Results 1 to 11 of 11
Thread: Jk soft top
    Default Jk soft top
    Hi Guys.
    Been enjoying the Jeep.
    Fitted my soft top for the first time today, wow what a job!!
    Do you ever actually use it?
    Much easier taking the hard top in and off if the weather is nice, I understand that could change quick. And thatís where the soft top would work better.
    But I just donít know about this.
    Dwayne
  2. The Following User Says Thank You to Pypkar For This Useful Post:
    Dec 2012
    Thanked: 121
    Default Re: Jk soft top
    I tried my soft top once as well.
    Yes, putting the roof up on the soft top is quick, but
    for me putting the windows back on takes too long.
    according to my instruction guide, the windows must be taken off
    to lower the roof.
    Second issue I had was with the rear window. I dislike putting stuff
    in the back without opening the window. The soft top windows is too much
    of a schlep to open and close. Hardtop much easier.
    Third issue I have is that the soft top is higher than the hardtop, which means
    it doesn't fit into my garage with the soft top on.
    My preference is hardtop. If I want open top, I just take the freedom panels off.
    I will never take them off in the bush again, though. Way too much dust in the vehicle afterwards.
    This was not an issue at the coast.
    Jurgen
    ______________________________________________
    Now: 2014 Toyota Prado TX 3.0D AT
    Then: 2012 Jeep Wrangler Unlimited Rubicon 3.6 V6
    Then: 2013 Ford Ranger 3.2L XLT AT D/C 4x4
  4. The Following User Says Thank You to JurgenH For This Useful Post:
  5. #3
    I totally agree.
    Had a TJ with just a hard top. And like the Freedom panels that can be removed.
    Yes the windows are the biggest schlep. My fingers are done just with the messing with this.
    Donít think Iíll be using the soft top. And it just takes up space in the garage.
    White River
    Thanked: 885
    I use my soft top a lot. It definitely gets easier the more you use it.
    The only thing that bugs me is undoing and lifiting the back window to put stuff in and out of the back. Other than that I have no hassles.
    Oh ja, and it is a lot noisier at highway speeds, but I have got used to it
    2011 JK Wrangler Rubicon 3.8
    Nov 2014
    Thanked: 28
    Quote Originally Posted by Pypkar View Post
    Hi Guys.
    Much easier taking the hard top in and off if the weather is nice, I understand that could change quick. And that’s where the soft top would work better.
    But I just don’t know about this.
    Dwayne
    I've never used my soft top, I'm actually selling it right now. it's in mint condition, just missing the rear window, that's just how it was when I bought the car. I don't plan on buying a new rear window so if anyone wants it please pm me. It's taking up a lot of space.
    In any case It looks like hard work to install.
    2014 Jeep Wrangler Unlimited 3.6 Sahara
    2008 Opel Corsa Utility 1.4 Base
    2004 VW Touareg R5 TDi Air Rear Locker - Facelifted - SOLD
    It's Either You Get Your Hands Dirty Or Let Your Hard Earned Money Get Dirty Instead #4x4community
    Joburg
    Thanked: 25
    You JK softies don't know how easy you have it hahaha Try a TJ soft top . If you don't bleed while raising or lowering it, you havent done it right.
    Having said that, I MUCH prefer the soft top to the hardtop. It's much quicker and easier to raise and lower the soft top than removing and replacing the Hard top every time. And also, good luck when it rains an you're 50kms from home.
    Stu.
    Current:
    06 Wrangler Sahara. 3.5inch Rubicon Express and Bilstein lift, Metalcloak control arms, 1.25" RC Body Lift, 1" JKS MotorMount Lift, Zone Disconnects, BFG KM2 33's
    NO LOCKER NEEDED!!!
    KTM 1190 Adventure
  9. The Following User Says Thank You to roadhawg For This Useful Post:
  10. #7
    Thanked: 101
    I use my soft top 90% of the time, but yes the rear window is a bit of a schlep.
    Nothing beats a Jeep with no roof and doors offroad, the dust is part of the fun
    Zone Built JEEP 018
    ORRA AG42
    2013 Jeep JK Rubicon
  11. The Following User Says Thank You to Jeepanator For This Useful Post:
  12. #8
    Aug 2010
    Thanked: 45
    Itís easy once you get used to it. Takes 2 minutes to take it down and about 3 minutes to put it up again. Practice boys, itís a Jeep not a convertible Merc.
    Pete
    Living the dream baby, living the dream......
    2011 Jeep Wrangler Unlimited Sahara 3.8
    1999 Jeep Cherokee Country 4.0 - SOLD
  13. The Following 2 Users Say Thank You to Jeep dream For This Useful Post:
  14. #9
    [REMOVED]
    Thanked: 318
    I timed my self once, it takes me 5mins to take it down or put it up by my self.
    The side windows are the easiest.
    I'm stuck with the hardtop now, my rear window zip stripped. The top right corner is a real pain to get past, On a hot day easy. I hooked the my letherman to the zip to get a better grip and I stripped it properly the zip's little hook also broke off.
  15. #10
    Oct 2017
    Thanked: 39
    When putting the soft top up, do the rear window first, before the side windows.
    That way the side panels of the roof can be moved slightly backward so that there isn't as much tension on the rear window and it zips up much easier with less chance of damaging the zipper.
    Reverse order for taking it down; side windows first.
  16. #11
    White River
    Thanked: 885
    I find it a bit easier to put the 3 window panels in before latching the top to the windscreen latches.
  17. The Following 2 Users Say Thank You to TonyP For This Useful Post:
