Puma D/Cab Build thread - Page 2
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 40 of 72
  1. #21
    Aug 2014
    Oppi plaas
    Thanked: 788
    Default Re: Puma D/Cab Build thread
    What you going to do about roof lining I canít find one for my double cab I built
    My double cab roof came complete with hoodlining. Bought it from British 4x4. The front hoodlining off a stationwagon and a single cab bakkie hoodling could maybe be enough to make a plan with, just a thought.
  2. #22
    Aug 2014
    Oppi plaas
    Thanked: 788
    Today I decided to try remove the left rear side panel from the donor load body. Got it successfully removed with even the little spot weld indents undamaged. I then removed the damaged panel from the Pumas load body.
    I also removed the bulkhead from another donor load body, which I want fit to the Pumas load body (goes between the cab and rear load area). Time to take a break, had enough of drilling out spot welds for one day.😁
    To be continued tomorrow....
ID:	491307   Click image for larger version.
ID:	491308   Click image for larger version.
ID:	491309   Click image for larger version.
  3. The Following 2 Users Say Thank You to Bosvark Kzn For This Useful Post:
  4. #23
    Thanked: 1033
    Don't forget to use high quality seam sealer when you finally fit the new panel to the body.
  5. The Following 2 Users Say Thank You to Skylark For This Useful Post:
  6. #24
    Aug 2014
    Oppi plaas
    Thanked: 788
    I think this will do?
  7. #25
    Thanked: 1033
    Quote Originally Posted by Bosvark Kzn View Post
    That looks good, maybe also get some brushable seam sealer if you want to make 100% sure you are getting full coverage over the seams after the panel has been fitted, also to touch up existing seams on the underbody or loadbin etc.
    It's amazing the difference enthusiastic application of hi quality seam sealer makes 10-20yrs down the line, especially in areas prone to sitting water.
  8. The Following User Says Thank You to Skylark For This Useful Post:
  9. #26
    Aug 2014
    Oppi plaas
    Thanked: 788
    So tomorrow the builder will start bricking up the walls and constructing the entrance, leaving a 3m wide opening and heigh enough for a Land Rover to drive in or out. This will be my "Landy cave" almost like a man cave😂
    I havenít work on the Landy much this last week or so, as we were working on the ďLandy caveĒ. Itís almost ready, I painted the floor tonight and over the next day or two will set it up as a mini workshop and then work on the Landy can start. Canít wait!
  10. The Following 3 Users Say Thank You to Bosvark Kzn For This Useful Post:
  11. #27
    Thanked: 1033
    Always nice working on freshly painted floors, looking good!
  12. The Following User Says Thank You to Skylark For This Useful Post:
  13. #28
    Fourways Gardens
    Thanked: 619
    Looks good Jacques!
    Series III 88"
    Scout Nomad
  14. The Following User Says Thank You to ClaudeG For This Useful Post:
  15. #29
    Aug 2014
    Oppi plaas
    Thanked: 788
    Last weekend I did the last few things left to do on the Landy cave and moved in.
    This week I didnít work on the Landy due to the my neck injury from the small accident on Monday.
    Iím feeling much better so this morning when Swambo went to town, I sneaked out, straight to the Landy cave. I worked on the rear bulkhead, which I previously removed from a donor load body.
    I marked out and cut the panel and got it to fit. Will get brush-able seam sealer tomorrow and rivet the panel in. By the time Swambo got back, I was back in bed, as if Iíve been there all day.😂
ID:	493648   Click image for larger version.
ID:	493649   Click image for larger version.
  16. #30
    Aug 2014
    Oppi plaas
    Thanked: 788
    I haven't updated this thread for some time due to this happening: https://www.4x4community.co.za/forum...day?highlight=
    Well, that's all sorted out and back on the road. So it's a new year and time to get started on my D/C again, hopefully this time without any unplanned interruptions.😀
    So December I'm planning on visiting Baviaanskloof and Gamkaskloof and I've decided to go in the..... D/C Puma. Yes, this one. Hope I'm not biting off more than I can chew, I guess time will tell. Gonna give it a bash and see if I can have this Landy ready and on the road come December.
