Padgeraas op bande wat afloop op elke tweede blokkie van band.Wat kan dit veroorsaak - Page 2
Results 21 to 28 of 28
    Friemersheim, Southern Cape
    Thanked: 1466
    Default Re: Padgeraas op bande wat afloop op elke tweede blokkie van band.Wat kan dit veroors
    My Unimog het dit ook gedoen as ek vinniger as 100km/h ry. Shocks kon seker dan nie byhou nie.
    Hehe Unimog vinniger as 100km/h .... of Cobus vinniger as 100km/h
    Thanked: 159
    I also believe itís tyre pressure. Could also be wrong tyre for your application you use you car for.
    You generally see these on BF and coopers. Especially the mud tyres.
    2010 Toyota Fortuner 2 4x4.
    2001 Isuzu KB320 Frontier 4x4.
    2012 Polo GT White with community sticker.
    Aug 2007
    Carletonville
    Thanked: 365
    Last weekend I was at my FIL. His old Series Landy has a collapsed and bent rear right leaf spring which has caused the left front to lift. Everybody has been looking for the problem on the front, even added a blade on the front right pack. I found the rear leaf all out of place and the shackle at a strange angle. BUT, I see the left front tyre has feathered. This is what alerted the old man to a problem in the first place, that they have been chasing for nearly two months now.
    Jul 2008
    Potchefstroom
    My Dunlops AT 3s het dieselfde gedoen. Ek het hulle afgehaal met nog so 5 mm loopvlak op
  5. #25
    Feb 2013
    Hartenbos
    The dealer phone me that they will credit me on new tires
    Q what kind of tire , this time normal road tire
  6. #26
    Feb 2013
    Hartenbos
    GPB, watter tipe het jy toe opgesit
  7. #27
    Feb 2012
    Mindalore
    Thanked: 81
    I've experienced the same on the Dunlop MT1s on the Pajero.
    Then today for me the final straw, while driving on the freeway I started getting a terrible vibration. When I stopped I found this bulge in the tyre.
    I won't be fitting Dunlop's again.
    One Wife - Livid
  8. #28
    Thanked: 371
    Now that could have ended bad.
    Eggie.
    - apology to Edward Langley.
