HCDP Electonics DCDC30A
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 58
    Dec 2012
    Thanked: 23
    Default HCDP Electonics DCDC30A
    Hi
    I've read lots of comments good, bad and different on this product.
    I am on a budget so am leaning towards this unit.
    Does anyone have unit installed? One of concerns is the terminals on the unit itself, they look rather small to connect a 16mm2 / 10mm2 cable to. Is it just the picture of the unit on the website or are the terminals big enough?
    Also on there diagram it shows the output to a fridge only. Can this output go to a 'bank' of connectors (of which the fridge would connect to one), maybe a couple of spare connectors and to power some led light strips?
    Is HCDP electronics the cheapest place to buy or is there someone in Cape Town?
    Feb 2012
    Mindalore
    Thanked: 94
    I cant comment on the 30a model but I have the 12a model. I've had 2 years good service from it so far.
    If it has the same connectors, you won't get 16mm cable in there. Maybe chat to hcdp, I found them very willing to assist with technical questions but I do run more than my fridge from that outlet
    One Wife - Livid
    Jukskei Park
    Why do you need a 16mm cable? IIRC, you need 6mm2 cable from main battery to unit and to 2nd battery?
    I have the 12A as well and am extremely happy with it;
    I had mine in the Rok to a bank of connectors with the main cables going to the Hellp for fridge & the rest for lights.
    EDIT: 12A needs 6mm2, 30A needs 10mm2. If so, Oom Manie would definitely make it big enough.
Name:	Dist boksie.JPG
ID:	286220   Click image for larger version.
    Attached Files Attached Files
    2008 9A Discovery 3 TDV6 SE "Binky"
    2015 Amarok Auto Highline
    Oct 2008
    Thanked: 9
    As far as I know, they are the manufacturer, you will not get it cheaper elsewhere.
    Jukskei Park
    Quote Originally Posted by Leeu View Post
    They are, you won't, sure they will courier to you.
    Sep 2012
    Cant go wrong with it.
    I am also using the 12to12 unit now for 2 to 3 years.
    Manie (or Johan) will be more than willing to assist.
    Just phone him with your questions.
    Mar 2009
    Thanked: 26
    Default HCdP DCDC chargers
    Hi Guys
    You can connect any load to the terminal marked +Ld. The drawings show a fridge for illustative purposes only.
    Regarding the wire size and terminals, the following:
    1) 16mmsq wire is not recommended in our drawings.
    2) For DCDC30A the a 10mmsq wire from the car is adequate and fits with ease into the terminal block provided.
    3) For DCDC12A the a 6mmsq wire from the car is adequate and fits with ease into the terminal block provided.
    4) A 4mmsq wire to the fridge/load is adequate.
    5) A 6mmsq wire to the battery is adequate.
    Manie
    May 2007
    Welgelegen, Cape Town
    Thanked: 131
    I have the 30A unit (had it for two years now)...it keeps two Deltec 130AH Deep Cycles happy, and two Engel 40's
    No problems whatsoever..
    But yes speak to Manie..always willing to assist
    And do your self a favour buy the Voltage cut of regulator...I think another R150 or so...to protect the batteries from draining below their limit..
    Toyota D4D Legend 45
    Nissan Kingcab 2007 4x4
    Bushlapa Vlooi 652
    Jukskei Park
    Mine's had a fun life thus far and still bulletproof; dankie Oom Manie!
    Sep 2010
    Paarl
    Very happy with mine too. You are welcome to come take a look in Paarl.
    Jan 2009
    The guys at 4X4direct in Brackenfell sell the hcdp units.
    01 Discovery 2 V8 A/T- Sold
    97 LC80 4500 GX Limited
    Dec 2012
    Thanked: 23
    Guys,
    Thank you all for your input. I have some more questions, sorry!
    It seems most are using the 12A?
    Is one of the major differences between the 30A & 12A the automatic feature of the solar panel?
    I will be running my 60L Snowmaster fridge, led lights and a 160L compressor (one thing, the compressor currently has alligator clips for direct battery connection, can these be cut of and a plug of sorts be fitted).
