12v pump/compressor - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 44 of 44
    King Williams Town
    Thanked: 616
    Default Re: 12v pump/compressor
    Quote Originally Posted by Teryos View Post
    Please share from where you got it and for how much...
    I bought it in East London in the EC. You should have a place that sells compressor hoses close by ie pneumatic hosing
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  2. The Following User Says Thank You to hunter26 For This Useful Post:
  3. #42
    Thanked: 43
    Quote Originally Posted by Peter Green View Post
    Apologies for hi-jacking this thread, I'm not sure how to start a new one
    Is there such a thing as an 'extension' air cable to increase the reach of the tyre connector? Or where to buy a longer coiled air tube?
    Buy yourself a 13mm diam pneumatic pipe at any place such as https://nearfinderza.com/business-di...pneumatic+hose
    that will reach all the vehicle(s) wheels. Add an extra tyre valve clip to use on the compressor end of the hose and then you can inflate from the spare in case your pump packs up. Just cheap belts and braces in case you need it.
  4. The Following User Says Thank You to mygoggie For This Useful Post:
  5. #43
    Thanks I'll try the local tool shop for an air hose extension.
  6. #44
    Melkbosstrand
    Thanked: 64
    I have a Brad Harrison connector at the tow bar that I don't use. Is it advisable to make up a connector to plug the compressor power cable into this (assuming that if it was used by the previous owner of the Paj to power a fridge (in a trailer) that it would carry the Amps needed for the compressor) ?
    Hmmm... Assuming the cable is decent enough to the connector (and the fuse rating is sufficient), I'd go this way... Actually sounds like a great idea!
    *disclaimer* I made a few assumptions in my response
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
