittles inside the toyota bouncing of each other and the cab. .
    Don't you know that's normal in a Hilux
    Oh, and spraying Kahlua over a keyboard makes for a very difficult cleanup...
    Thanked: 185
    Quote Originally Posted by Leon Venter View Post
    Hoekom?
    Thanked: 185
    Hey - jy moenie by die werk drink nie!
  13. #11
    Thanked: 3060
    Ek doen quality control
    Af gewees vandag
    I think the hard tyre in mud comes from the idea that a harder tyre will cut through the "slush" and find grip on the firm stuff underneath. Whereas a soft tyre will "float" on top and have no grip.
    But I'm in Cape Town and we haven't seen mud in a long time.
  14. #12
    Helderkruin
    Thanked: 399
    Hoekom?
    Dit is hoe ek nog altyd ry in modder en ry nogal heelwat modder nou op die oomblik ook.
  15. #13
    Thanked: 185
    Af gewees vandag
    A restaurant owner that gets time off is a rarity!
    I acknowledge there are hundreds of kinds of muds and I'm not a mud expert, I just have a healthy respect for it, but:
    I would want floatation, because when you start dragging diffs and chassis into mud, you have lost the fight. Just like sand.
    I want as big a footprint as possible to make every knobbly work for me. The cape mud is also more like a hard surface covered in an oil slick, than just a mushy swamp.
    And what I remember when I did product research into mud tyres, magazines doing mud tyre shootouts, the lower they went on tyre pressures, to further all the tyres went on the test track. That was common to all the articles.
    And comfort.
    Because I know I do not know everything, I would like to know the reasoning (and experience) behind other peoples' beliefs.
  16. #14
    Thanked: 3060
    And comfort.
    I can tell you this, on the Karoo farm roads that turns into clay when it rains, an old farm Hilux on hard (2.5bar) skinny tyres is a lot more stable at speed than with soft tyres. Sometimes the momentum carries you through patches where you'll get stuck if you stopped.
    But that's not strictly off-roading, more like muddy on-roading.
  17. #15
    Thanked: 185
    So far my strategy has worked for me. The KL71 at 1 bar have always stuck like velcro for me.
    In the cape it is also difficult to get away from any trail that doesnt involve mountains. You will be stopping often.
    Only once have I needed to attempt a pull away a 2nd time and that was doing switch backs up the side of a mountain on a trail rated 3 in the dry. I went and did it in pouring rain.
    PS I'll be seriously impressed with your farm mud if you couldnt pull away the jeep in it.
  18. #16
    Thanked: 1098
    Thanks for the great tips and advice guys, just what I needed.
    Are there things to be careful of when negotiating beach or river sand?
    I'm assuming keeping you speed up helps, should you always plan to stop in a location that's easy to drive off from, perhaps with a slight downhill?
  19. #17
    May 2010
    Thanked: 217
    Yes downhill or flat is better than uphill. Also just try stopping as smoothly as possible - try to keep the sand piling up in front of your wheels as little as possible - if you dont need to dont use your brakes when stopping just coast to a stop.
  20. The Following User Says Thank You to JurgenSteyn For This Useful Post:
  21. #18
    Sep 2015
    Thanked: 119
    Although not asked, on tar one can try over inflated the rear tyres slightly if you normally experience a lot of under-steer. All four of my tyres break traction at the same time now when pushed hard into a corner.
    When going down any terrain with less grip, use engine braking in gear and just jab the brakes as required.
    In the Kgalagadi, you often travel in soft, corrugated river sand (first pic), which is why you see this sign (second pic) at the filling station.
ID:	495982   Click image for larger version.
    Renault Duster 4WD Gen1: No Meow
  22. #19
    Thanked: 829
    All my perceptions (and experience) regarding tyres and tyre pressures went out the window after a week of game drives in Botswana - 7.5 x 16 pumped to 3.5bar!!
    FJC - Just Cruising
  23. #20
    Mar 2007
    Thanked: 719
    For general off-road driving I deflate to 20% below normal tar road pressure and for sand to 50% below normal tar road pressure
    Johan 😎
    2011 Daihatsu Terios 4x4