    I have a king cab and want to put the 2nd battery behind the seats in a ply / aluminum box. Does the HDCP charger need any breathing space or ventilation holes?
    So my question would be, would the 12A be adequate for my needs as I can buy the 12A and a battery for the cost of a 30A.
    Also @ Manie_dup ( I guess your the man in the know)
    The reason i quoted the 16mm2 is because on your website under the 30A product document. The alternative wiring diagram does state 16mm?
    @diaan Very happy with mine too. You are welcome to come take a look in Paarl. Thanks for the offer.
    Thanks again all for your help
    Marcus
    May 2014
    Thanked: 17
    I have the 12 a model and its been working like a charm from the cars alternator and solar panel
    Suzuki Grand Vitara,
    Metalian Maxi bush trailer.
    Harley Davidson VRod.
    May 2007
    Thanked: 131
    Quote Originally Posted by sucramuk View Post
    Guys,
    Marcus
    Depends on what you are going to charge? one or two auxiliary batteries?
    Bushlapa Vlooi 652
    Mar 2009
    Thanked: 26
    Default DCDC30A connector
    Sorry Scumarok
    I forgot the 30A alternative wiring shows a 16mmsq wire, but the terminal bloch will accept a 16mmsq wire. See attached data of terminal blockc which specs 16mmsq as the maximum,
    Dec 2012
    Thanked: 23
    Hi
    I will only be charging one battery of 105A.
    Thanks for clearing up the 16mm confusion
    Hey Guys, quick bump on this thread.
    Bought a 30A unit. Wondering now where to mount it as it has the SP/Car switch. Can it be left on one or the other and "autoselect" or does one have to flick the switch? This will obviously change my mounting position.
    Quote from website: "Dual purpose lead acid battery charger (charges from car or solar panel without having to re-connect car or solar panel" - but I guess you have to flick the switch?
    Fortuner 3.0D4d 4x4
    EFS Suspension, Oversize BF AT's, Dual Battery System.
    I don't want to sound like a badass but.... I eject my USB without removing it safely!
    Thanked: 87
    Quote Originally Posted by Gizmo View Post
    You have to flick the switch every time you change between car and solar.
    Cobus
    Land Cruiser 200 4.6
    Imagine Comfortvan
  19. #19
    Feb 2015
    Parys
    I have the 12A unit as part of a battery box (from Bush Power) in my loadbin charging a 100Ah LC that powers my freezer. In my trailer I have the 15A MK4 panel charging 2 x 100Ah LC batteries in parralel. While driving the loads on both units are switched to the alternator. In my case a low voltage cut-off isn't needed, as the freezer (in vehicle) and fridge (in trailer) already offers this function. Neither unit can deplete your starter battery as it only kicks in above a certain voltage. Both units, in my opinion, are top of their class.
  20. #20
    Aug 2010
    Delmas
    Thanked: 34
    I am very happy with my 30amp and 12amp units.
    I am building the units into the campers as well without any complaints from my customers.
    BlinkGat Products
    Manufacturing of Aluminium
    custom made Products
    Sarel 082 820 9413
    www.blinkgatproducts.com
  1. HCDP dc-dc charger
    By Kobus Jacobs in forum Camping, Fridges, Accessories
    Last Post: 2018/12/22, 05:04 PM
  2. Excellent service and brilliant results - HCDP ELECTRONICS
    By PJN in forum Camping, Fridges, Accessories
    Last Post: 2014/04/29, 12:01 PM
  3. Anyone using HCdP DC-DC 12V charger in Cape Town?
    By chris-2 in forum Camping, Fridges, Accessories
    Last Post: 2013/05/23, 10:57 PM
  4. Ctek D250S ... or similar ???
    By Elders in forum Camping, Fridges, Accessories
    Last Post: 2013/01/30, 12:20 AM
  5. HCDP powerpacks: problem and follow up (title amended)
    By big t in forum Camping, Fridges, Accessories
    Last Post: 2010/03/30, 05:53 PM
