My offroad "Bos Pandok" caravan built
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 52
    Feb 2016
    Fish Hoek
    Thanked: 9
    Default My offroad "Bos Pandok" caravan built
    As I did not have a big budget startng this project, I guess I did this project with materials I already had and the rest easy to find. fabrication i had do myself with the basic tools i have. My basic tools.... arc welder, grinder, drill, skillsaw and jigsaw. I started off with a multipurpose trailer I already owned. I installed new 1.2ton leaves and a new axle that I made up myself from 60mm steam pipe 5mm waĺl thickness and BMW 5 stud hubs (front struts). the floor of the caravan is 18mm shutterply. Frame I used 25mm aluminium square tubing 2mm wall thickness (bought). Outside skin 1.2mm aluminium sheeting (bought). The design is something I worked out in my head and just did as I worked it out in my mind. Here are a few pics off the start and framework. (Used corner profile fittings to join tubing).
  2. The Following User Says Thank You to Disa For This Useful Post:
    Feb 2016
    Fish Hoek
    Thanked: 9
    Default Re: My offroad "Bos Pandok" caravan built
    Here is some pics off the start
ID:	492052   Click image for larger version.
ID:	492053   Click image for larger version.
ID:	492054   Click image for larger version.
    '16 BMW X5 3.0D X-drive
    '01 Pajero 3.2DiD LWB
    '92 Kawasaki ZX10 B2
    '10 BMW F800 ST
    '09 Honda 125 NXR
    Feb 2016
    Fish Hoek
    Thanked: 9
    '10 BMW F800 ST
    '09 Honda 125 NXR
    Thanked: 1642
    With your wheels so far back it will tow well but keeping nose weight below 100kg might be interesting. The main focus in building a caravan and especially one that has to come in waay below 750kg is to build in lightness. You need to come in at 600kg to have a 150kg payload for all your kit that you want to take along, not an easy task. Rethink using that heavy wooden door for a lighter sandwich construction.
    Good luck.
    Henk
    Follow us on Facebook
    Feb 2016
    Fish Hoek
    Thanked: 9
    Good luck.
    Thanks for the reply. The window and door is made off aluminium. The axle so far back is because tha caravan sleeps 2. We are a family of 4. I plan to hinge a Echo 1.4m roortop tent on the back of the caravan for the kids. Also a spare wheel and 4 x 20l jerry cans.
    '10 BMW F800 ST
    '09 Honda 125 NXR
    Feb 2016
    Fish Hoek
    Thanked: 9
    Does anyone have experiance or now the road forward with regestration. As I am building the caravan on an allready registeted "Kokerbak" trailer.... can I use it as is?
    '10 BMW F800 ST
    '09 Honda 125 NXR
    Dec 2012
    Secunda
    Thanked: 76
    Lekke Disa sterkte ek hou jou vordering dop
    Sep 2014
    Thanked: 90
    Quote Originally Posted by Disa View Post
    Just do a search there is a recent trailer build the guy was also using a kokerbak
    Wolverine : 93' Range Rover Classic 3.9L EFI
    Feb 2012
    Bloubergrant
    Thanked: 109
    Well done Disa, moving the goal posts of DIY!
    Mitsubishi Triton DC 3.2 A/T 4X4
    2007 Hilux 2.5 D4D SOLD
    Feb 2016
    Fish Hoek
    Thanked: 9
    I'm planning to insulate the walls with 22mm Isofirm offcuts i have left after doing the ceilings of the bedrooms in my house. I've installed doors covering the opening for the side kitchen and the slide out fridge.
    '10 BMW F800 ST
    '09 Honda 125 NXR
  12. The Following User Says Thank You to Disa For This Useful Post:
  13. #11
    Feb 2016
    Fish Hoek
    Thanked: 9
    I will not have water tanks and waste water tanks installed. I plan to have a portapotty with Biodegradable chemicals. I will have 2 x 10l water cans under the little sink. One can for clean fresh water with submersible pump (12v) and one empty can for waste from sink. I bought a National luna battery power unit with built in solinoid. I will run 5 led lights and the submersible pump off the deap cycle battery. Try to keep it simple and not to expensive. Also will run a National luna 90l fridge freezer of battery.
    '10 BMW F800 ST
    '09 Honda 125 NXR
  14. #12
    Nov 2006
    Thanked: 403
    "25mm aluminium square tubing 2mm wall thickness "
    Ive always had this idea in mind for the basic frame.
    Why not, at my age the trailer doesnt have to last forever.
    If you live each day as if it was your last, someday you'll most certainly be right. SJ
  15. #13
    Feb 2016
    Fish Hoek
    Thanked: 9
    Quote Originally Posted by Damdan View Post
    Im making use of a Sikaflex product to glue panels to tubing. Edges are covered with 25mm aluminium angle with ss rivets. Try to keep it as light as possible
    '10 BMW F800 ST
    '09 Honda 125 NXR
  16. #14
    Feb 2016
    Fish Hoek
    Thanked: 9
    Getting there.
    '10 BMW F800 ST
    '09 Honda 125 NXR
  17. #15
    Thanked: 849
    the 25mm alu tubing connected with Connect-IT pieces? Or am I seeing wrong?
  18. #16
    Ellisras
    Thanked: 395
    I have the greatest respect for these okes that "build their own"
    Well done...enjoy your own...
    2000 Patrol GU 4.2D(onkey) beyond 830 000 km
  19. #17
    Feb 2016
    Fish Hoek
    Thanked: 9
    Quote Originally Posted by Rustie View Post
    Yes. I bought them at Mica. They had to br grinded alittle as they are made for tubing with 1.6mm side wall. I used 2mm. I also screwed then together with normal self drilling screws. I guess time will tell to how well it will last/keep up.....
    '10 BMW F800 ST
    '09 Honda 125 NXR
  20. #18
    Feb 2016
    Fish Hoek
    Thanked: 9
    Thanks.... At the end of the day we do with the money available and for it to work for your own purpose. Its standard with no frills but affordable and lots of fun.
    '10 BMW F800 ST
    '09 Honda 125 NXR
  21. #19
    Sep 2014
    Thanked: 90
    I built a roofrack with the connectit fittings
    It has thusfar lasted over 2 years with a nuber if 4x4 trips with a rooftop tent strapped to it
    Next project trailer like yours
    Q:where did you buy the aluminium sheeting?
  22. #20
    Feb 2016
    Fish Hoek
    Thanked: 9
    Quote Originally Posted by whosthejman View Post
    Im in Cape Town. I bought it at Non ferrous metals 114 Voortrekker road Salt River.
    '10 BMW F800 ST
    '09 Honda 125 NXR
