D4D vs GD6 XCab Load bin size
Results 1 to 3 of 3
    Jul 2018
    Default D4D vs GD6 XCab Load bin size
    Hi All, so what is the size difference between the two? Would a canopy off a D4D fit a GD6, or not at all?
    I'm in the market for a canopy, and can get nice 2nd hand deals but I'm concerned it might not fit my GD6
    Brackenfell
    Default Re: D4D vs GD6 XCab Load bin size
    Gd6 is wider than the d4d. Wont fit.
    Nov 2016
    A D4D canopy will actually fit on a GD6. We put my bosses RhinoCab from his previous D4D D/C on his new GD6 D/C without a hassle. The inside bin dimensions are the same, but the GD6 had a narrower top width on which the canopy sits, because of this the canopy had some excessive overhang at the rear although still 100% supported. Also the canopy is 50-100mm higher than is should be so it sticks out above the roof line
