My Knife Making Thread - Page 14
Page 14 of 17 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 261 to 280 of 323
  1. #261
    Thanked: 269
    Default Re: My Knife Making Thread
    In any case he used a negative method where the blade was exposed to uv etc.
    I think it might be the same type of method you are using.
    Maybe you can try to contact him via his website. He lives in Parys.
  2. #262
    Kimberley
    Thanked: 125
    I don't know when it is forged
    This was hammered thinner and broader. Some kind of cleaver type sharp metal object.
    12mm leafspring down to 6mm
    50.5mm wide to around 7 or 8mm I could not make a accurate reading. OAL as this stage about 240 to 250mm. Tang is around 100mm
    I did three normalize cycles and left it in the forge to cool slowly over night. After bringing it evenly to critical temp. I hope I did not do something silly after all I have no idea what I am doing
    Pajero Gen2 1996 2.8TDi LWB
  3. #263
    Thanked: 269
    Why three cycles? Is normalise and anneal in this case the same thing?
    Wrt not knowing what you're doing, at least you do something. Sometimes one musn't be too scared to try something.
    I believe in any case you couldn't mess it up. It should be soft now and when you're finished tou just harden and temper it again.
  4. #264
    Kimberley
    Thanked: 125
    From what I understand you need to normalize after forging cus u heat up the steel over 800 degrees that is when grain growth occurs. Thus normalize to reform the grain into tightly packed structures. This is not achieved in one step depending on the growth that may have occurred. Thus 3 cycles. This is what I have read and seen. At least 3 cycles after forge welding which is much hotter than what I was doing.
    Annealing is the softening of the steel to a workable state since it was leafspring that was harden before
    Like I said this is my understanding. If I missed something please correct.
  5. The Following User Says Thank You to hogbeast For This Useful Post:
  6. #265
    Thanked: 269
    Thank you for the explanation. Now I understand. Makes sense.
  7. #266
    Kimberley
    Thanked: 125
    Done the profile and grind away the hammer blows. It was a bit heavy and I wanted it to be a broad knife rather than a chopper. Very thin at 3mm.
    Did the heat treat as well and almost forgot to drill the holes
    I want a 30mm high grind. This means a very steep grind angle. Looks like 2 degrees. My till table cannot grind that steep. I will have to go back to the jig. I must get the grind proper to make this project pop. Else it is back to try again and that is something I don't want to do
    See the original size of the leafspring
ID:	571665   Click image for larger version.
ID:	571666   Click image for larger version.
ID:	571667   Click image for larger version.
ID:	571668   Click image for larger version.
  8. The Following 2 Users Say Thank You to hogbeast For This Useful Post:
  9. #267
    Kimberley
    Thanked: 125
    For the last week I was testing dry film etching. Initial results showed promise but when I etch the blades every thing went wrong.
    Out of desperation I went back to the positiv20 method. However I learned a few things through my experimenting. Thus the result.
    One test piece perfect
    Two blades perfect
    I am growing increasingly confident with each etch
  10. The Following 2 Users Say Thank You to hogbeast For This Useful Post:
  11. #268
    Kimberley
    Thanked: 125
    What do you think. I think I have the process down.
    I must design the graphic on the other side.
    Let's see how it turns out.
  12. #269
    Thanked: 269
    I'm glad you got it sorted. It seems " practice makes perfect" still rings true.
    Congrates.
  13. #270
    Kimberley
    Thanked: 125
    Congrates.
    Thank you for the encouragement
  14. #271
    durban
    Thanked: 1060
    ..it looks real good .......What did you change in your approach?
  15. #272
    Krugersdorp
    Thanked: 96
    HI Guys
    Completed my first knife ever...
    I used 4mm 01-Tool Steel, hardened it and Tempered it etc.
    Added a Hollow Grind and sharpened with whetstone.
    Handle is made from Mozambique Teak wood with brass pins inserted.
    2014 Nissan Pathfinder 2.5 SE 4x4
    2015 Conqueror Courage
  16. The Following 2 Users Say Thank You to Ruan_1 For This Useful Post:
  17. #273
    Kimberley
    Thanked: 125
    Quote Originally Posted by Ruan_1 View Post
    HI Guys
    Nice one. Much better than my first attempt
  18. The Following User Says Thank You to hogbeast For This Useful Post:
  19. #274
    Kimberley
    Thanked: 125
    With the dry film method you heat the film to adhere to the steel. You place the steel in the tray and wash the developer over it. This made me think if I can use the same approach. You also sandwich the stencil between glass and the steel.
    So first thing I did was spray on the positiv20 wipe off repeat twice leaving a thin layer each time then spray a thin coat. Then heat it with a clothes iron to around 60 to 80 degrees. It then sits 30 to 60 minutes (not sure I do other stuff not really time it. Metal must be cool before exposure)
    I expose 90sec and let sit in the the dark for 15 minutes
    I then remove the stencil and develop in the caustic soda. I find the resist is very durable. Much more than just letting it dry over night.
    Block off area and etch with ferric chloride.
    I have improved the result ten fold
    In the last Pic u can see the difference. I could not do the sandwich thing. My blade warped slightly
ID:	572837   Click image for larger version.
ID:	572838   Click image for larger version.
ID:	572839   Click image for larger version.
ID:	572840   Click image for larger version.
  20. The Following User Says Thank You to hogbeast For This Useful Post:
  21. #275
    Kimberley
    Thanked: 125
    Bolsters coming on nicely. Pins invisible thus far. I hope they don't show themselves.
    Don't use cheap lock down drill bits. They don't drill exactly round and to size thus u get movement where you don't want.
ID:	572935   Click image for larger version.
  22. #276
    Thanked: 269
    Quote Originally Posted by hogbeast View Post
    You prefer UDL?
  23. #277
    Kimberley
    Thanked: 125
    You prefer UDL?
    What is UDL?
  24. #278
    Thanked: 269
    What is UDL?
    It's jobber drill bit made from cobalt(?).
  25. #279
    Thanked: 306
    HI Guys
    Looks GREAT, well done!
    Cruiser 76 V8
    Disco 4 XS
  26. The Following User Says Thank You to wildhunter For This Useful Post:
  27. #280
    Kimberley
    Thanked: 125
    First time I heard about this type.
    No I use the slightly more expensive. Like 30 bucks or so works well for me. Just this time I found these and I was lock down desperate. It was like R8🙄
