Defender clutch slave heat shield
Results 1 to 4 of 4
    Oct 2014
    JHB
    Thanked: 20
    Default Defender clutch slave heat shield
    Has anyone made a heat shield to protect the Td5 clutch slave from Exhaust heat?
    Read an interesting post on a facebook LR group about this which has me thinking it's a good idea.
    Miks
    Thanked: 13573
    Default Re: Defender clutch slave heat shield
    If you fit one, make sure it isn't on any place that is exposed to vibration because your brackets and mounts will always crack.
    Jan 2014
    St Lucia
    I wrapped my exhaust pipe with special heat shield tape where it is close to the slave cylinder on my td5, problem solved
    Oct 2014
    JHB
    Thanked: 20
    Please can you post a photo? I'd love to see
    Another option was to wrap the pipe running from the slave in heat reflective material
