Trailer design - where are the clever guys - Page 4
Results 61 to 73 of 73
  1. #61
    Feb 2008
    Thanked: 360
    Default Re: Trailer design - where are the clever guys
    This has turned into a full-on design review - with calculations! Thanks for all the help guys!
    I must just make it clear that I am in concept phase and no detail is sorted out yet. I am taking all the advice into consideration.
    Overkill - isn't!
  2. #62
    Jan 2015
    Pretoria, Akasia
    I said in the start of thread the A frame should be Channel. It is pointed out that the the rectangular 100x50x4 for the main frame is also a problem. Maybe you should change that to channel as well. The difference is only 1.1kg per meter.The problem is that side gate. If this was a dedicated cattle trailer the complete welded structure will make it strong. But you have a big bending moment right in front of the front shackle. Normal flatbeds are 250 or 300mm deep there. If you can move that gate behind the mudguard it will be a plus.Floor structure, you can seal the joints with a proper seam sealer. Den Braven Polyflex, or tectane, or Sikaflex. These products are paintable. Plan B is to leave a gap of 10mm between pans. But a big bull may bend it then. 2m is a long span.
    Kind Regards.
    Wikus Beetge.
    Discovery 3S TDV6 2007
    Hilux KZTE single cab 2001
  3. #63
    Feb 2008
    Thanked: 360
    Any thoughts on mounting the springs on the inside of the chassis instead of below it? It will further reduce deck height.
    Overkill - isn't!
  4. #64
    Robertson/ Larissa, Greece
    Thanked: 1211
    Going Amarok! Same principle
    I'm not arguing, I'm just explaining why I'm right!
  5. #65
    Feb 2008
    Thanked: 360
    Drew it...... Crappy idea..... abort!
    Overkill - isn't!
  6. #66
    Apr 2011
    Hartbeespoort
    Thanked: 20
    Default Trailer design - where are the clever guys
    Not so crappy look at the way they are done on trucks.
    Easier to brace for side flex spreading the chassis load from the spring pack mounting points over a greater area.
  7. #67
    Feb 2008
    Thanked: 360
    Yes, but trucks has pressed steel chassis. Not straight channel chassis.
    Overkill - isn't!
  8. #68
    Feb 2008
    Thanked: 360
    The drawings has been sent to my manufacturer. It will be painted Cruiser Khaki - that should add another 50 GPa to the Young's module of the material.
    Full Channel frame - C100x 50 taper flange
Name:	WhatsApp Image 2018-07-16 at 20.24.06.jpg
    Section through the model showing the deck plates. 2mm gap between the plates which I may fill with silicon or may not....
Name:	WhatsApp Image 2018-07-16 at 20.22.55.jpg
    Stiffening where the a-Frame meets the loadframe
Name:	WhatsApp Image 2018-07-16 at 20.21.43.jpg
    Suspension mounting cradle and balance beam:
Name:	WhatsApp Image 2018-07-16 at 20.22.17.jpg
    CoG:
Name:	WhatsApp Image 2018-07-16 at 20.28.48.jpg
    Overkill - isn't!
  9. #69
    Jan 2018
    Thanked: 17
    CoG:
    Hi Uys
    What contribution do you envisage those haunches as having?
  10. #70
    Feb 2008
    Thanked: 360
    Quote Originally Posted by Learnercamper View Post
    Hi Uys
    hmmm..... had to read that 4 times.
    I asked myself the same question and arrived to the conclusion that if they don't do much, at least I like it.
    Overkill - isn't!
  11. #71
    Jan 2018
    Thanked: 17
    Looks really good, nice drawings!
  12. #72
    Feb 2008
    Thanked: 360
    Thank you!
    Overkill - isn't!
  13. #73
    Feb 2008
    Thanked: 360
    And so it begins.
    I got some quotes to have it build and soon realized that this is not an economical option.
    So Kiepie here will have to get his hand dirty.
    The first components are ordered an in process. I am keeping a cost sheet which I'll update as the build goes along.
    Here is where we are now:
Name:	Trailer costs.JPG
    Overkill - isn't!
