New National Luna Aux Battery Box
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 49
    Forest Hills, KZN
    Default New National Luna Aux Battery Box
    So i'm looking for a 2nd battery setup for the camping fridge to stay charged, etc. when on the road and perhaps leave in camp while roaming about. I came across this and quite like the setup. No solar requirement right now, but there will be at a later stage so this looks like it will fit the bill of requirements.
    http://www.nationalluna.com/product/...ry-battery-box
    Thoughts? I saw it at ODW and the build quality looked fine. Has anybody used this yet? Will need to use the solenoid function with it otherwise the D4 won't charge the aux battery or so I believe.
    Then, how difficult is it to run the cable from the main battery to this box in the boot?
    Lastly, any other input is welcome.
    2004 LR Discovery 2 Td5 GS - mods in thread en route. (Ingwe)
    Jun 2013
    Default Re: New National Luna Aux Battery Box
    Hi, just my 2c
    I had a good look at these, and they look fantastic. Then I thought OK what application here.
    If I was to install this in my vehicle I would now need to install either a solenoid or a DC-DC in order to charge through the vehicle. To charge it through the box I would need to buy an NL charger and I still have no solar unless I use a separate controller and feed an input.
    Why then spend so much on that box when it needs add ons. Sure it look sexy but the normal grey box actually does more for the 4x4 guy.
    It is easy to wire because you just need an input, the solenoid is inside and you have your meters too. You can easily use solar by having a controller and feeding a grey input/output.
    You could for a better cost use a WRND and build a box to your requirements.
    BMW R1200R
    Hillcrest, Malaysia
    Hi, just my 2c
    Maybe have a look at the Data sheet. It contains a solenoid already, and a whole bunch of nice stuff, properly integrated.
    Experience tells me never to discount the value and true costs of all the little bits and bobs we eventually land up adding to make a reliable functional syste.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Jun 2013
    OOPS my bad, if it has the solenoid already that certainly changes the picture. Point taken, READ THE INSTRUCTIONS.
    This is the bit I saw
    Optional Extras:
    • In-line Fuse holder
    • Intelligent Solenoid
    • NL5 Battery Charger
    • Additional 29mm Sockets
    • 7 metre 16mm˛ charge cable kit
    BMW R1200R
    Forest Hills, KZN
    Yes, the solenoid is an added extra.
    For me, the complete wiring noobie this seems like an easy enough solution.
    NL Box
    NL Solenoid
    NL Batter controller
    Battery
    Jun 2013
    NL Box
    NL Solenoid
    Battery
    Yeah but,
    add all the individual items up and the older grey box is much less expensive. All it would require would be a fused line, 2 wires, running from the crank battery to the box and plugged into the red input.
    The solar requirements would be the same for both boxes.
    PS, I am an NL fan
    BMW R1200R
    Forest Hills, KZN
    Yeah but,
    PS, I am an NL fan
    Is it cheaper because the solenoid/isolator is built in?
    The other feature that plays a part for the black box is the layout. All plugs, etc. is on the front and not the side.
    http://www.4x4direct.co.za/battery-b...ttery-box.html
    Thhis is the same one? Yes. Only thing is that it kinda limits you to the NL Smart chrger! I have the older version http://www.4x4direct.co.za/battery-b...-luna-box.html and it works like a charm combined to a 12v DC-DC and 220v Smart charger!
    Forest Hills, KZN
    Quote Originally Posted by Luka View Post
    Which dc-dc charger and 220v smart charger please?
    And do you perhaps have a wiring diagram to follow?
    Edit: oh, and where do you see it is limited to the NL smart charger?
    Which dc-dc charger and 220v smart charger please? http://www.4x4direct.co.za/dc-to-dc-chargers/8487-dc-to-dc-charger-20amp-solar-mppt.html
    And do you perhaps have a wiring diagram to follow? No need, they are included, two 10sq cables from main batt, two to aux battery. And the other two are for solar power input (Controller already part of charger)
    Edit: oh, and where do you see it is limited to the NL smart charger? Look at the description: For charging from 220 volt a socket is supplied which fits the standard National Luna 5 Amp charger
    Forest Hills, KZN
    Thanks, so to sum this up, in order to charge with no issues from my D4 to the NL aux box, all I need is:
    The NL box
    The WRND charger
    Battery
    + Solar panel for later charging?
    Just the NL Box and a battery in it, properly wired. Just make sure that the NL box is configured for the Disco 4
    Gavin
    The NL box
    The WRND charger
    Battery
    Yes plus a NL 5A or other (Modify connection) smart charger for 220V charging.
    Forest Hills, KZN
    Quote Originally Posted by gavpike View Post
    How do you mean configured for Disco 4?
    Hi, just my 2c
    Agree. Good advice.
    Forest Hills, KZN
    Hi, just my 2c
    So, see if you agree with me on this one please?
    1 x http://www.4x4direct.co.za/battery-b...-luna-box.html
    1 x http://www.4x4direct.co.za/battery-b...y-bracket.html
    1 x http://www.4x4direct.co.za/dc-to-dc-...tml?ipa=0&ins=
    1 x deep cycle battery.
    Then I just need the cabling and lugs from the primary battery (with fuse inline) to the WRND Charger - from the WRND to the NL Box. Solar can then be plugged in to the WRND controller at a later stage.
    What size cabling is needed and is there a easily available kit that doesn't include unnecessary extras?
    NL have a specific configuration in the management system for the Disco4. The guys selling it should know about it.
    Gavin
    Hillcrest, Malaysia
    Optional Extras:
    You can add in things like USB chargers, built in Digital Voltmeter.
    It really is a nice package.
    ZS5KAD
    3 V8's
    Forest Hills, KZN
    Um, ya, they weren't really helpful when calling. I am getting clearer information here.
    Forest Hills, KZN
    Why you throwing spanners in the works Keith?
    Please check my earlier post where I linked to the items on 4x4 direct and comment. I'm stoopid with this stuff.
