Fire Bricks
Results 1 to 11 of 11
Thread: Fire Bricks
    Gaborone, Botswana
    Thanked: 1203
    Default Fire Bricks
    Where can I get Fire Bricks (Refractory Bricks/Silica Bricks) in Gauteng? Rustenburg/Brits would also be fine. I need +-20.
    What can I expect to pay per brick?
    It is for my Forge I want to build.
    Kobus
    Robertson/ Larissa, Greece
    Thanked: 3377
    Default Re: Fire Bricks
    Just a suggestion. Won't refcast cement be a better option? I don't know what your forge will look like but with the cement you can fill all nooks and crannies and free form. FWIW
    JHB
    Thanked: 32
    You can try Vesuvius Refractories
    https://www.vesuvius.com/en/contact-us.html
    or
    Insimbi Alloy Supply
    http://www.insimbi-iras.co.za/contact/
    Not sure if they would sell to the Cash and Carry market, but worth a shot.
    Thanked: 888
    Can't stand the heat over time from temps a forge will reach - especially if you use it regularly.
    EDIT - for some reason I read PRECAST cement. Yes refcast should work, there are recipes online for DIY.
    Gaborone, Botswana
    Thanked: 1203
    I prefer using the bricks. It will be easy to rearrange them if I want to change the design or go smaller/bigger.
    The cement will be permanent once it is cast.
    Kobus
    Thanked: 104
    Brick & Tile in Centurion near Chamberlain stock the bricks. Can't remember pricing but for 20 it won't break the bank. They also have cement.
  7. The Following User Says Thank You to waldo_g For This Useful Post:
    durban
    Thanked: 1119
    How are you going to fire your forge.?
    Gaborone, Botswana
    Thanked: 1203
    LP Gas. I'm still investigating the design of the burner.
    Also looking for a Red Devil high pressure regulator.
    Kobus
    Gaborone, Botswana
    Thanked: 1203
    Quote Originally Posted by waldo_g View Post
    Tx.
    R35 per 230x114x76mm brick.
    I will go get a few on my next visit to Pta.
    Kobus
    Kimberley
    Thanked: 136
    Refraline
    J23 or J28 R28 ex vat
    Refset R174 20kg bucket
    Pajero Gen2 1996 2.8TDi LWB
    Kimberley
    Thanked: 136
    Make sure you get the j23 or j28 insulation bricks
    Seems fire brick is slightly diffrent
