My Knife Making Thread
Page 1 of 12 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 20 of 238
    Kimberley
    Thanked: 68
    Default My Knife Making Thread
    I have posted on a few threads, I decided to start my own.
    i posted my last three projects, the others are not that great
ID:	487803   Click image for larger version.
    Pajero Gen2 1996 2.8TDi LWB
    Kimberley
    Thanked: 68
    Default Re: My Knife Making Thread
    Tomahawk forged
ID:	487805   Click image for larger version.
    Kimberley
    Thanked: 68
    Sheath for tha tomahawk
    Kimberley
    Thanked: 68
    The gas forge with the burner i build recently.
    testing phase. i added a air quick release coupling and red devil regulator with 9kg bottle. also closed up the hole going into the forge
    Gaborone, Botswana
    Thanked: 1043
    Following....
    Kobus
    Jul 2015
    Richards Bay
    Thanked: 43
    Quote Originally Posted by hogbeast View Post
    That is looking good. How much gas do you use roughly?
    2004 Pajero LWB 3.8 - My toy
    1998 Pajero SWB 3.0 - SWAMBO's toy
    FJ45 with fibreglass body and 3CT motor - being built
    durban
    Thanked: 905
    How hot can a forge like that get.?What are you using to grind your knives?
    Kimberley
    Thanked: 68
    Quote Originally Posted by furpile View Post
    For heat treat only i used a 7kg bottle. Probably 5 to 10 blades
    Kimberley
    Thanked: 68
    Unhappy Re: My Knife Making Thread
    I can weld in the forge. I measured 1300 degrees then i pulled the thermocoupler
    My actual problem is to get 816 degrees for carbon steel
    I build a belt grinder to take the 2m belts
    durban
    Thanked: 905
    How do you adjust heat in a gas forge .?Or dont you. What style grinder is it.I am battling to find a reasonably priced 8 inch wheel. They are hellish expensive.
    Gaborone, Botswana
    Thanked: 1043
    ....I am battling to find a reasonably priced 8 inch wheel. They are hellish expensive.
    I made mine with MDF.
    Kobus
    Kimberley
    Thanked: 68
    I use the red devil high pressure reg to control the pressure and i control the air flow on the burner.
    I found nylon wheels with fitted bearings as wheels. Not the ideal but works well enough
    Kimberley
    Thanked: 68
    My next project
    Lets see how it turns out
    Templates cut out. Now i can refine the design
ID:	489289   Click image for larger version.
ID:	489290   Click image for larger version.
    Kimberley
    Thanked: 68
    Would you willingly invest in a carbon steel kitchen knife or do you prefer stainless steel
    durban
    Thanked: 905
    stainless for kitchen.
    Kimberley
    Thanked: 68
    Eventually started work on my three burner forge
    Mar 2012
    Thanked: 844
    Don't want to hijack your thread but just a quick question for KobusDJ. How is that MDF wheel holding up for you?
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
    Gaborone, Botswana
    Thanked: 1043
    Quote Originally Posted by ViperR View Post
    This was when it was new. See here.
    Apart from being dirty, it has served me well. This is a small pulley, I have seen much bigger MDF wheels/pulleys running on youtube.
    Kobus
    Mar 2012
    Thanked: 844
    Dankie! Het laas week geky na wiele maar ja hulle is duur self al voer ek hulle in.
    Honda Civic Type R
    - Daily Drive
    Kimberley
    Thanked: 68
    Finished and tested the burners today
