New National Luna Aux Battery Box - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 48 of 48
    Forest Hills, KZN
    Thanked: 647
    Default Re: New National Luna Aux Battery Box
    Quote Originally Posted by RichardB_ZA View Post
    I recently did a similar setup, also got all the components from 4x4 direct:
    Haha. Exactly where I out my WRND also..
  2. The Following User Says Thank You to douglash For This Useful Post:
  3. #42
    Apr 2019
    Ruimsig
    Hi guys, on the WRND - will it work optimal with a ‘Smart’ altenator ?
  4. #43
    May 2011
    Thanked: 695
    Quote Originally Posted by Jacques13 View Post
    Yes!
  5. #44
    Jan 2011
    Thanked: 91
    Also got me one. Added an LED light to the front of the NL box. Mounted the WRND at the back of the box with only two BH plugs. The grey connects to the vehicle (battery and alternator) via a BH plug mounted in the load bin of the bakkie and the yellow to my solar panels. Tested it with my NL fridge and works great. Click image for larger version.
ID:	525575Click image for larger version.
  6. #45
    Forest Hills, KZN
    Thanked: 647
    Yes, just make sure it is wired in. I have it in my Disco and no issues..
  7. #46
    Apr 2009
    Thanked: 191
    can you also charge from solar/charge controller via the RED input plug on the box?
  8. #47
    Thanked: 2294
    I modded a box for a mate and on opening the front panel, you can see that all of the input /outputs are basically direct. There is no solenoid or charging electronics inside.
    You can use the red or grey for input as long as there is a controller before the input. This could be a solenoid, but you would still need to monitor this. It could be a PWM or MPPT controller or a combined one like the WRND, or it could be a charger (recommend smart) with a BH adapter.
    You can also get the NL charger lead separately to plug into the box from a charger.
    I wired a PWM direct to the battery and works like a charm for solar charging.
    BMW R1200R
  9. #48
    Apr 2009
    Thanked: 191
    oh okay cool, I have a Victron MPPT Charge controller, so will go through the red plug..
    Thanks for the info!
