The truth about snowmaster - Page 5
Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 81 to 100 of 109
  1. #81
    Barberton
    Thanked: 1441
    Default Re: The truth about snowmaster
    Quote Originally Posted by CornelisVoigt View Post
    PM sent
    Good luck. That add is 11 months old.
  2. #82
    Thanked: 1032
    I have an 80litre SM and as of yesterday the left compartment has overridden the preset temperature. It basically went down to minus 25. It was set at 6 degrees.
    The right compartment is working perfectly. The fridge is not even a year old and is only used in the house to keep my beers cold.
    Anyone know what could be the problem?
    Toyota Fortuner 2.8 GD-6 4x4 Auto
  3. #83
    Bosveldsig, Nylstroom/Modimolle
    Thanked: 215
    Quote Originally Posted by Caracal View Post
    Take it to SnoMaster, mine did the same after many many years and 3 drops.
    Mine was to old and SnoMaster would repair it but with no warranty.
    Think they give a 5 year warranty, so might be a better option
    Danie & Marinda - die wiele is rond, dus moet hulle hardloop - afgetree nou leef ons net.
    2017 BL - Kewer B1115 RUS WA GP - bos en kamp tyd
    2016 Ford Fiesta Ecoboost - daaglikse ryding
    2013 Ford Ranger 3.2 DC XLT 4x4 - nuwe rondloop ry ding, nou sleep ons! (2017)
    2011 Echo 4, die RUSWA-ZN - (verkoop 44 000 km)
    2010 Ford Ranger 2.5 DT DC XLT 4x4 - rondloop ry ding met "bietjie ekstra" krag (Verkoop 177 000 km)
    2005 Chev Aveo - Afgeskryf (2016 130 000)
    2005 Opel Corsa 17DTi - Geruil (warm enjin 180 000)
    2003 Opel Corsa 17DTi - Geruil (warm enjin 150 00)
    2000 Nissan Hardbody - Geruil (pyne by die duisended 52 000 km)
    1998 Opel Kadett - Dogter se wiele geword in 2003 (baie warm enjin 116 000 km)
    1990 Datsun 1800 short wheelbase - Pa se ou plaas bakkie, na die Nissan die pad gevat het met sy probleme in 2003 (117 00km)
    1990 Hilux 2.4D - en hy kon loop, pomp en top gewerk aan.
    1984 Opel Commondore - het gehardloop
    1983 Safary 3 karavaan - verkoop en begin tent in 2000 (51 000 km)
    1980 Ford Granada 3.0 - warm enjin afgeskryf
    1969 VW 1600 TL - geen einde nie, warm enjin en geruil
    1968 VW 1600 L - geen einde en baie warm enjin, verkoop in 1998 (328 000 myl/525 000 km)
  4. #84
    Centurion, Pretoria, SA
    Thanked: 404
    Quote Originally Posted by Danie S View Post
    Is Johan here on the forum still active?. Seem to remember some problem or was it another member?. He is in Lynnwood. Search the forum.
    Peter
    SOMETIMES I WAKE UP GRUMPY,
  5. #85
    Sedgefield
    Thanked: 83
    I have had this before on quite a few occasions, mainly when switching from mains to 12v or visa versa, and when the temp reading is below the set temperature.
    I found that when switching power sources, I leave it off for around 10 min before switching it on again, or just leave it on the battery all the time with a charger on the battery.
    I think it has something to do with the solenoid valve that directs the refrigerant to either side, getting confused.
    Toyota
    2019 Toyota 2.8 GD-6 4x4 Raider DC Auto
  6. #86
    Thanked: 653
    Rule No 1 ..Spend an extra R 1K and get a Luna ..Fridge Break downs cant be fun out there
  7. The Following User Says Thank You to Peter Betts For This Useful Post:
  8. #87
    Thanked: 941
    Quote Originally Posted by Peter Betts View Post
    Yes there are absolutely no threads on the forum about National Luna ever having a problem
    ***facepalm***
  9. The Following 7 Users Say Thank You to Half-Pint For This Useful Post:
  10. #88
    Plett/Paulshof
    Thanked: 1217
    You really should learn when to keep quiet. A brand new NL I got with my Boskriek broke down just as we were preparing to leave for a trip.
    Bruce Hunter. 2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa Kewer 2202, Fusion 17 boat-Yamaha FT100hp 4st.
