Cole Hersee Solenoid
Results 1 to 18 of 18
    Thanked: 59
    Default Cole Hersee Solenoid
    Hi,
    Does anyone know where I can get a Cole Hersee Solenoid in the Midrand, JHB North, Centurion area ?
    I tried Autozone and the local spares shops,but none of them stock it and some of them don't even know what it is.
    I want to use it in a custom dual battery setup.
    Andre.
    Jan 2008
    More or less Cullinan
    Jacques
    Never trust a Chinchilla to hold your balloon.
    PTA
    Thanked: 8
    Try any 4x4 Megaworld
    D4 V8
    Live life on the edge... you get a better view !
    Disco 3 Video
    http://www.youtube.com/watch?v=STt7DmJeeVc
    Thanked: 59
    I managed to track down some stockists.
    GP Autoelectrical charges R350.00 for the Cole hersee 24059. Is that a decent price ?
    4X4 Megaworld doesn't stock Cole Hersee anymore, they now have a Tmax solenoid for R190.00. Does anyone have any experience with these ?
    Just for interest sake, Outdoor Warehouse charges R620.00 for the national luna solenoid (Cole Hersee 24059).
    I would much rather stick to the cole hersee, but if anyone else have a good report on the Tmax solenoid then I might consider it. Can't beat that price, but I don't want to buy my self a hole in the pocket.
    Andre.
    RICHARDS BAY KZN
    I buy my cole hersee solinoids direct from BOSH, R 240.00
    RIG
    Nigel
    Thanked: 2075
    LUCAS makes 1 as well. A lot of the older Fords used them. Under R50.
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
    On your screen
    Thanked: 150
    Quote Originally Posted by Andre N View Post
    Andre.
    André, just for interest sake, the Cole Hersee (NL intelligent) has more to it than just the solenoid. It has some electrical wizardry that automatically activates the solenoid as well as disconnects it as the DB system requires . . . eg the solenoid remains open when you start the vehicle to allow all the charge from the alternator to first recharge the main battery and then after +- 5mins allows the solenoid to activate and send charge to the secondary battery.
    IMHO, stick to the CH solenoid, some of the others were not designed to handle big (relatively speaking ) current for extended periods. The coil on the more affordable one's tend to burn after 4+ hours of continous current flow.
    [B]Johan Prinsloo
    Nigel
    Thanked: 2075
    I didn't find a problem on the coils. But I did find that the contacts on the relay burn.
    Warn
    Lucas
    Even genuine Freightliner
    They burnt.
    What I found to work OK was 5 x spotlight relays. 30A ea gives a total amps of 150A. According to spec. I still found that there was to much voltage drop and the aux didn't charge properly. Now I just run straight parallel. Works much better.
    I just put in a device that will make sure that the accesories are cut off when the power goes to low.
    Uniglide
  9. The Following User Says Thank You to Henris For This Useful Post:
    Oct 2006
    pretoria
    Saw some cole soleniods at 4x4 Mega world in Menlyn just did not ask what it cost.
    LEON CAHILL
    Jeep Wrangler JK Rubicon
    PajeroSport 2.5 HP
    Echo 4 4x4 Trailer
    Jeep Wrangler TJ '99 (My Classic Toy stock standard)
    *3.2 PajeroSport replaced with 2.5 PajeroSport
    Thanked: 59
    Picked one (24059) up yesterday for R200 at Trysome Auto Electrical in Jetpark. They're a big truck auto electrical supply company.
  12. #11
    Aug 2007
    Montclair Durban
    I found mine at Midas R250.00.
    '79 Range Rover classic.
    Now sadly sold.
    88" series 3"Littlemule"my first diesel.No more Landys, all sold
  13. #12
    Thanked: 294
    Bought 2 genuine Cole Hersee solenoids in Mooi Street Jhb, end last year for R190 each. Can't remember the name of the place, huge spares shop accross the road from the VW Garage. Driving on the M2 in a eastern direction you get off at Mooi Street. Pass the first robot and then check for the place on your left with VW to the right. Go to their electrical section.
  14. #13
    Thanked: 6
    Just an update as I am also in the market for the second battery setup
    Battery Centre in Botha laan Centurion, m2cw these guys are very good!
    16 mm˛ wire @ +- R31 p/m, btw the cheapest that I could find.
    Manual isolator +- R120, m2cw quite handy incase something do go wrong or battery faulty to cut of main supply to the second battery in full.
    Trysome Auto Electrical (7 Model str Jet Park) 0118235650
    Cole & Hersee (24059) R 220.17 incl vat and they have stock on hand
    QSV Motor Spares (Mooi str JHB) 0112201000
    Cole & Hersee (24059) R 285.00 incl vat and they have stock on hand
    This post was done on prices that I got between 7-9 Feb 09 and hope this info helps anyone else.
    "Ability is what gives you the opportunity belief is what gets you there"
    David Maritz
    Triton - Barberian!
  15. #14
    WayneSchalk Guest
    I foun mine at Breno AE THEY DELIVER!!! Make sure it’s got Cole Hersee imprinted around the top. There is a lot of imitations out there at a fraction of the cost, but hardly worth it!
  16. #15
    Klerksdorp
    Default Re: Cole Hersee Solenoid
  17. #16
    Klerksdorp
    The Lucas solenoid does not have a holding coil so will not work for long activation period.
  18. #17
    Nigel
    Thanked: 2075
    Quote Originally Posted by Jacques1965 View Post
    You can try and bring down the voltage with an old 1400 Nissan ballast resistor. I had the problem on my 80 that the Cole Hersey got very hot. Brought down the voltage with a ballast resistor and it was happy.
    Uniglide
  19. #18
    Thanked: 97
    Please take note that you get different models of solenoides with the same brand name. Most are starter solenoids which will not work for a doubble battery system because they will burn out.
    What you are looking for is called a "continuous duty solenoid".
    So for example you asks for a Cole Hersee Contiuous Duty Solenoid.
  20. The Following User Says Thank You to Viertrek For This Useful Post:
  1. WJ 2.7 CRD Maintenance
    By wtrlan in forum Jeep
  2. Part catalogs & other useful info
    By charlatan in forum Jeep
    Last Post: 2017/04/15, 11:31 AM
  3. Dual battery system
    By anvanleeuwen in forum Camping, Fridges, Accessories
    Last Post: 2014/12/01, 04:32 PM
  4. Cole Hersey Solenoid
    By 110Mike in forum Camping, Fridges, Accessories
    Last Post: 2014/09/03, 07:34 AM
  5. Grand Cherokee Error code
    By Nick47 in forum Jeep
