Run-in oil?
Results 1 to 16 of 16
Thread: Run-in oil?
    Aug 2016
    Thanked: 16
    Default Run-in oil?
    So the 300tdi has been rebuilt and is running smooth, starts immediately, and more importantly no leaks or knocking anymore.
    Here is a question I have been wondering about though. Do people still use run-in/break-in oil and if yes which do you use?
    Thanked: 11390
    Default Re: Run-in oil?
    SAE30 was always considered the correct oil.
    on old minis we did the following:
    500km maximum on SAE30 then new filter and a decent multigrade for the next 1500km. No synthetics.
    Then normal service intervals.
    Aug 2016
    Thanked: 16
    Is a 30 oil not to thick for a turbo engine? I'm using Penrite 15w40 running in oil for mine. Was just curious if people still used running in oils.
    Springs
    Thanked: 277
    i use only SAE40
    going to 30 may cause oil pressure to be insufficient when hot.
    it compared in viscocity with the 5W40 most engines run on.
    i normally try to find oil with as few additives as possible as the additives hamper the ability for the rings to bed in properly.
    run for 2000 - 5000km and then flush and replace with good quality oil.
    also replace the oil filter
    Jan 2007
    Thanked: 38
    I FCYou can get run-in oil from John Deere (bought at Delmas agent). I used it after my 300tdi rebuild in Jan 2016, drove 2 000 kms with it and from thereon Caltex Delo 400. I can't notice oil consumption between services (normally change oil between 5 000 and 6000 km).
    krugersdorp
    Thanked: 470
    not sure what they use, but i just bought a land cruiser v8 diesel, wanted to do a oil change after the first 1000km, was told not to because it has running in oil in it. something to do with soap and other stuff.
    2010 d4 v8 hse hers
    2018 D/C CRUISER V8
    Dec 2009
    Thanked: 225
    SAE40 for 1000km. Drain, new filter and a premium 15w40 for the refill
    Toyota RAV4
    Chevrolet Utility
    Centurion, Pretoria, SA
    Thanked: 339
    Running in oil is not about the viscosity, it is about the additive level. Running in is a process where you are allowing wear to take place under controlled conditions. Whether you use an SAE 30 or an SAE 20W50 is not going to make any difference for the run in.
    To allow wear to take place / run in you need an engine oil with a low anti wear level and for the tdi you are looking for an engine oil with an API level "CC". It might appear as an API SF / "CC" which will be fine as long as it has the "CC". This can be in multigrade (eg 20W/50) or monograde (eg SAE 30). You might have a bit of a hard time finding something as low as "CC" but they are around.
    That spec oil is only suitable for 1000 km run in period.
    I will PM you my number if you need to confirm / discuss available specs when you are shopping.
    SOMETIMES I WAKE UP GRUMPY,
  9. The Following 4 Users Say Thank You to Sneaky Pete For This Useful Post:
    Dec 2009
    Thanked: 225
    Midas liquid gold SAE40 used to be a good running in oil. But haven't checked the spec for a while.
    Ravenol makes a good running in oil (labelled as break in oil) maybe give them a call? It is a SAE30
    www.ravenol.co.za
    Toyota RAV4
    Chevrolet Utility
    Swakopmund
    Thanked: 166
    To complicate matters, the question must be ask how to do the run in of a new engine. I changed oils at 1500km to a very good quality mineral oil. The run in was done with a long trip where you accelerate and decelerate on piston compression... Just my way of doing it.
    2014 Land Cruiser 76 V8 SW
    1994 Defender TDi 200
    Drive it like you stole it!!
  12. #11
    Wartburg.
    Thanked: 537
    I have always believed, motor must labor but not rev high
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
  13. The Following User Says Thank You to Chris8d For This Useful Post:
  14. #12
    Wartburg.
    Thanked: 537
    Idling around doesn't help it
  15. The Following User Says Thank You to Chris8d For This Useful Post:
  16. #13
    Thanked: 11390
    Quote Originally Posted by _FC View Post
    Which is an SAE40 base with some additives.
  17. #14
    krugersdorp
    Thanked: 470
    running in needs to be done, drive slowly until the motor and everything is warm, rev and drive it like normal, do not labour the motor, but you must drive it like you stole it one in while, i think it is all about getting it hot and cooling it down, at the correct times. no use never reving it over 3000 and then after so many km, you drive it like you stole it. it needs to as far as i understand seat properly or whatever you call it. so it must be revved to the limit some times during the running in period. if anything is going to go south it should go in the running in period.that's just my take, and how i have done it in the past.
    2010 d4 v8 hse hers
    2018 D/C CRUISER V8
  18. #15
    Thanked: 11390
    This is how we used to do it on tight new thumper engines:
    first 100kms: vary throttle between 1/3 and 2/3: vary often, don't run one speed
    next 300kms: vary throttle between 1/4 and 3/4: vary often, don't run one speed
    next 100kms: As above but occasionally take throttle up to full open for short bursts then CUT the throttle on a downhill to allow full compression engine braking: this allows the final bedding in of the compression rings
    Service.
    Then drive it like you stole it for HALF a service interval and service again.
    FILTERS MUST BE REPLACED AT EVERY OIL CHANGE.
    We used a similar process on Mini and Essex engines: just used a rev counter to determine engine RPM instead of throttle opening.
    As mentioned: DON'T LUG the engine excessively at any stage in the run in period: 1000rpm is possible for most diesels, but I'd say 1200rpm is a better RPM. A 300TDi should be happy anywhere between 1200 and 3000rpm during run-in.
    I'd say 3400 should be your peak RPM, but I'm no expert on that engine, and I suggest getting it to 3400 and chopping the throttle closed, don't keep it there
  19. #16
    Jan 2007
    Thanked: 38
    As said by many above, a run-in oil must provide just the necessary amount (bare minimum if possible) of lubrication and must not have fancy anti-frictions additives so that piston rings can bed in on sleeves properly. Since a well known company such as John Deere sells specifically a run-in oil, that is what I have used and whilst it was fairly expensive (+/- R700 per 5 l x 2) I believe it is money well spent.