  11. The Following 6 Users Say Thank You to BruceHun For This Useful Post:
  12. #89
    Brackenfell
    Thanked: 342
    if yours is 1yr old
    then you should rather contact them (snomaster), rather then ask advise here first. See here
    220 volt 3 yr on unit & 5 on Compressor
    12/220 - 3yr on unit and 7 on compressor.
  13. #90
    Nov 2014
    Thanked: 1901
    The fridges have a temperature sensor, like a copper strip thermostat, that starts and stops the compressor. That had failed. Itís not an expensive fix. My Dometic cost about R1,100 to fix.
    Out and about, never get locked down again, never refuse an invitation to go somewhere.
  14. #91
    Constantia Kloof
    Thanked: 1366
    My truth about snomaster. I have the big 95L dual compartment unit bought about 4 years ago.
    I bought it because I needed a fridge/ freezer to take with on fishing and hunting trips. I chose it above NL because of price and standard equipment such as baskets, remote control and a cover. I took the biggest unit they have because I use it to make and keep many beers cold in addition to food. It has been in Mozambique, Eswatini and the northern parts of South Africa multiple times. It resides on the back of my bakkie under the tonneau cover when I travel so is subjected to severe conditions in terms of temperature fluctuations as well as vibration from the roads I travel on.
    It has been tasked with cooling beverages and keeping meat frozen in ambient temperatures ranging from -2 in winter to 45+ deg C temperatures in the Limpopo valley during February and has done so without issue. I have run temperature differentials as high as 15 deg C between compartments successfully although it is obviously easier for the machine to maintain smaller discrepancies between compartments.
    In essence it has done all I asked of it reliably and at the end of the day that is what most people want from any piece of equipment, isn't it?
    I am very sure too if I had bought a NL or Waeco or Engel that my opinion would have been the same. I don't go outdoors to compare my equipment with that of my neighbour's. What I do know is that if you want to be known as the twat in a group start brand bashing or throwing comments around about the superiority of your fridge/ vehicle/ tent. Nobody likes a braggart.
    Brandt Theunissen
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
  15. The Following 11 Users Say Thank You to Koebelwagen For This Useful Post:
  16. #92
    Thanked: 392
    Quote Originally Posted by Gungets Tuft View Post
    Jip it's called a thermister. If you do it yourself it costs around R15 for the part (but it is a pain to get to)
  17. #93
    Tshwanetoria
    Thanked: 894
  18. The Following User Says Thank You to hatjohan For This Useful Post:
  19. #94
    Garsfontein
    Thanked: 756
    This Snomaster vs Luna thing.
    I still don't get it.
    It reminds me of the Toyota vs any other brand debate. Apparently, Toyota's never break down, but yet everybody is so worried about the availability of parts...
    My snomaster must be about 6 years old now. It has worked and toured hard. It has not missed a beat...
    Ian de Villiers
    Nissan Patrol GRX 4.5
  20. The Following 3 Users Say Thank You to iandvl For This Useful Post:
  21. #95
    Dec 2007
    nelspruit
    Thanked: 173
    I paid R250.00 for a NL probe.
  22. #96
    Brackenfell
    Thanked: 342
    FIL has 2 campmasters. One about 8 to years old and other 6 years. One permanent on in garage other camping. Both do horrible gravel roads in the back of bakkie during decembers.
    not a cent spent on either.
    I owned one for about 4 years before selling and upgrading to SM 85 Dual zone.
  23. The Following User Says Thank You to Dwayne P For This Useful Post:
  24. #97
    Thanked: 1032
    My fridge is going to Johann tomorrow. Solenoid apparently.
    Otherwise, its a great fridge.
    Thanks for all the advise.
  25. #98
    Okahandja, Windhoek
    Thanked: 944
    Some fridges are popular because of their good back up services. Other because it rarely need a service.
    Johan Kriel
  26. #99
    Brackenfell
    Thanked: 342
    Maybe a good thing then if someone does not see this thread
  27. The Following User Says Thank You to Dwayne P For This Useful Post:
  28. #100
    Thanked: 1068
    Was not that lucky. Had to discard 2 of the said brand as they stopped working due to leaks. The piping inside the foam corroded/ broke with futile repair attempts by the agents.
    Bought 3 Engel fridges and never looked back. NL at that stage did not want to supply small trade, and would have been my first choice.
    Training: 4x4, bush mechanics, recovery, defensive, 4x4 trucks
    Angel Construction
    COMBAT19: Large scale fogging and decontamination
    [email protected]
    +27824453301
