Using different solar panels in parallel
Results 1 to 4 of 4
    Pennington
    Thanked: 37
    Default Using different solar panels in parallel
    My new carvan has an HCDP power pack. the solar input is 270w max, but i'm told that the max open circuit voltage is 26V.
    The van is to have a 160W panel fitted to the roof which is removable if required, Voc is 21.9V.
    I currently have a pair of 50W panels that fold-up and have used these with my trailer the Voc is 21.0V on the 2x 50w.
    My question is, if needed could I connect all 3 to give me 260W or is this a bad idea.
    Okahandja, Windhoek
    Thanked: 410
    Default Re: Using different solar panels in parallel
    Should work, the volts is close enough.
    Johan Kriel
    LC PU's and a Prado
  3. The Following User Says Thank You to JLK For This Useful Post:
    Thanked: 448
    Simply connect all 3 in parallel (or 2 of the 3) - no problem with that.
    Eggie.
    - apology to Edward Langley.
  5. The Following User Says Thank You to Eggie For This Useful Post:
  6. #4
    Thanked: 9
    Cancel
