Platic can
Results 1 to 8 of 8
Thread: Platic can
    Apr 2008
    Boksburg
    Thanked: 18
    Default Platic can
    Where can I buy a can (or similar) than this. I bought this one years ago in PE but the sun has taken its toll. The normal outlets don't have any
    Chris
    2010 Pajero GLX
    Imagine Comfortvan
    Gaborone, Botswana
    Thanked: 572
    Default Re: Platic can
    I saw some at Puritech in Midrand the other day.
    Here it is https://www.puritech.co.za/20l-bottle-tap/
    Kobus
    HDJ81 VX
  3. The Following 2 Users Say Thank You to KobusDJ For This Useful Post:
    Mar 2013
    Thanked: 14
    Good morning
    I have seen similar a Plasticland, but only know of two shops. One in Centurion and one in Woodmead. Unfortunately I do not know your area, but there should be similar stores.
    2008 KB300 D-TEQ 4x2
  5. The Following User Says Thank You to Namakwalander For This Useful Post:
  6. #4
    Melkbosstrand Cape Town
    Thanked: 53
    Plastics for Africa have them made by Pioneer plastics.
  7. The Following User Says Thank You to Andrew Rodrigues For This Useful Post:
  8. #5
    Thanked: 184
    Quote Originally Posted by visconeng View Post
    See OP ,apart from that I would fix it with Fibre Glass mat etc.. Look at the air vent.. A drinking water bottle spout pull out and you have an air vent. Brilliant.
  9. #6
    Apr 2017
    The best buy ever is the blue water jerry can availabe at most outlets. For R100 more than the plastics you get something lasting 10 years!
    Note you cant use the green jerry cans for water! Its intended for petrol.
    Toyota Hilux 3D
    BL976 - Baobab 4
  10. #7
    Apr 2008
    Boksburg
    Thanked: 18
    @Janseekat, that mod became necessary because I didnít close the breather cap properly and lost it. I could not find similar size & thread.
    I have come right by following the guide to Purtech. Will collect next week.
    Thanks for the advise
    Chris
    2010 Pajero GLX
    Imagine Comfortvan
  11. #8
    Thanked: 184
    Way to go. The tap on the can looks more efficient than the pioneer plastic jerry can tap .I have 2of those and the taps are bas... to open
    Groetnis
