Td5 leak around the fuel pressure regulator
Results 1 to 20 of 24
    Oct 2014
    JHB
    Thanked: 20
    Default Td5 leak around the fuel pressure regulator
    Howzit guys,
    Today I noticed this leak coming from the area where the fuel pressure regulator sits.
    The body itself was clean but both pipes were covered in rubbish.
    Is this 100% the whole unit that needs to be changed or are there seals in the pipes coming from the regulator that can be changed?
    I have had no issues with starting and the car runs fine
    Picture of what it looked like before I cleaned it.
    Thanked: 1205
    Default Re: Td5 leak around the fuel pressure regulator
    The leak is probably from the body of the fpr, the diesel then blows back/drips onto the pipes. Feel if the back of the fpr is wet. I have seen the replacement part on gumtree but have never tried it..Its that silver round part that leaks.
    Oct 2014
    JHB
    Thanked: 20
    To be safe:
    New Fuel pressure regulator
    New gasket (body to engine)
    New o-rings for the pipes (are these included with the FPR?)
    Does this sound right?
    Thanked: 1205
    You can try replacing just the orings where the pipes go into the body, any oring that copes with fuel will do, then you dont have to change the body. It depends on where its leaking from.
    Oct 2014
    JHB
    Thanked: 20
    I'll inspect it tomorrow and see if I can find the leak. Thanks for the help
    Jan 2015
    Thanked: 198
    Had the same issue. Replaced the o rings and bobs your uncle. LR will try to sell you a new unit.
    2002 Discovery td5
  7. The Following User Says Thank You to Nambro For This Useful Post:
    I had a similar issue with that particular fuel line, but on the opposite end from the fuel regulator. Fuel was leaking on the bend of the fuel line just below the yellow rectangular area on the attached photo. It is so cramped in there I couldn't see whether the issue was on the fuel line itself or one of the o-rings. Took it to my local indie and ask for the entire fuel line to be replaced. In hind sight though it could have been one of the o-rings that needed replacement.
    2011 RRS HSE Lux
    2002 Disco 2 Td5 GS A/T
    Nov 2017
    Thanked: 7
    Quote Originally Posted by Nambro View Post
    +1
    Just a mission to get it off on a D2.... Lots of swearing took place!!
    Price on o-ring is about R5 each and the metal gasket about R24. New britpart unit is about R2900
    Discovery 3 V8 SE 2007
    Discovery 2 TD5 2002 (485k km)
    Jan 2015
    Thanked: 198
    True on that one. Scraped nuckles tools falling down etc.
    2002 Discovery td5
    Dec 2014
    Thanked: 1840
    Not to mention that ONE bolt or nut you drop that never makes it to the floor, leading to an increase in volume and quality of the swearing.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Nov 2017
    Thanked: 7
    You know what, to be honest, if I need to do it again, I might consider removing the intake manifold and have plenty of room to make sure everything is properly fitted and torqued to spec. Gasket for the intake manifold is R58.
    Depends on time available to do the job.
    Also a good time to look at the condition of the core plugs x3 and maybe replace them as well while you have all that stuff off.
    Dec 2014
    Thanked: 1840
    Quote Originally Posted by Dee's View Post
    I would not even contemplate doing it without removing the manifold!
    My hat's off to you for that!
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Oct 2014
    JHB
    Thanked: 20
    +1
    Where can I get the o-rings? LP4A doesn't have. Going to Dover on Monday I'll see what they have
  15. #14
    Thanked: 1205
  16. #15
    Jul 2019
    Default TD5 Fuel pressure regulator recommendation please
    Guys, recommendations please on a new FPR for TD5 D2?
    I have replaced 2 of them in the past 2 months. Both of them were Britpart which I got from Dover parts. The first failed within a week or two and started dripping from the pressed casing. On closer examination, (I cut it apart) it turned out that the diaphragm had failed where it was crimped into the side of the casing. I think due to a tooling problem in manufacture.
    I got a second one, and it seemed to be fine and has been since December, but this weekend it failed catastrophically pumping out half a tank of diesel in the 15 minutes it took me to get home. It was squirting out of the exit pipe on the pressed casing so can only assume its another failed diaphragm.
    Can you guys recommend something other than the britpart one? I understand that the landy OEM ones also give problems.
    PS. having taken it out and put it back in quite a few times now, I am becoming a bit of an expert at it. Strongly recommend removing the bolts holding the fuel cooler in place and moving it slightly aside. Creates just that bit of extra space needed to properly get in there, especially when torquing up the bolts.
    I also replaced the standard mounting bolts with socket head cap screws (Gr 8.8) which made a world of a difference in terms of keeping the tool in place while tightening or loosening.
  17. #16
    Feb 2019
    Paulpietersburg
    Default Re: TD5 Fuel pressure regulator recommendation please
    Quote Originally Posted by dudleybza View Post
    I'm having exactly the same problem currently and bought the same as you from the same company. My FPR lasted 2500km since 15 January 2020. I was forced to look for the old leaking one just to avoid the whole tank being drained in 22km trip home.
    It's a Bosh FPR that completely failed.
    Please let us know if you find any other brand that's reliable. According to the salesman that I spoke to, it's the first time that the FPR that they sell totally fail.
  18. #17
    Oct 2015
    Thanked: 94
    Hi Wihan
    I have a Td5 Defender and had that leak as well. I got a Bosch one and its holding up. It seems that I should get a spare if that is what happens when it fails to get to the nearest help. Other than that I have no advice.
    ONE LIFE!
  19. #18
    Sep 2018
    Thanked: 21
    Had the same problem creep up the day before lockdown started. Diesel dripping off the bell-housing.
    I managed to get a replacement (just the regulator) from Goldwagen today for R357. Managed to remove the circlip and pull out the old one without removing the whole assembly or pipes, pushed the new one in and replaced the cir-clip. All seems well now, will just have to see if the part holds up.
    For anyone else that doesn't want to replace everything it is possible to just replace the regulator. Please note - I could see the leak so knew it was not the hoses or gasket so no need to break the seal and replace them. When I got the old one out I could see the 2 o-rings were damaged which confirmed my thoughts prior.
    I used a small mirror to see the clip and had a 90 degree arm on the cir-clip pliers. All in all took me about 20 minutes.
    Will get new o-rings and keep the old as a spare for now.
  20. #19
    Oct 2015
    Thanked: 94
    Hi Travisty
    Thanx for the post. I have got 2 questions.
    If it was only the O rings wouldnt it be cheaper to only replace them instead of the regulator? They are odd size though.
    I tried Goldwagen but they could not help for the ones they got was below 4 bar. Are you sure the one you got are for 4.2bar? ( I think the system runs at 4.2bar. )
    If so what is the partnumber? I will get one as a spare.
    Thanx
    ONE LIFE!
  21. #20
    Sep 2018
    Thanked: 21
    Hi Travisty
    Thanx
    Hey Wildkyker,
    They would be cheaper yes but during lockdown its hard to get parts so just bought the whole thing as it's my daily driver as well and need to get around now.
    It is a 4.0bar unit, took it for a drive around the block and don't notice any difference power wise, if it battles on the open road I will get the OEM or Bosch part and keep this as a spare. I also don't go over 2500rpm or 100kph so might not effect me as much.
    p/n 0280160575
