Ford & Mazda How to get spare wheel lock off
Results 1 to 19 of 19
    Jan 2011
    Bela Bela
    Thanked: 386
    Default How to get spare wheel lock off
    Hi,
    I have never had to change a tyre but while checking everything before a Botswana bush trip I decided to check that I can get the spare wheel lock (Ford lock with key). The plastic cover stops the dust, the key fits easily and turns immediately. Then this is where I get stuck. Does it screw off or do you just, after unlocking, pull (force) it off? I did not want to force anything incase I break it.
    Help will be appreciated!!
    Tobie Oosthuizen
    Ford Ranger 2.2 XLS 4X4
    RSI canopy & Frontrunner Slimline roofrack
    Jan 2011
    Bela Bela
    Thanked: 386
    Default Re: How to get spare wheel lock off
    This is the lock. Please advise after unlocking how to remove? Does it just pull off or do you have to unscrew? (I am screwed )
ID:	488041   Click image for larger version.
ID:	488042   Click image for larger version.
    Tobie Oosthuizen
    Thanked: 112
    That looks like the same kind of lock system as used on my Frontier's aftermarket bumper. It should just pull off. On the rod there should be an O-ring in a groove to protect it from dust ingress from the other side, which can be quite a tight fit, which would be causing the resistance that you feel.
  4. The Following User Says Thank You to Frontiersman For This Useful Post:
    Jan 2011
    Bela Bela
    Thanked: 386
    Quote Originally Posted by Frontiersman View Post
    Thank you will check again tomorrow in the light. I think the groove is open. How does the actual lock work? When you turn key what happens? Does it withdraws a pin from the rod?
    Tobie Oosthuizen
    Thanked: 112
    There is also a wide groove for the locking mechanism. When you turn the key to lock it, a rounded "tongue" from the lock slides into the groove, thereby keeping the lock attached to the rod.
    Looks like this: http://www.diamondcomponents.co.za/p...are-wheel-lock
  7. The Following User Says Thank You to Frontiersman For This Useful Post:
    Jan 2011
    Bela Bela
    Thanked: 386
    If I understand you correctly it then has to be pulled of and not unscrewed? Sorry to be such a nuisance
    Tobie Oosthuizen
    Thanked: 112
    No problem, yes, just pull it off. As mentioned, the O-ring might cause it to be quite tight, but it will pull off. Click on the link in my previous post to see a picture of the rod with the lock off, it will give you a better idea of how it works.
  10. The Following User Says Thank You to Frontiersman For This Useful Post:
  11. #8
    Jan 2011
    Bela Bela
    Thanked: 386
    Yip clear now thank you very much!
    Tobie Oosthuizen
  12. The Following User Says Thank You to Tobie4x4 For This Useful Post:
  13. #9
    Mar 2007
    Irene
    Thanked: 67
    Got a similar looking one on my Ranger. There is a hardened (tungsten?) steel pin attached to a chassis strut that goes through one of the wheel mounting holes. The big round thing as you rightly say has a plastic dust cover. The lock "locks around a groove in the pin making it more or less impossible to pull it off thereby keeping the spare wheel where its supposed to be when you need it! When you unlock it the little O-ring mentioned earlier makes it a bit difficult to pull off, just wiggle the round thing and pull hard downwards at the same time, it will eventually come off. If not try some WD40 or alike at the top. Mine tends to also stick a bit but I take it off once a year or so, clean it and spray some lubricant into the lock. The thing tends to get jammed a bit due to dust and some minor corrosion if not done regularly. That reminds me, mine needs to be cleaned again coming weekend.
  14. #10
    Jan 2011
    Bela Bela
    Thanked: 386
    With all the advice I gave it another go and just pulled it off. It came off without too much effort. Thanks for all the help guys.
    Tobie Oosthuizen
  15. #11
    Potchefstroom
    Thanked: 20
    "As geweld nie werk nie, dan het jy eenvoudig nog nie genoeg gebruik nie"
    "If violence does not work, you simply did not use enough"
  16. #12
    Jan 2011
    Bela Bela
    Thanked: 386
    Tobie Oosthuizen
  17. #13
    Mar 2007
    Irene
    Thanked: 67
    Quote Originally Posted by Tobie4x4 View Post
    Just remember to clean it and give it a generous dose of lubricant such as Chain Wax before putting it back (and redo every year at least)
  18. The Following User Says Thank You to jorgl For This Useful Post:
  19. #14
    Jan 2011
    Bela Bela
    Thanked: 386
    Quote Originally Posted by jorgl View Post
    Hi Jorgl, is that the trade Name "Chain Wax"?
    Tobie Oosthuizen
  20. #15
    Mar 2007
    Irene
    Thanked: 67
    Spanjaard Chain Wax, comes in an aerosol can, get mine at the local Builders Warehouse in Centurion
  21. The Following User Says Thank You to jorgl For This Useful Post:
  22. #16
    May 2012
    Thanked: 85
    Just to reiterate the "keep it clean" advice.
    Came to fit a new rear bumper myself yesterday on my 2018 XLT and the key wouldn't go into the lock (white plastic cover had been in place).
    Long story short, water and sand had made it's way into the lock from above and seized it up. 2 hours of knocking/spraying cleaner and lubricant/poking etc and finally got the key all the way in, then another hour until the lock turned.
    I soaked it in paraffin and then used an electrical contact cleaner spray to clear out the lock. Could not believe the amount of sand and muck that came out of there.
    Refitted with a home made rubber seal on top and tape sealed the plastic cover in place. You don't want to be stuck on a freeway or in the middle of nowhere and battle with a wheel lock.
    Current: 2018 Ford Ranger 3.2L XLT AT D/C 4x4 (since: 24/04/2018 )
    Previous: 2015 Ford Ranger 3.2L XLT M/T D/C 4x4 (31/08/2016-24/04/2018 )
    Previous: 2013 Ford Ranger 3.2L XLT M/T D/C 4x4 (05/01/2013-31/08/2016)
    Previous: 2010 Nissan Navara 2.5D LE M/T D/C 4x2 (Sold: 30/10/2012)
  23. The Following User Says Thank You to Prodigal For This Useful Post:
  24. #17
    West Rand
    Thanked: 76
    Quote Originally Posted by Prodigal View Post
    Completely agrees!
    We've had quite a number of incidents at work where people could simply not get those locks off or the keys in! I remove and clean mine every 6 months, properly.
    André Jordaan
    2016 Ford Ranger 2.2TDCI XL SuperCab 4X2
    I've just done something, and I DON'T KNOW what it was!!!
  25. #18
    Mar 2007
    Thanked: 105
    Just had my lock unit replaced under warranty as that original design failed...
  26. #19
    Jun 2008
    Pietermaritzburg
    Thanked: 24
    Quote Originally Posted by Clouder View Post
    Completely agrees!
    It took less than a few minutes for thieves to destroy my nephew's brand new wild track lock and make off with his spare wheel. Cops say the sprayed it with something and just bashed it apart.
    Sad situation.
    2011 I30 Huyundai platcar
    2017 Ford Ranger D/Cab 2.2 TdCi XLS 4x4 Auto
