Results 1 to 9 of 9
    Feb 2017
    Thanked: 15
    Default Nissan Hardbody ZD 30 Diesel Pump Problem
    Does anybody know where I can take my HB to get the Diesel Pump tested. A few weeks ago the car just stopped. My local mechanic figured out it was the diesel pump. (when we spray some Q20 , it starts). Problem is, He has had it (apparently) at 3 people, none of them can give us a test bench report, which is required by my AA Warranty. Apparently it is a problem part and they do not want to take the risk. Should I take it to a place like BOSCH or is Nissan my only option?
    Mar 2016
    Thanked: 6460
    Default Re: Nissan Hardbody ZD 30 Diesel Pump Problem
    One of my friends had to replace his.
    Agents only - R30 000 IIRC
    André Opperman
    Apr 2009
    Thanked: 57
    I also had to issues with the pump on the HB.
    Recon at R21k if I remember correctly. Was a few year ago. Yes a problem part.
    Martin Prinsloo
    if only life came with a ◄◄ REW ► PLAY ▌▌PAUSE █▌STOP
    2015 VW Caravelle 4Motion
    2011 VW Touareg 3.6 FSI V6 (With Air Susp) - SWAMBO
    Thanked: 20097
    Talk to Reenen, I think there was a way of converting the ZD30 to a mechanical pump?
    Thanked: 20097
    By the way, has the "mechanic" done a proper check to see if diesel is indeed getting to the injectors?
    Has he checked the Nissan Diagnostic codes?
    Has he considered checking the CRANK POSITION SENSOR?
    The IMMOBILISER?
    I suggest a Bosch Diesel workshop as a MINIMUM.
    Thanked: 51
    Agree with Jelo, has the mechanic doen the proper testing.
    Take it to a Bosch diesel centre or there is a bloke in Germiston called Diesel Maniac Mechanic which helped me sourcing injectors last year. He is quite a helpful old man with a heap of diesel knowledge.
    Adress:
    152 President St, Germiston South (Industries E A), Germiston, 1401
    Tel: 011 825 0400
    Nato
    '13 Nissan Navara 2.5TDCI DC 4X4
    Ex '08 Nissan Hardbody 3.0 TD 4x4
  7. The Following User Says Thank You to natoburgoffer For This Useful Post:
    Nov 2017
    Strand
    Thanked: 501
    last i read, he said no.
    if this is not correct, i am all ears.
    on another note:
    - Immobiliser/NATS will stop the diesel from sending diesel into the lines
    - CAS will do the same
    - as Jelo put it: do you get diesel at the pump? (from filter)
    Codes will be a good indicator of the issue.
    '01 HB DC 3.2D 4X4 (SE)
    Thanked: 20097
    Quote Originally Posted by N0ddy View Post
    damn
    Apr 2018
    Just make sure before you buy another diesel pump. Don't trust this bush machenic, last time I took my navara for diognosis @ jorbug to one of machenic coz my truck just lost the power after replacing clutch plate and flywheel. Then his diognosis machine says FUEL PUMP. I went to buy another diesel pump and replace it and still the same no change. So be careful don't be like me coz I just wasted my money.
