Mabua to Nossob - Michelin Primacy SUV tyres?
Results 1 to 7 of 7
    Mar 2012
    Thanked: 123
    Default Mabua to Nossob - Michelin Primacy SUV tyres?
    I have Michelin Primacy SUV tyres 255/60/18 (more of a HT tyre if you ask me). I will be driving the sand road Mabua to Nossob on these "city tyres" Will be towing. Previously used Hankook AT tires 265/65/17 which did me proud in sand anywhere and towing. Yes I plan to lower pressures down to about 0.9 bar or less if needed. I have never driven this road but the reports I have read indicate "not too bad" so I am thinking it should be ok - maybe! If anyone has done this journey with "oridinary" non AT tyres - I am keen to know your experience.
    "To look is one thing, to understand what what you see, is something else"
    Amarok AUTO 4X4
    Out fitted Offroad Trailer
    Morgan Bay Eastern Cape
    Default Re: Mabua to Nossob - Michelin Primacy SUV tyres?
    Never done it in a none AT tyre but should be ok if the tires are still good should only get punchers from sticks in the sand
  3. The Following User Says Thank You to sakkie stone For This Useful Post:
    Mar 2013
    Molopo
    Thanked: 147
    I haven't done the route with a HT type tyre, but knowing Kalahari sand tracks very well I suspect you will be fine with your tyres.
  5. The Following User Says Thank You to HannoK For This Useful Post:
    May 2018
    Default Re: Mabua Khiding campsite to Nossob
    Hi all,
    Is it possible to drive from Mabua - Khiding campsite to Nossob in one day and how long would it take?
    Thanked: 518
    It is a normal track.
    No really thick sand. Most of the surface up to Matopi 1 is relatively hard track.
    The only softer sand is at the main dune about 19 km from Nossop.
    It can take 7 hours if you towing. It was 5 hours, last time 7 hours due to corrugations.
    At times the road is worse than a corrugated normal Kgalagadi road. Mostly approaching Nossop.
    This is a pic of the high dune, but it is not bad at all.
    Also do not loose momentum at the top as at times people get very stuck and mess the track up leaving big holes.
    I get up that hill with a 300tdi TOWING an Echo 3.
    What I do is ride about a 1/4 way up THROW SWAMBO out and then reverse back so that she can give me the all clear for vehicles.
    BUT, it is Lion and Leopard country, so think about what you are doing, that is why I throw her out
    As you must have been reading, BEWARE of people Racing on that road.
    As an experienced Suurgat I have seen lots racing on that track even after gate closing times.
    Sitting at Matopi you can see or hear the vehicles.
    It is not easy to tell if a vehicle is approaching on the blind side of a dune, rise or corner.
    Take a break at Matopi 1, but if someone is camping then I just stop in the entrance portion so as not to disturb the people.
    Defender Kalahari
    Series 3 SWB
    Series 2 SWB (Near Future)
    Series 1 Station Wagon 88''
    Mar 2012
    Thanked: 123
    Many thanks Imgreg for good info. Will let you know how it goes - will be in park 6 Aug.
    Amarok AUTO 4X4
    Mar 2012
    Thanked: 123
    Quote Originally Posted by imgreg View Post
    Some feedback - finally did this trip - Mabua to Nossob towing. As most said - it was fine and no problems. Thanks again to all for the help and comments.
    Amarok AUTO 4X4
