Building my LP Gas Forge
Results 1 to 20 of 34
    Gaborone, Botswana
    Thanked: 1208
    Default Building my LP Gas Forge
    I decided to build a gas forge.
    The old wood burning model works great, but it takes time to make the fire, drag the compressor (for the forced induction) outside and then wait for it to heat up.
    Old faithful.
    Kobus
    Gaborone, Botswana
    Thanked: 1208
    Default Re: Building my LP Gas Forge
    I will start with the burner.
    The high pressure regulator by Safegas.
    0.2Mpa (2 Bar / 29Psi)
    All the parts up to the valve from Cosmo Industrial in Silverton. +-ZAR450-00
ID:	491160   Click image for larger version.
ID:	491161   Click image for larger version.
    Kobus
    Gaborone, Botswana
    Thanked: 1208
    All the parts for the rest of the burner.
    The only reason for having 2 each of the 1/2 inch components is that they sell 2 per packet at Builders Warehouse. There are also some extras. At the time of buying I was not sure how it will fit together where the Mig nozzle must go.
    Decided to drill 12mm hole in the 1 inch T.
    Drill and tap (M6) the 1/2 inch stopper.
    Welded together
ID:	491165   Click image for larger version.
ID:	491166   Click image for larger version.
ID:	491167   Click image for larger version.
    Kobus
  4. The Following User Says Thank You to KobusDJ For This Useful Post:
    Gaborone, Botswana
    Thanked: 1208
    Where the nozzle goes. Yes, I know it is crooked/askew. I will redo this part later. At least it is functional.
    Everything screwed together.
ID:	491170   Click image for larger version.
    Kobus
    Gaborone, Botswana
    Thanked: 1208
    And there she blows....
    Kobus
  7. The Following 4 Users Say Thank You to KobusDJ For This Useful Post:
    Thanked: 15
    Looks awesome Kobus, what do you use the forge for?
    This reminds me when I built a small smelter way back our of fire bricks. Also used some primitive techniques with briquettes and a small blower
    Smelted aluminium like a charm
    Keep posting pics, would like to see the final result
    HUMMER H3 Adventure 3,7L 8)
    Achievement Unlocked: Hang A HUMMER.... Twice
    Achievement Unlocked: Shoot a .50 cal rifle
    Achievement Unlocked: Shoot original AK47
    Gaborone, Botswana
    Thanked: 1208
    It worked first time. !
    I need to redo the 1 inch T. Firstly to do it straight and secondly I will use a 3/4 inch T. Those 2 x 1 inch air inlets are too much. I had to close one side (masking tape ) to make it burn a nice blue flame.
    Next up is building the actual oven. This will probably happen over this weekend.
    The Bricks are waiting
    Kobus
    May 2016
    Thanked: 3078
    Why not install a valve to control the air intake?
    2006 VW Touareg V10 TDi
    Gaborone, Botswana
    Thanked: 1208
    Quote Originally Posted by QuantumPi View Post
    Thanks.
    I'm attempting some knife making.
    http://www.4x4community.co.za/forum/...Kobus-maak-Mes
    Kobus
  12. The Following User Says Thank You to KobusDJ For This Useful Post:
  13. #10
    Gaborone, Botswana
    Thanked: 1208
    I'm thinking of some adjustable thingy/valve.
    At the moment it burns 100% with only the one side open. I may just blank it off.
    Kobus
  14. #11
    Gaborone, Botswana
    Thanked: 1208
    Building the actual oven.
    Mockup.
ID:	491509   Click image for larger version.
    Kobus
  15. #12
    Gaborone, Botswana
    Thanked: 1208
    Building / Welding. All offcuts.
    I built it in two parts. It will bolt together once the bricks are inside.
    It fits
    Done
    Red oxide
ID:	491511   Click image for larger version.
ID:	491512   Click image for larger version.
ID:	491513   Click image for larger version.
    Kobus
  16. #13
    Gaborone, Botswana
    Thanked: 1208
    The bricks where the burner goes. Angle grinder with masonry disk.
    Painted red. Ready for assembly.
    Final part to hold the burner in place.
ID:	491515   Click image for larger version.
ID:	491516   Click image for larger version.
    Kobus
  17. #14
    Gaborone, Botswana
    Thanked: 1208
    Assembled. All bolted up.
    Only the tip of the burner sticking out.
ID:	491520   Click image for larger version.
ID:	491521   Click image for larger version.
ID:	491522   Click image for larger version.
    Kobus
  18. #15
    Gaborone, Botswana
    Thanked: 1208
    Lighting it up.
    Kobus
  19. The Following 3 Users Say Thank You to KobusDJ For This Useful Post:
  20. #16
    Nov 2017
    Thanked: 210
    Awesome project - looking good.
  21. #17
    Gaborone, Botswana
    Thanked: 1208
    I'm very happy with the result. Everything works as planned.
    I still need to sort out the air intake. Currently I use masking tape to close/partially close the big holes in that 1 inch T-piece. At full blast it sounds like a weber carburetor without an air cleaner.
    A 6mm rod did not take long to become red hot.
    Kobus
  22. #18
    Oct 2012
    Thanked: 267
    Well done Kobus, I just love DIY projects like these.
  23. #19
    durban
    Thanked: 1121
    Nicely done.How hot do you think it can make metal.I wonder if a thermostat could be included.?I soppose with gas you will be limited to a certain heat range but for your application it is hot enough.
  24. #20
    Kimberley
    Thanked: 136
    It should reach 1300 plus
    What is your internal length
    Pull the flare back a bit. It will burn up a lot faster like that
    Pajero Gen2 1996 2.8TDi LWB
