Carb Balancing Tool......where to get/how to make one??
Results 1 to 20 of 26
    Bethlehem
    Default Carb Balancing Tool......where to get/how to make one??
    Does anyone know where to get a Carb Balancing Tool, soecifically to work on the Pinzgauer's twin Zenith carbs?? It's a in line 4 cylinder aircooled motor, petrol 2500cc.
    Or is there a way to make something "makeshift"??
    THANKS
    Of COURSE I have a Bad Habit. I take Tea at Three (Mick Jagger)
    Rangeview Krugersdorp
    Default Re: Carb Balancing Tool......where to get/how to make one??
    Before JvR landed I had a length of 3mm pvc tubing nailed to a board in 2 S s shape and filled with very light oil. Balanced SU s perfectly
    Chev Aveo and Atos and Polo.
    Bethlehem
    Duncan.......please some more detail?? Or a link or something??
    Thanksamill man. Seems like we may have that miss out of the Pinzie, but I need this done, too
    BAIE DANKIE
    BAIE DANKIE
    No idea how to post youtube here. Ask Mr Google about a home made mannometer. Lots of examples.
    Posted in pub for you
    Hillcrest, Malaysia
    Sorry I cant help apart from saying decades ago I would have used a stethoscope or "listening tube"
    But a little story. I knew a guy who was a friend of my dad that had a second hand car dealership.
    So Sunday morning he wakes up and decides the 12 Cylinder Lambo is not idling so smooth. Hauls out the screw driver and starts fiddling with the 6 Double Barrel Dellorto carbs. In no time the car is rougher than a bears a$$ and he cant fix it.
    Keep in mind this was around 1980. Only solution eventually after trying all avenues - fly a mechanic out from Italy with the knowledge and tools to fix.
    Balancing manual carbs is not for the fainthearted.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Cape Town, Plumstead/The Sea/Franskraal
    And the GX and SSS ran lekker!
    Have now covered 270 000Km on veg oil.
    Oh, and an Isuzu 280DT, 40 000Km on Bio Diesel
    Rand for Rand gets 33Km/L
    Randpark Ridge
    Petri
    I take it you are looking at one of the following
    The glass tubes use mercury got it from a bike shop for my bike, the other as a part of a workshop clean out.
    Can offer you a loan unit till I rebuild my 500 twin and Z750e
ID:	494568   Click image for larger version.
ID:	494569   Click image for larger version.
    Discovery 3 TDV6 S G4 No 29 - Mine
    Discovery 4 TDV6 SE - SWAMBO's
    Jun 2012
    Pretoria East
    Oom Petri. My advice, buy a tool from Highveld Garage in Pta - http://www.hge.co.za/index.php?route...scription=true for not much money and rather pay someone some good money to teach you how to use the synchro tool. Spend money once and from then on you can do it yourself (or if you mess it up you know who to call and have the tool to fix it).
    Quote Originally Posted by ZuluCowboy View Post
    And the Mini's carbs cost more than the car whilst the Cortina's wheelarch had to be cut away to fit the pair of DCOEs
    Nigel
    Pull all the plug leads. But put them on so that they still can spark.
    Now start the engine.
    Pull off each lead and listen to the revs. The revs must drop equally on every missing spark lead that is disconnected.
    Voala
    Uniglide
    +27 zero eight 2 four 95 9252
    I tried it last night with my daughters 125cc scrambler. Works like a charm! Every time I pulled the plug the revs dropped to 0.
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    Kemptonpark
    Some advice, make sure your carbs have the ports/connections to use a setup like rabbitdog, as there was another type you placed over the intake of the carb.
    2007 TDV6 S
    ARB BB and winch,BRS HD tow bar,TT and EGR's blanked,RR with dual awnings,Duel batterys,Custom long lange tank,Centre mount fridge,Custom rear box,Custom internal water tank 65Lt,Custom dash consol,Custom swing out spare wheel carrier, Adjustable 50mm suspension lift, SDV6 3Lt conversion.
    Bethlehem
    Voala
    Henri baie dankie
    Bethlehem
    Randpark Ridge
    Quote Originally Posted by discoeast View Post
    Didn't know about that.
    All the bikes, cars and boat motors I have worked on used the vaccume tubes.
    Kemptonpark
    Quote Originally Posted by rabbiddog View Post
    I agree, while I found the thread interesting I wanted to know what carbs were fitted to that engine, did the Google thing and found that it was a Zenith - NDIX 36. From the few exploded views I browsed I found no mention of a vacuum port, there may well be one, but did see pics of people using the one I posted, hence my post.
    2007 TDV6 S
    As I opened the forum my eyes caught this thread . And my first reaction was ! I got one.
    Just yesterday I was sifting through some stuff in a very special crate I was hiding under some things in the corner of the store room.
    Guess what was in there ? a carb balancing tool.
    On that moment a was thinking way back about all the SU and Weber carbs I sat for hour with !
    Quote Originally Posted by DVR View Post
    ..and the permanent small bottle of 3 in One oil in the cubby hole ?
    Constantia Kloof
    What you need is a "snail gauge", it will be much easier to use than traditional vacuum gauges. In addition you will find a wide band AFR meter a great help too.
    Then, as was mentioned above it would be a good idea to spend some time with someone who knows how to set carbs. You cannot do it when the engine is cold and you have to know the manufacturer's recommended setup procedure.
    The carburettors on the Pinzgauer are antiquated, no really, Zenith as a brand faded away more than 40 years ago so parts and jets are expensive, if you can source them. In your shoes I would have been looking at replacing them with throttle bodies and basic fuel injection or even a set of 36mm downdraught Webber units for which rebuild kits, venturis, emulsion tubes and jets are readily available if you know where to look.
    By all means keep the original carburettors and manifolds for the next owner who wants absolute originality but trust me when I say you would be streets ahead starting with a more modern and/ or tuneable fuel system if you want to actually enjoy and use your vehicle.
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