    Planning on getting the most challenging job done first, and that, to me, is replacing the firewall. So at the moment I'm preparing the new firewall for painting, once painted, I'll remove the damaged firewall and fit the new.
    Will update the thread and post photos soon.
  17. The Following User Says Thank You to Bosvark Kzn For This Useful Post:
  18. #31
    Aug 2014
    Oppi plaas
    Thanked: 788
    Tonight I used 600 grit water paper to ďflatĒ the new firewall in preperation of spray painting it tomorrow. I also used a heat gun and thinners to remove what was left of the foam/seal at the top of the firewall where the windscreen frame rest on the firewall.
    Iíll take it to the workshop tomorrow morning and if all goes well, it will be Land Rover Corris Grey by tomorrow afternoon and then the fun can start removing and replacing the firewall.
ID:	515808   Click image for larger version.
  19. The Following User Says Thank You to Bosvark Kzn For This Useful Post:
  20. #32
    Sep 2008
    Thanked: 139
    Good to see some progress!
    1951 Land Rover Series I 80" 2-litre ioe tilt (project)
    1975 Land Rover Series III 88" 2.25 p soft top (workhorse)
    1998 Land Rover Defender 90 2.8i CSW (expedition vehicle)
    1977 Land Rover Series III 109" 2.25 p station wagon (sold)
  21. The Following User Says Thank You to lrswb For This Useful Post:
  22. #33
    Aug 2014
    Oppi plaas
    Thanked: 788
    Firewall painted! And Iím very happy with the result and the color I chose.
    Used a medium hardener as it provides a higher quality finish than a fast hardener, so the paint will take a bit longer to cure, so Iím gonna leave it Ďtil Monday before I take it home.
    I may just start removing the old firewall over the weekend, so by Monday I can start fitting the new one.
    Have to keep going now while Iím on a roll!😂
ID:	515896   Click image for larger version.
ID:	515897   Click image for larger version.
  23. The Following User Says Thank You to Bosvark Kzn For This Useful Post:
  24. #34
    Fourways Gardens
    Thanked: 619
    Jis i like that colour
    Wish mine was that darker grey too!
    Series III 88"
    Scout Nomad
  25. The Following User Says Thank You to ClaudeG For This Useful Post:
  26. #35
    Aug 2014
    Oppi plaas
    Thanked: 788
    Hope I can put all this back together again.🙈
ID:	515971   Click image for larger version.
  27. The Following 2 Users Say Thank You to Bosvark Kzn For This Useful Post:
  28. #36
    Aug 2014
    Oppi plaas
    Thanked: 788
    And sheís out. What a mission. Maybe a good time to de-cat. But now itís beer time.
ID:	516062   Click image for larger version.
ID:	516063   Click image for larger version.
  29. The Following User Says Thank You to Bosvark Kzn For This Useful Post:
  30. #37
    Fourways Gardens
    Thanked: 619
    Wow thats crazy! Hows that harness
    Series III 88"
    Scout Nomad
  31. The Following User Says Thank You to ClaudeG For This Useful Post:
  32. #38
    Aug 2014
    Oppi plaas
    Thanked: 788
    That harness is my biggest worry!🙈
    I took hundreds of photos, should help a bit when trying to figure out what goes where.😀
  33. #39
    Aug 2014
    Oppi plaas
    Thanked: 788
    Small problem. I think I just discovered the 2.2 firewall is different to the 2.4.
    And I think my new firewall is off a 2.4, because where there should be a hole, there isn’t one....
ID:	516223   Click image for larger version.
  34. #40
    Aug 2014
    Oppi plaas
    Thanked: 788
    Sorted!
ID:	516237   Click image for larger version.
  35. The Following 2 Users Say Thank You to Bosvark Kzn For This Useful Post:
